Dave Pelletier
Joined: 10 Jan 2006 Posts: 100 Location: Prescott, Arizona
Posted: Tue Jul 25, 2006 2:48 pm Post subject: Emailing: HPIM1049 |
A couple of guys asked for pictures of my "T" stand. All it is is a stand with felt on top. It telescopes up and down with holes drilled into the stem and locked by a pin (or bolt or ???). As it stands, it is 51" high, which is just right for my wing. When rigging my MKIII, I position the stand a bit inboard of where the outboard tip of the wing will be. Then I swing the wing out and rotate it into "flying" position and work the inboard edge into the lip of the fuselage. When it pops in, I hold the wing with one hand and finish positioning the stand with the other. Then I rest the wing on the stand and hurry over to the fuselage end and put in the pin. After that I lift the wing a bit with my shoulder and hook up the strut. Then when the aileron and flap pushrods are hooked up it's a done deal. Piece of cake.
I don't plan on doing much flying for the next week or so because we're getting rain - Arizona's "monsoon" (Ha!) season. But if anyone wants more pics of something, let me know and I'll take them next time I fly.
AzDave
51.84 KB |
371 Time(s) |
_________________ AzDave |
rlaird
Posted: Tue Jul 25, 2006 7:32 pm Post subject: Emailing: HPIM1049 |
Dave --
Thanks for the picture... it speaks a thousand words, and although
you may think it too simple to warrant a posting of the image, I
hadn't thought it would look like that, so, I'm really glad you did!
Again, thanks!
-- Robert
On 7/25/06, Dave & Eve Pelletier <pelletier(at)cableone.net> wrote:
Piece of cake.
AzDave
_________________ ~~~~~~~~~~~~~~~~~~~
Robert Laird
Houston, TX area
http://www.Texas-Flyer.com |
pj.ladd(at)btinternet.com Guest
Posted: Wed Jul 26, 2006 1:38 am Post subject: Emailing: HPIM1049 |
pictures of my "T" stand>>
Hi ,
very neat. I had envisaged something more like a step ladder to accomodate rough ground. I assume from the small flat base that you usually rig on a flat surface.
Pat
