WillUribe(at)aol.com Guest
Posted: Mon Aug 07, 2006 6:28 pm Post subject: FireStar II flying the US- Mexican border |
Greetings Kolb fan,
It has been raining way too much here in the desert southwest so I thought I
would do a little recon over the Rio Grande this past Sunday.
Below is a link to a short video I took during the flight.
Be advised the file is 4.92 MB so dialups need not view it.
http://members.aol.com/ELPEAA125/border.WMV
Will Uribe
FireStar II
El Paso, TX
http://members.aol.com/willuribe/mv/
N111KX (Kip)
Posted: Mon Aug 07, 2006 6:55 pm Post subject: Re: FireStar II flying the US- Mexican border |
Pretty cool, Will.
_________________ Kip
Firestar II, N111KX
Waiex, N111YX
Quickie 1, N111QX
Atlanta |
biglar
Ralph Hoover
Joined: 09 Jan 2006 Posts: 206 Location: Central Ohio
Posted: Tue Aug 08, 2006 10:12 am Post subject: Re: FireStar II flying the US- Mexican border |
Will, I'm impressed! Probably I use that too much. But I am. I know that you are dealing with thermals as I am watching the "Step away from the string"! Hey, in the video, you had that "schreec sound" as your wheels touched the asphalt. We dont' get that with grass!
You do good, my man. I would be interested in your camera mount. I have a Canon ES190 with 440 digital zoom and would be really interested in how and where you mounted yours. I have often looked at the "wing support tab". Not sure how well that would work.
See, we could trade video's; in the winter, you could send me really "hot" videos of desolation and heat, and I could send you pictures of the ground covered with snow, to the point I would have no idea where the field is. That would cool you off. How about it.
And Mikie, I hope this isn't percieved as Babbalon. You know where that "Babble-on " came from in the Bible don't you?
Ohio Ralph.......really hot here in Ohio!
Posted: Tue Aug 08, 2006 12:12 pm Post subject: FireStar II flying the US- Mexican border |
Hi Ralph,
I had a gusting cross wind to deal with when landing. Normally I like to
land long and touch down mid field to avoid a long taxi. It was not my
intention to touch down where I did but since I was being blow away from
center line I figured it was time to land.
A short while ago someone posted a picture of a Kolb with a camera mounted
on the side of the fuselage using a RAM mount. I wish I can remember who
posted it so I can give him credit for the idea. I already had the RAM mount
so when I saw the picture I had to try it out on my next flight.
Erich Weaver of California mounts his camera on the wing support tab, take a
look.
http://gtalexander.home.att.net/cam_mount.html
Will Uribe
FireStar II
El Paso, TX
Bill Vincent
Posted: Thu Aug 10, 2006 4:58 pm Post subject: FireStar II flying the US- Mexican border |
Hi Will
The video was great! I am curious what is the model/make of the camera you
used. Was it a digital camera or a digital video camera? Sorry if you
already answered this question ... been having computer problems.
Thank you
Bill Vincent
Firestar II
Upper Peninsula of Michigan
_________________ Bill Vincent
Firestar II
Upper Peninsula of Michigan |
Posted: Fri Aug 11, 2006 6:11 am Post subject: FireStar II flying the US- Mexican border |
Hi0 Bill,
I use a Panasonic digital0 palmcorder model No. PV-GS200 with a Leica lens, saves the digital video on0tape0 and also saves 2.3 mega pixel still pictures on a 1 GB memory card. The reason I0 liked this camcorder is it has a 3 CCD image sensor system that handles color0 the same way as broadcast equipment before they went to high definition0 cameras.
This picture was0taken0 from the video, notice "La Migra's" watch tower on the lower right hand corner,0 they are keeping our borders safe from terrorist. The tower is enclosed0 like an airport control tower with air conditioning and tinted windows. It is0 mounted on a trailer and can be moved any where along the border. It uses0 hydraulics to raise and lower it.
111.11 KB |
587 Time(s) |
