VHF antenna mounting
wgill10(at)comcast.net
PostPosted: Mon Jul 24, 2006 6:20 pm    Post subject: VHF antenna mounting Reply with quote
Hello All,
I’m mounting two VHF bent whip antennas on the belly of an RV-7. Where can I find information pertaining to doubler requirement? Also, a cork gasket/seal is installed between the Comant antenna base and the fuselage skin – is the antenna base grounded to the fuselage via the mounting screws since the cork seal insulates the antenna base? Thanks.
Bill Gill
RV-7 wiring
Lee’s Summit, MO
jmoreau2(at)cox.net
PostPosted: Mon Jul 24, 2006 6:58 pm    Post subject: VHF antenna mounting Reply with quote
What position are you mounting them in.  I am getting ready for bent whips on the belly of my RV8A.  I was wondering how close together you are mounting them.Are they side=by side, or in line with the centerline of the fuselage.  Any info would be appreciated.
Jeff Moreau
Virginia Beach, VA
On Jul 24, 2006, at 10:15 PM, William Gill wrote:
Hello All,
Bill Gill
RV-7 wiring
Lee’s Summit, MO
PostPosted: Mon Jul 24, 2006 7:14 pm    Post subject: VHF antenna mounting Reply with quote
Hello Jeff,
I’m mounting them side by side…they are about 32” apart.
Bill
FLYaDIVE(at)aol.com
PostPosted: Tue Jul 25, 2006 1:21 am    Post subject: VHF antenna mounting Reply with quote
In a message dated 7/24/06 10:23:27 PM Eastern Daylight Time,
wgill10(at)comcast.net writes:
Hello All,
I'm mounting two VHF bent whip antennas on the belly of an RV-7. Where
fuselage skin - is the antenna base grounded to the fuselage via the
Bill Gill
RV-7 wiring
Lee's Summit, MO
Bill:
It is just good practice to reinforce an antenna mounting with a doubler. In
most if not all antenna packages a doubler is supplied.
Considering the design of an antenna you have a lot of unsupported material
just dangling out in the breeze, better to support it than to take the chance
of metal fatigue due to concentrated vibration points.
As for the electrical grounding ... YES ... You are correct, the grounding is
accomplished through the screws. So you can imagine that a doubler installed
against the unpainted aluminum, followed up with good screws and lock washers
will do much to improve everything associated with the ground and function of
the antenna.
One small trick with the cork seal, put a light smear of RTV on both sides of
the cork. This is not a major trick but it will keep out moisture and
improve the seal.
Barry
"Chop'd Liver"
"Show them the first time, correct them the second time, kick them the third
time."
Yamashiada
FLYaDIVE(at)aol.com
PostPosted: Tue Jul 25, 2006 2:52 am    Post subject: VHF antenna mounting Reply with quote
In a message dated 7/24/06 11:01:15 PM Eastern Daylight Time,
jmoreau2(at)cox.net writes:
Jeff Moreau
Virginia Beach, VA
Jeff:
By definition bent whips are belly mounted.
Keeping antennas as far apart as possible is always a good thing. If I
recall the minimum distance recommended is 36" . Yet that is very hard to
maintain. I have two mounted on the belly under the leg area of an RV-6 only about
20" apart. I do not have any front end overload or directivity to the pattern.
If I was building the plane and had access to the tail easier I would install
them in line on the center line (rivets permitting) and the recommended 36+"
apart.
You might also want to take note that COM #2 is usually mounted on top of the
plane. This is to aid in better ground communication while on the ground.
While Com #1 is used in the air. Once airborne Com 1 & 2 do work very well in
the air.
Barry
"Chop'd Liver"
time."
Yamashiada
Hopperdhh(at)aol.com
PostPosted: Tue Jul 25, 2006 5:22 am    Post subject: VHF antenna mounting Reply with quote
Bill,
I riveted 2 short pieces of leftover stiffener material from the fuselage across between the seat ribs that the antenna screws go up through (for one antenna).  The antenna feels pretty solid with very little weight gain.
Dan Hopper
RV-7A
In a message dated 7/24/2006 10:23:27 P.M. Eastern Daylight Time, wgill10(at)comcast.net writes:
Hello All,
Bill Gill
RV-7 wiring
Lee’s Summit, MO
gmcjetpilot(at)yahoo.com
PostPosted: Tue Jul 25, 2006 6:22 am    Post subject: VHF antenna mounting Reply with quote
Bill:
Yes the ground is thru the screws so make sure there is no
primer and the nut plates are grounded to the airframe,
assuming you will use nut plates which is highly recommend.
