Big holes
Jaybannist(at)cs.com
PostPosted: Sun Jul 23, 2006 9:12 am    Post subject: Big holes Reply with quote
I've got another question for the learned group.  How do you get a 1 1/8" dia. hole in .090 aluminum?  This is for the torque tube bearings.  ZAC shows a "flat faced drill bit" but no suggestion as to where one might obtain one of these. I searched the internet to no avail.  I don't think a hole saw would make a smooth enough hole for a bearing.  I would be afraid to use a fly cutter.  Is it possible to get the desired results with a series of step drill bits (in a drill press)?
Jay in Dallas, working on XL fuselage
ding(at)tbscc.com
PostPosted: Sun Jul 23, 2006 9:55 am    Post subject: Big holes Reply with quote
Jay,
            My standard method is to drill undersize (1" in this case), and open bigger with a sanding drum in a drill. I first mark the desired perimeter and work out to the line. A hole saw can be used this way, but otherwise is not precision enough.
                                                        Lynn
                                                        Corry PA
                                                        601XL    tails & wings done
tonyplane(at)bellsouth.ne
PostPosted: Sun Jul 23, 2006 11:13 am    Post subject: Big Holes Reply with quote
 I used the Uni-Bits (great tools) for holes in sheet metal from about 5/16 inch (8mm)  up to I believe 1-1/4 inch dia.(30.5mm).  Any good hardware store has them.
Tony Graziano
601XL N493TG;  118 hrs and just finished first Annual Conditional Inspection
Big holes From:    Jaybannist(at)cs.com (Jaybannist(at)cs.com) Date:      [b]Sun Jul 23 - 10:12 AM[/b]
a drill press)?
rstone4(at)hot.rr.com
PostPosted: Sun Jul 23, 2006 11:13 am    Post subject: Big holes Reply with quote
 Jay,
      I had the same problem and did it with a fly cutter but not with the regular tool steel cutter.  I took an old file and ground it to look like a knife blade on one end the other end to fit into the cutter slot on the fly cutter.  Draw it down on the .090 sharp end first and apply pressure very slowly.  This will make the most clean cut you ever saw.  When you think you have the cutter adjusted to end up with a hole 1 & 1/8th, check by drawing the blade down on a piece of wood and check the diameter.  Aluminum is soft and much easier to work than any other metal I know of unless it has been alloyed with harder metals
Bob Stone, Harker Heights, Tx
Zodiac XL (Not too far along)
admin(at)arachnidrobotics
PostPosted: Sun Jul 23, 2006 11:20 am    Post subject: Big holes Reply with quote
    If you find that you still have problems making a clean hole, I have several extra Torque Tube Bearings for the XL.  I'd send you one if you wanted to pay shipping.  The 1.125 DIA hole on these was punched with a single punch of the correct size, so they look great.  Let me know off-list if you're interested.
raymondj(at)frontiernet.n
PostPosted: Sun Jul 23, 2006 7:53 pm    Post subject: Big holes Reply with quote
You might try a Forsner bit. Used in woodworking.
Raymond Julian
Kettle River, MN.
Corvair core acquired.
[quote] --
pacificpainting(at)comcas
PostPosted: Sun Jul 23, 2006 8:24 pm    Post subject: Big holes Reply with quote
Jay,
I have a set of Rotabroach sheet metal cutters. They are expensive but they work very well. They actually cut holes, not saw or drill them. Look up Rotabroach on your browser. I looked them up. They do come in the size you want, but I don't know how much they are.
Dave in Salem
801
grs-pms(at)comcast.net
PostPosted: Tue Jul 25, 2006 10:15 am    Post subject: Big holes Reply with quote
Jay:
The "flat-faced drill bit" probably refers to a flat wood boring bit, the kind with little spur projections on each side.  You should be able to find one at almost any hardware store.  Locally, I find them at Lowe's and Ace Hardware.  They work well in a drill press, or even with a handheld drill and they leave a clean hole.  Expect to pay about $3.00
George
PostPosted: Tue Jul 25, 2006 10:17 am    Post subject: Big holes Reply with quote
Thanks to all of you for your input on drilling large holes in .090 aluminum.  I finally sprung for a 1 1/4" step drill bit.  I drilled the torque tube bearing and got a beautiful hole, 3/32" off center!  So I fabricated another bearing and carefully drilled it.  Worked out great.
Thanks again - Jay in Dallas
PostPosted: Tue Jul 25, 2006 12:02 pm    Post subject: Big holes Reply with quote
     The tool you guys are talking about is called a "Spot Facer"  it is used to provide a flat surface just a little larger than the bolt or screw head when the part being fastened has a surface that is not at the same angle as the part it is being fastened to.  I have attached a drawing to help show what I am talking about.  If you are going to get one or a set of these remember the reason for the spot facing around the hole is not only so the bolt head will fit flat on the surface but so you can also get a socket on the bolt head when you are trying to tighten a nut on the other end.
 Filesize:  1.01 MB
 Viewed:  177 Time(s)
ggower_99(at)YAHOO.COM
PostPosted: Tue Jul 25, 2006 2:35 pm    Post subject: Big holes Reply with quote
This are the type of bit I use for making holes up to 1 1/4" diam.  (The biggest one I have from a bit kit).
Is better using a variable speed hand held drill,  just make low and even presure,  use a low speed where you feel confortable.  practice in a scrap piece.  put a piece of wood under the work.  Is easy and the results are great.
For the first ones I used our Bridgeport,  that was overkill  Smile
Saludos
Gary Gower
Do not archive.
George Swinford <grs-pms(at)comcast.net> wrote:[quote] Jay:
George
