mjurotich(at)hst.nasa.gov Guest
Posted: Mon Jul 24, 2006 9:01 am Post subject: Magneto P leads (DEAN PSIROPOULOS) |
At 02:56 AM 7/24/2006, you wrote:
| Quote: | *
Today's complete Engines-List Digest can also be found in either of the
of the Engines-List Digest and can be viewed with a generic text editor
HTML Version:
http://www.matronics.com/digest/engines-list/Digest.Engines-List.2006-07-23.html
Text Version:
http://www.matronics.com/digest/engines-list/Digest.Engines-List.2006-07-23.txt
Slick mags have tow teminals one is labeled ground. You need to only
strip about 3 inches (8 cm) of shield braid.
| Quote: | ================================================
Engines-List Digest Archive
Total Messages Posted Sun 07/23/06: 1
Today's Message Index:
1. 10:49 PM - Magneto P leads (DEAN PSIROPOULOS)
________________________________ Message
1 _____________________________________
Time: 10:49:15 PM PST US
From: "DEAN PSIROPOULOS" <dean.psiropoulos(at)verizon.net>
Subject: Magneto P leads
I'm wondering about connecting the P leads at the magneto. Looking at the
top of the (Slick) magneto, I removed the nut and star washer and found an
insulating fiber washer underneath. Looking under the washer, there is the
threaded stud which projects from a piece of white plastic that is in turn
surrounded by a shiny piece of metal that looks like a large nut. My
question has to do with grounding the P lead out on the magneto which is
recommended for lowest system noise. I assume that the fiber washer is
there to keep the P lead terminal from grounding the threaded stud to the
"shiny metal nut" that surrounds the plastic that the stud projects out of.
If so, can I use two ring terminals on the coax, one with a much larger ring
placed under the fiber washer which will serve as the return grounding path
and then place a smaller ring terminal (connected to the other wire in the
coax) on top of the fiber washer (which is on top of the larger ring
terminal contacting the shiny metal nut) under the nut that goes on the stud
and not have to worry about magneto grounding somewhere else on the engine?
I'm just trying to not have to strip a whole bunch of shield off the P lead
for grounding at a separate location and this looks like it should work but
I know nothing about magnetos so I'm not sure if my hypothesis is correct.
I hope you can decipher what I trying to say. Thanks.
Dean Psiropoulos
RV-6A N197DM
Stringing wire (still)
Matthew M. Jurotich
e-mail mail to: <mjurotich(at)hst.nasa.gov>
phone : 301-286-5919
| | - The Matronics Engines-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
http://www.matronics.com/Navigator?Engines-List |
