Hopperdhh(at)aol.com Guest
Posted: Fri Jul 28, 2006 12:02 pm Post subject: little symbols -- was Antennas general |
In a message dated 7/28/2006 3:10:39 P.M. Eastern Daylight Time, altoq(at)cebridge.net writes:
| Quote: | --> AeroElectric-List message posted by: "John D.Heath" <altoq(at)cebridge.net>
NOT RV Related
Just as a point of intrest, if you want V²2/R, turn Number Lock on, hold
down Alt key and type 0178 on the Number Pad. When you release the Alt key
the ² pops up. Degrees (X°) is 0176 and (X³) is 0179. This is done through
Charicter Map and there are many more. Check it out in System Tools. It is
an automatic install for Windows XP but you might have to install it in
98/SE. Its on the Windows Disk.
John D.
John,
Wall, all'll be!
How do you know all this stuff?
do not archive either
Dan
dcarter11(at)sbcglobal.ne Guest
Posted: Fri Jul 28, 2006 4:23 pm Post subject: little symbols -- was Antennas general |
[quote] Using Character Map
You can use Character Map to copy and paste special characters into your documents, such as the trademark symbol, special mathematical characters, or a character from the character set of another language.
Open [url=ms-its:C:\WINDOWS\Help\howto.chm::/EXEC=MyDlgClass,charmap.exe, CHM=ntshared.chm FILE=alt_url_windows_component.htm][img]cid:0c6601c6b2a4$4ff7ac10$0701a8c0(at)davidsdell8200[/img]Character Map[/url].
[img]cid:0c6701c6b2a4$4ff7ac10$0701a8c0(at)davidsdell8200[/img] Notes - To open Character Map, click Start, point to All Programs, point to Accessories, point to System Tools, and then click Character Map.
- For information about using Character Map, click Help in Character Map.
Copied the above from Start, Help, character map in search field.
David Carter
[list]---
79 Bytes |
1902 Time(s) |
Dale Ensing
Joined: 11 Jan 2006 Posts: 571 Location: Aero Plantation Weddington NC
Posted: Sat Jul 29, 2006 4:02 am Post subject: little symbols -- was Antennas general |
Thanks David,
my old brain might be able to remember that route.
Dale Ensing
do not archieve
79 Bytes |
1904 Time(s) |
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
