7suds(at)Chartermi.net Guest
Posted: Sat Aug 05, 2006 3:48 pm Post subject: Battery Box |
List,
Installing an Odessey PC680 in my fox forward of the firewall, can I simply
construct a tray to hold it or does it need to be a full box?
Lloyd
markrmiller(at)cableone.n Guest
Posted: Sat Aug 05, 2006 4:33 pm Post subject: Battery Box |
Short answer is a tray with straps of sufficient strength is all that is
required.
Mark Miller
Michel
Posted: Sat Aug 05, 2006 10:30 pm Post subject: Battery Box |
On Aug 6, 2006, at 2:33 AM, Mark R Miller wrote:
| Quote: | Short answer is a tray with straps of sufficient strength is all that
is required.
I agree with Mark, Lloyd. The Odessey PC680 (also my battery) is sealed
and can be positioned any way, even upside down. I have had mine for
nearly two years, not on the firewall but right behind the seat, to
shift a bit the CG when I installed a Jabiru engine.
Cheers,
Michel
kitfox(at)itsys3.com Guest
Posted: Mon Aug 07, 2006 7:06 pm Post subject: Battery Box |
Aircraft Spruce sells a mounting bracket especially sized for the
PC680. It is reasonalbly priced, gets a secure grip on the
battery, and can be mounted with adel clamps pretty easily. I
have a picture of just such an installation in my Series 6 at
http://www.itsys3.com/kitfox/images/annual05/NewBatt.JPG
Bill Hammond
Parker, CO
Cudnohufsky's wrote:
