Door Raising GooseCreek Airport
Ed Anderson
PostPosted: Wed Jul 26, 2006 12:14 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
Well, after a bit of work, the framework for my hangar door is ready to be raised to the hinge bar (See photo).  The framework is 40' at the bottom and 30' at the top and weighs (est) approx 350-400lbs.  I just need to stand it on its bottom side (side nearest front in photo)  - so only need to tilt the framework up 90 deg from its position on the floor.  Place a few clamps to hold things in place and I can proceed from that point.
I believe either 3 old cougars and/or 6 young studs could do the job.  So if you fit into either category and have the time and interest, I could use your assistance.  I estimate it should not take over 30 minutes (actually more like 15 seconds) to raise the framework.
I am hoping for this Saturday AM probably around 1030 or whenever sufficient bodies show up.
Thanks in advance
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com (eanderson(at)carolina.rr.com)
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
 Filesize:  59.88 KB
 Viewed:  205 Time(s)
Ed Anderson
Matthews, NC
eanderson@carolina.rr.com
Dale Ensing
PostPosted: Wed Jul 26, 2006 12:39 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
Ed,
Will one old geezer be of any worth? (A geezer is a  little older than a cougar!) Anyway, I should be around to assist in the momentous movement.
BTW is a Door raising anything like Hell raising?
Dale
do not archieve (does the RVSouthEast list have archieves)
Dale Ensing
RV-6A
Aero Plantation
Weddington NC
Ed Anderson
PostPosted: Wed Jul 26, 2006 1:00 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
Well, we can hand the old geezer the horse whip to keep everyone else toeing the line.
Thanks, Dale
Ed
Ed Anderson
Matthews, NC
N777TY
PostPosted: Wed Jul 26, 2006 1:02 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
Ed, I can come by...
Radomir
-7A Finish
the framework.
Thanks in advance
Ed
Ed Anderson
Matthews, NC
RV-7A
N777TY
Steve Glasgow
PostPosted: Wed Jul 26, 2006 1:38 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
How about an old geezer.  Just remind me.
Also do you need the latter before Saturday?  If not I will pick it up tomorrow an bring it back on Saturday.
Small project to do at JQF.
Cappy
Steve Glasgow-Cappy
Cappy's Toy
RV-8 N123SG
Ed Anderson
PostPosted: Wed Jul 26, 2006 3:11 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
Hi Steve,
Finished with the ladder yesterday, so your ladder is yours to take home - thanks, it came in handy putting in those last bolts attaching front sheets to arch.  Won't need a tall one on Saturday, I think with the one I have and Bill's short one it will be enough
Ed
Ed Anderson
Matthews, NC
Ed Anderson
PostPosted: Wed Jul 26, 2006 3:26 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
Thanks, Radomir.
Appreciate your help!
Ed
Ed Anderson
Matthews, NC
sawad13(at)msn.com
PostPosted: Wed Jul 26, 2006 5:26 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
I hope to be out at the airport Saturday and would be glad to lend a helping
hand.
Ron Awad
Reply-To: rvsoutheast-list(at)matronics.com
To: <rvsoutheast-list(at)matronics.com>
Subject: Door Raising GooseCreek Airport
Date: Wed, 26 Jul 2006 16:12:10 -0400
Thanks in advance
Ed
Ed Anderson
Matthews, NC
<< MVC-008F.JPG >>
Don’t just search. Find. Check out the new MSN Search!
http://search.msn.click-url.com/go/onm00200636ave/direct/01/
Ed Anderson
PostPosted: Wed Jul 26, 2006 5:29 pm    Post subject: Door Raising GooseCreek Airport Reply with quote
Thanks, Ron. Appreciate the help
Ed
Ed Anderson
Matthews, NC
