roncarolnikko(at)hotmail. Guest
Posted: Sun Aug 06, 2006 8:12 pm Post subject: First flight 541KF |
Having recently completing my tailwheel training I left the field today in
N541KF. The VW powered MK IV Speedster is an absolute joy to fly. Slips
through the air without all of the parasitic drag of my STOL Avid. Flys
hands off and does not squirrel around when the power settings are changed.
This was a concern with the thrust centerline/ angle using the redrive. The
controls feel smooth and solid begging for more input than I plan to do for
a while. Balance feels perfect as I can stall the tailwheel down before the
mains if I want.
That is the good part.... The prop is overpitched and climbed 500' per
minute at best. Cruise was around 90 without being able to reach redline
rpm. Worse than that was this nasty little habit of misfiring after about
1/2 hour hard running. I was doing a left then right mainwheel touch and go
to see what the alignment felt like on asphault. The landing went well with
no tendancy to swerve from either main wheel and a nice transition to
tailwheel. With 3000' of runway 31 asphault left I chose to go around
again. At about 300' agl the motor misfired a few times and I radioed
landing runway 22. I could not contact a small helo playing long on that
runway so I amended my landing to runway 16. This was a 230 course
reversal. With a tailwind and a pos motor I made the turn. It went well and
I could have landed anywhere there if needed. Fortunately I made the runway
so our overactive firefighters did'nt come over and hose me.
After gapping down the plugs at a friends hanger it ran flawlessly. Ten
miles to the north, near my grass strip, I began some steep turns and stalls
to get at least some performance testing in. After 1/2 hour running I made
for the pattern. On my turn to base the same misfire. Yes practice slips
and s turns and come in hot! I had my carb heat on and I don't think it was
ice. I believe it may be that my magneto is overheating and needs baffles
and a scat hose. After cooling down it once again runs perfect. I'll
check fuel flow as well. Any ideas??? Ron NB Ore Cleaning the shorts
Don’t just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
morid(at)northland.lib.mi Guest
Posted: Mon Aug 07, 2006 5:07 am Post subject: First flight 541KF |
Good story Ron, thanks. Obviously, only four things need to happen for the
engine to run properly. Fuel, air, spark, and both to meet at the correct
time. The first thing I'd check would be the fuel flow. Ensure it is
within the fuel flow requirements. Check free flow and also the flow with
pump on. Do you have a backup pump? You obviously have spark or the engine
wouldn't run. However, when things heat up something is obviously breaking
down. While checking fuel flow I would replace the plugs because it's the
cheapest and easiest to do then go out and try again while taking note of
all ambient conditions. Cleaning and gapping will not help a plug with a
small crack in the insulator. Do you have EGT gauges? Do they read any
different during this time. Does the engine miss under load or at all
times, even when you're taxiing back? What is the OAT during this time? Do
you have a manifold pressure (MP) gauge? Possibly you may have a small
vacuum leak which the MP gauge would show. Mags are designed to operate
under very high heat, but I wouldn't rule it out. Do you have a single mag?
Do you have access to a spare?
Hope some of this helps.
Deke
Posted: Mon Aug 07, 2006 6:32 am Post subject: First flight 541KF |
Hi Ron,
I had a VW for a long time and had the same thing
twice. Once it was ignition system overheat, and the
other was the ignition capacitor itself. (I tore the
whole engine apart for a $1.69 capacitor!)
Add to that your engine might carbon up with that high
pitch prop and just a little rich running.
I'd buy a cheap ($10) indoor/outdoor thermometer and
put the outside sensor on the ignition to monitor it.
Shield it from the exhaust heat too.
Just some thoughts.
Kurt S.
--- ron schick <roncarolnikko(at)hotmail.com> wrote:
| Quote: | Having recently completing my tailwheel training I
my STOL Avid. Flys
mains if I want.
nice transition to
chose to go around
times and I radioed
was a 230 course
hose me.
runs perfect. I'll
Cleaning the shorts
Posted: Mon Aug 07, 2006 6:39 am Post subject: First flight 541KF |
HI Deke. Single mag only and one cylinder misfires first if not the only
one. I have limited gauges so am diagnosing by experience of other vw
problems only. The plugs all looked the same with the excepion of the sooty
misfiring plug. I think it sooted up as a result rather than cause of the
misfire. Single barrell carb so I can eliminate many possibilities due to
the other strong pulling cylinders. The misfire occred under transition to
go around first, then at 50% or less power in the pattern the second time.
My first check will be to ensure fuel flow, then put a stock distributor in
for a test. I have everything to try this without spending more $$$$$ on
parts which may not be the problem. I have a zero time Revmaster with
dual plug heads that I may put on this engine if I can get the prop and
performance dialed in. Hate to cabbage a complete motor though. Thanks
Ron NB Ore
[quote]From: "Fox5flyer" <morid(at)northland.lib.mi.us>
Subject: Re: First flight 541KF
Date: Mon, 7 Aug 2006 09:05:56 -0400
engine
Do
mag?
Deke
vadert(at)telusplanet.net Guest
Posted: Mon Aug 07, 2006 6:57 am Post subject: First flight 541KF |
Ron
Sorry I can't offer any advice on the misfiring other than the things
you've already outlined. Well maybe one thing, check your fuel line for
nearby heat sources that could be causing some vapourizing problems. I
think it's more likely to be electrical. Oh, check the plug wires for
separation so they aren't crossfeeding each other. Congratulations on your
first flight. I hope you get your problems sorted out for the next flight.
Sounds like you handled your problems well on the first one. Good luck with
diagnosing the problem.
Tim Vader
C-FBYV (Sub IV)
Still repairing
Posted: Mon Aug 07, 2006 7:35 am Post subject: First flight 541KF |
It doesn't sound like a huge problem as you can easily see where it is
affecting one plug and shouldn't be difficult to track down. First thing
I'd do is change that plug and also the plug wire might be a bit of a
suspect. Changing the distributor is a good plan too. One of the problems
of doing too many changes in one go is that when the problem is fixed, you
don't know which fix fixed it! Good luck and congrats on first flight.
Deke
pulsair(at)mindspring.com Guest
Posted: Mon Aug 07, 2006 9:10 am Post subject: First flight 541KF |
It seems that everytime you had a problem you were in some type of turn. It
could be fuel disruption for some reason. Jeff Classic IV
