Wing Root Seal - Help needed from Kit Builder
nfivesl(at)yahoo.com
PostPosted: Fri Jul 21, 2006 6:38 am    Post subject: Wing Root Seal - Help needed from Kit Builder Reply with quote
Good Morning:
If you are a kit builder of a 601XL, could you measure
the width of your wing-root seal rubber for me? I'm
about to order some and I want to make sure it is the
right width. An Aircraft Spruce or Wicks part number
would be ideal but if you can measure yours and give
me the width I can find it.
Thank you,
Scott Laughlin
www.cooknwithgas.com
Almost finished with Canopy
dvoverdt(at)HOTMAIL.COM
PostPosted: Fri Jul 21, 2006 2:52 pm    Post subject: Wing Root Seal - Help needed from Kit Builder Reply with quote
Hopefully the attached picture will help with the dimensions.
Josh
601XL Wings
 Filesize:  28.19 KB
 Viewed:  278 Time(s)
PostPosted: Fri Jul 21, 2006 4:46 pm    Post subject: Wing Root Seal - Help needed from Kit Builder Reply with quote
Thank you Josh. That is exactly what I needed. I
ordered the trim from ZAC and I'm glad I did since the
A/S stuff was different.
Thanks again,
Scott Laughlin
Still dreamin.
dimensions.
Josh
