Graeme Toft
Posted: Sun Jul 30, 2006 11:05 pm Post subject: Vacuum pressure |
Hi Guys, I just had another 30 minutes in the circuit letting things settle in but noticed my vacuum (MAP) is sitting on 10 on take off (only pulling 5200rpm) and goes back to around 3 at 4400 rpm in cruise. Are these figure OK and if not how are they adjusted?
Graeme
AMuller589(at)aol.com Guest
Posted: Mon Jul 31, 2006 8:30 am Post subject: Vacuum pressure |
our non-turbo subaru shows nearly 29 in hg on t.o. and ground runup and about 10 in hg at idle. We first had inaccurate/no readings thinking there was a wiring problem but found the manifold pressure line had been clogged at the sensor box inlet with sealant. Sounds like your problem is pinched or plugged line. Check for adequate flow by sucking on it?