The primary load is air drag load, which is very small. You
can go crazy and make very large structural doubler's. Back
in the old days with huge ADF and VOR flying wing antenna's
structural doubler's where important. Your light weight bent
com antenna is tiny compared to those lead sails.
The belly on the RV is very thick. If you are in the area fwd of
the main spar, not much doubling is needed. You do want local
stability to keep it from flexing.
Old FAA best practices AC 43 12-2A (chap 1)
structures, shows antenna doubler's.
Here are some ideas from the FAA AC source:
If you place the antenna near a stiffener or rib, a good idea,
you can bend an angle into the doubler to joggle or butt
against the rib or angle and rivet to that. It's standard. to
fill the whole BAY from stiffener to stiffener laterally wide. Your
doubler will be square/rectangle from stiffener to stiffener and
the width, fwd/aft, will be long enough to extend past the
antenna foot print by 1.5" min on each end or to a frame.
The above is ideal an very strong but not needed for a
small COM antenna on a thick skin belly. If you put the
antenna near a stiffiner the doubler may not be needed,
at least on the RV forward belly.
A traditional doubler, lets say just plop it right in the middle
of a skin bay, has the same foot print but twice as large and
one gage up from the basic material.
So with a COM antenna you would have a tear drop airfoil
shape about 8.5" long x 5.25 wide (approx give or take). Min
edge width or edge margin should be 1.5" from edge of
antenna foot print.  You don't necessarily need to attach to
a nearby stiffener or frame but depends on the skin thickness
and size of antenna.
What some do is make a local doubler with the nut plates
and than attach the doubler to the skin with just a few rivets.
That way you are not putting a bunch of small 3/32 rivets
for the nut plates into the structural skin. Just make sure
the screws have a ground path to the airframe with bare
metal or ground straps.
I suggest you put the COM antenna on the pilot side, just
forward of the spar. You can make access to the coax while
fairly well protected and out of the way. If you ever want to
attach a portable radio to it you just reach down and
remove the coax and attach a coax jumper from the antenna
to the handheld radio (emergency only). Just a suggestion or
idea. You can get fancy with panel splitters and so on but
this is simple and works. Just don't TX with the main radio
if the antenna is not connected of course.
Bottom line you want the whip part of the antenna to
bend or brake before wrinkling the skin.
Cheers George M, RV-4, RV-7
>From: "William Gill" <wgill10(at)comcast.net (wgill10(at)comcast.net)>
Comant antenna base and the fuselage skin - is the antenna
base grounded to the fuselage via themounting screws since
Get on board. [url=http://us.rd.yahoo.com/evt=42298/*http://advision.webevents.yahoo.com/handraisers]You're invited[/url] to try the new Yahoo! Mail Beta.
jmoreau2(at)cox.net
PostPosted: Tue Jul 25, 2006 8:21 am    Post subject: VHF antenna mounting Reply with quote
Thanks Bill
On Jul 24, 2006, at 11:11 PM, William Gill wrote:
Hello Jeff,
Bill
brian
PostPosted: Tue Jul 25, 2006 2:24 pm    Post subject: VHF antenna mounting Reply with quote
On Jul 25, 2006, at 9:15 AM, Hopperdhh(at)aol.com wrote:
Bill,
Good. When I worked at a radio shop many, many years ago I was taught
how to install antennas. The long and short of it was:
1. Always put in a doubler. Make it at least 4" (10cm) square if
possible but bigger is better. Rivet it in and liberally use zinc
chromate. (Remember, this was back in the early 1970's and we weren't
using two-part epoxy primers then.)
2. Don't use the cork gasket that comes with the antenna. They never
really seal well but they do a good job of keeping the moisture in
once it gets in and this tends to corrode things. Use a good sealant
instead. If the bushings are long enough that it creates a
significant gap use an aluminum spacer.
3. Where the antenna's mounting bushings contact the aircraft skin,
make sure the paint is removed to ensure a good electrical contact.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery
PostPosted: Tue Jul 25, 2006 5:55 pm    Post subject: VHF antenna mounting Reply with quote
Thank you ALL for the great info. Maybe I'll have a com radio going by
this weekend.
