AMuller589(at)aol.com Guest
Posted: Sat Aug 05, 2006 5:19 pm Post subject: series V C.G and weight limits |
I tried to attach a Attach a copy of a factory weight and balance cleaned0 up of extraneous comments regarding other than un-swept wing, non-series V0 etc data. The series V comes in forward swept one degree or non swept wing.0THE0 MAX GROSS WEIGHT RECOMMENDED IS 1550 LBS BUT YOU CAN CERTIFICATE ANY MAX WEIGHT0 YOU DESIRE. The FAA inspectors recommend you use whatever you think your0 estimated max useful weight will be so you don't exceed it in use for insurance0 and accident purposes..The floor and bag are very large but you can also make0 the baggage compartment any shape you want and many people put in a long0 thin-wall pvc tube for skis and fishing poles. Its up to you to keep the c.g. in0 limits. The factory says the MGW is 1550 lbs , Mean Aerodynamic Center 51.10in,0 forward cgl imit 9.96 in, rearward cg limit 14.75 in. The cg limits are absolute0 and must be complied there is no discretion here, only in the max gross weight0 should you use other than factory limits and I don't recommend0 that.
shilocom(at)mcmsys.com Guest
Posted: Sun Aug 06, 2006 6:20 am Post subject: series V C.G and weight limits |
I guess the new series 7 airplanes that will be0 sold will have the 1320 GW that sport pilot allows according to the literature0 being handed out at OSH with a 1550 GVW option, which I think John said is a0 different landing gear being the main or only difference. Their literature0 shows EW of 750 lbs. which is likely very optimistic, since most Model IV's come0 out in or above that area, and if you actually come out around 900 lbs.0 which some have suggested you would only have slightly over 400 lbs. for fuel0 and people, or with full tanks of 27 gal, would make it a single place airplane0 for most of us and a max pilot weight of 258 lbs. One of the many0 "loop holes" I guess of the Sport Pilot thing. Bob U.
phil(at)lakercustom.com Guest
Posted: Sun Aug 06, 2006 7:34 am Post subject: series V C.G and weight limits |
I own and have flown a Vixen for 1500 hours. It weighs 755 pounds
on EAA's "certified" scales. Tri gear, 1550 Grove gear, Clevelands.
I was very carefull about weight from the first hour of build. I
am sure a 750 pound Kitfox Super Sport will be acheivable, and am
betting the business on it. The demonstrator fuselage and weldments
are going to the powder coater now, I'll keep you all posted. The
Super Sport 1550 option is a slightly heavier gear.
Thanks for the support shown us at Oshkosh!
Phil Laker
[quote] I guess the new series 7 airplanes that will be sold will have the 1320 GW
that sport pilot allows according to the literature being handed out at
OSH with a 1550 GVW option, which I think John said is a different landing
gear being the main or only difference. Their literature shows EW of 750
lbs. which is likely very optimistic, since most Model IV's come out in or
above that area, and if you actually come out around 900 lbs. which some
have suggested you would only have slightly over 400 lbs. for fuel and
airplane for most of us and a max pilot weight of 258 lbs. One of the many
rjdaugh(at)rapidnet.com Guest
Posted: Sun Aug 06, 2006 8:33 am Post subject: series V C.G and weight limits |
Just to support what Phil says: My Series 5 with a series 7 firewall
forward and 912S weighs 776 lbs. This is with Grove gear, large heavy
tires, adjustable pedals, dual brakes, two 13 gallon gas tanks and weight
conscious building.
750 lbs is not unreasonable.
Randy
lcfitt(at)sbcglobal.net Guest
Posted: Sun Aug 06, 2006 10:02 am Post subject: series V C.G and weight limits |
Have to disagree a bit with your numbers. First though, I scanned my
personal achives and found that you fly a Model IV and suspect you have a
582, is that correct? I am curious about your empty weight.
My Model IV with R-912 weighed in at 704 lbs with all fairings, spring gear
and junk like kick panels and carpet. Mine is the heaviest of all the ones
in our flying group and the lightest comes in at exactly 100 lbs lighter
than mine - 604 lbs.
Unlike other claims made by so many people trying to market such things as
engines, I can't imagine the three guys - all Kitfox owners - actually
builders and owners - and pilots would begin their tenure at Kitfox Aircraft
LLC with credibility damaging claims. Granted the numbers are likely
calculated, but it is not a group of engineers here, these guys, all three,
have walked the walk and have a lot at stake in terms of the success of
their business. With the major credibility damaging practices of late
Skystar, it would be hard for me to understand the new group starting off in
the same way.
Lowell
kerrjohna(at)comcast.net Guest
Posted: Sun Aug 06, 2006 3:27 pm Post subject: series V C.G and weight limits |
For what it is worth, my Classic IV/912UL with every speed fairing along with a full panel and upholstry/carpets came in at well under 700 (673). Maybe Bob is referring to the V's which likely will exeed 700#.
John Kerr, The Kitfox is more fun to fly than the RV9. "Dirt bike vs. Road bike"
I have three airplanes because I can't afford four; yet.
I guess the new series 7 airplanes that will be sold will have the 1320 GW that sport pilot allows according to the literature being handed out at OSH with a 1550 GVW option, which I think John said is a different landing gear being the main or only difference. Their literature shows EW of 750 lbs. which is likely very optimistic, since most Model IV's come out in or above that area, and if you actually come out around 900 lbs. which some have suggested you would only have slightly over 400 lbs. for fuel and people, or with full tanks of 27 gal, would make it a single place airplane for most of us and a max pilot weight of 258 lbs. One of the many "loop holes" I guess of the Sport Pilot thing. Bob U.
janderson412(at)hotmail.c Guest
Posted: Sun Aug 06, 2006 4:29 pm Post subject: series V C.G and weight limits |
Well, I built my V to last, turbo intercooled Subaru,(well built) belt drive. Every bit of metal painted, dual batteries, landing lights, strobes, strut fairings grove gear, alum tail spring, carpets etc etc. 945lbs....but what the hell, I'm just a skinny fellow and my good lady's the same so..With a bit of weight they fly nice. John A.
[quote] From: kerrjohna(at)comcast.net
Subject: Re: series V C.G and weight limits
Date: Sun, 06 Aug 2006 23:08:50 +0000
Posted: Mon Aug 07, 2006 5:58 am Post subject: series V C.G and weight limits |
I stand corrected. I was going by others weights on IV's and 7's. A
recently posted weight and balance sheet showed a Series 7 in the 1050 lb.
range I believe. This just substantiates how different airplanes can be
built from the same parts. I hope Phil incorporates many of the vacuum
molded parts he made for his airplane also. What I know for sure is most
light experimentals fly soooooo much better light. Maybe someone can tell
me if there is much difference in weight of the series 5 vs the 7 and if
someone has already built a series 7 in the 750 lb range. Bob U.
