Alt. High pressure elect. fuel pump
rice737(at)msn.com
PostPosted: Wed Jan 18, 2006 9:28 pm    Post subject: Alt. High pressure elect. fuel pump Reply with quote
Hi all,
I searched the archieves, but could not find an cheaper alternative the airflow perf. pump Vans sells for the fuel injected engines. Anyone know of a viable alternative to this.
Paul
mrobert569(at)hotmail.com
PostPosted: Thu Jan 19, 2006 11:21 am    Post subject: Alt. High pressure elect. fuel pump Reply with quote
Actually, The Airflow pump that Van's sells is the cheapest alternative I've
found. The other "certified" pumps run almost double the cost of the
Airflow Performance.
Mike Robertson
Reply-To: rv-list(at)matronics.com
To: <rv-list(at)matronics.com>
Subject: Alt. High pressure elect. fuel pump
Date: Thu, 19 Jan 2006 00:26:08 -0500
Hi all,
Paul
cjensen(at)dts9000.com
PostPosted: Thu Jan 19, 2006 3:29 pm    Post subject: Alt. High pressure elect. fuel pump Reply with quote
You might check with Airflow Performance, but Don may have an agreement
not to undersell Van's, his distributor
Chuck Jensen
Hi all,
Paul