Bill
nuckollsr(at)cox.net
PostPosted: Tue Jul 25, 2006 7:44 pm    Post subject: VHF antenna mounting Reply with quote
this weekend.
Bill
rd2(at)evenlink.com
PostPosted: Wed Jul 26, 2006 4:43 am    Post subject: VHF antenna mounting Reply with quote
_____________________Original message __________________________
(received from Robert L. Nuckolls, III; Date: 10:36 PM
7/25/2006 -0500)
________________________________________________________________
----other inserts snipped-----
I published a mate-up sketch to the website a few months ago:
http://www.aeroelectric.com/Pictures/Antenna/Antenna_Installation.gif
The emphasis for "grounding" the base of the antenna to structure
needs to concentrate on the areas around fasteners where mate-up
pressures assure the "gas tight" condition. Removal of paint or
material surface protection any place else is a waste of time and
only exposes those surfaces to the ravages of atmosphere. All the
magic happens right around the screws and no place else.
Bob,
Speaking of the magic (grounding the base) - looking at the
Antenna_Installation.gif ,
I have seen toothed lock washers used between the doubler plate and skin.
This was on a Cessna. The doubler plate was not riveted to the skin (it
came with with the antenna replacement kit). The lock washer assured better
el contact (grounding). They used externally toothed lock washers, as per
attached. Maybe a better idea would be to use the external-internal toothed
type washers (also attached). Opinions?
Rumen
 Filesize:  3.12 KB
 Viewed:  9264 Time(s)
 Filesize:  3.71 KB
 Viewed:  9265 Time(s)
PostPosted: Wed Jul 26, 2006 8:35 am    Post subject: VHF antenna mounting Reply with quote
7/25/2006 -0500)
Bob,
We're really slice'n and dice'n mouse hairs here. Obviously
the goal is to get a low ohms connection between the antenna
base and the skin that is as good 10 years from now as it is
the day we bolt it on. This comes down to a few simple-ideas:
(1) pressure high enough to bring two clean surfaces into intimate
gas tight contact with each other and (2) exclusion of environmental
effects that include (a) contaminants and (b) loosening that work
against condition (1).
Some designers embrace the idea that the toothed lockwashers
provide a multitude of very high pressure points . . . even to
the point of upsetting metal at the points of contact to achieve
(1). My concerns are that a toothed washer is a spacer between
the two surfaces that may contribute to initial joint quality (1)
but leaves the gap "open" for ingress of (a).
In all of our bonding specs at RAC, the use of lockwashers is
never suggested. Self locking all metal nuts are the preferred
anti-loosening technology. In the sketch I published, 99% of the
magic needs to happen in the area just around the screw hole and
between skin and antenna base. All other "prepared" areas add
only marginally to the quality of the joint.
Obviously, the "99% conductivity area" is of very small gap and
the only thing one might add is sealant or anti-moisture guckum (Like
silocone grease) to fill the tiny void around the periphery
of the 99% area to prevent entry of oxidizing agents. Beyond
that, maintainance of pressure over time is enhanced by use
of largest practical hardware torqued to upper limits and
secured with some form of locking technology . . . all metal
locknuts being the technology of choice.
When we were selling contactors with treaded studs for fat wires,
the split-ring, steel washers supplied were discarded and replaced with
internal tooth, phosphor bronze lockwashers. The supplied steel
nuts were replaced with brass. Again, the lion's share of conductive
magic happens were the terminal comes down against the bottom nut.
The lockwasher and nut on top contributes to conductivity but
only a tiny fraction of the total.
Bob. . .
FLYaDIVE(at)aol.com
PostPosted: Wed Jul 26, 2006 8:37 am    Post subject: VHF antenna mounting Reply with quote
In a message dated 7/26/06 8:48:44 AM Eastern Daylight Time, rd2(at)evenlink.com
writes:
Rumen
Rumen:
By putting washers between the skin and the doubler you do not create a
doubler, the would-be doubler now becomes a spring and you also create individual
stress points at each screw. Their may also be some crazy RF issues; better to
do it like the book/manufactur says.
The idea of improving the ground contact is good but that can be done with a
clean surface, snug screw holes and star washers under the nuts.
The type of star washer you suggest is perfectly acceptable. Just not
between the skin and doubler.
Barry
"Chop'd Liver"
time."
Yamashiada
