Rick Galati
Joined: 10 Jan 2006 Posts: 91 Location: Lake St. Louis MO.
Posted: Tue Jul 18, 2006 8:40 am Post subject: X-C Tool Kit |
I am preparing an emergency tool kit to be carried on trips and seeking ideas on the most efficient tools (and spares) to stow on board. Naturally, I want the kit to be light yet as comprehensive as possible. While no emergency tool kit can cover every possible contingency, what do seasoned overnight X-country RV'ers among us find to be especially useful for common field repairs? For instance, rather than carrying a common pair of pliers as is supplied with my Axle Jack, I prefer to tote a small pair of vice grips as this tool seems to offer more utility for roughly the same amount of weight penalty. Ideas?
Rick Galati RV-6A "Darla" 153 hours
ronlee(at)pcisys.net Guest
Posted: Tue Jul 18, 2006 9:27 am Post subject: X-C Tool Kit |
Note that XC can be the airport 45 minutes away. So consider if a flat there
is worth carrying things or will you want someone to drive there to get you.
Main tire and tube
Nose tire and tube
Appropriate tools to get to main and nose tires to replace tube
Extra valve stem cores and long removal tool (from NAPA)
Extra gas cap
Assortment of screws, washers, etc
Appropriate tools to remove cowl and typical nuts/bolts
Duct tape
Tube repair kit
Tube inflation device (electric or manual)
There is more but this is a start.
Some have laughed at my carriage of these items on even local flights yet I
have
helped others on two or three occasions.
Ron Lee
michele.delsol(at)microsi Guest
Posted: Tue Jul 18, 2006 11:43 am Post subject: X-C Tool Kit |
Might be overkill but I've been considering adding a spare starter and
starter relay (I'll have a Skytech). As for the main contactor, I am
planning on having a contactor override just in case the main contactor
fails. Engine is a TMX-IO360 - I don't fancy hand proping it.
Michele
RV8 - Fuselage
dburton(at)nwlink.com Guest
Posted: Tue Jul 18, 2006 12:31 pm Post subject: X-C Tool Kit |
Dan Checkoway posted a real reasonable tool kit to carry on his website. It
might be a good place to start. I've had good luck getting help from pilots
on the field when I've had problems, but you can't count on it...
tedd(at)vansairforce.org Guest
Posted: Tue Jul 18, 2006 2:31 pm Post subject: X-C Tool Kit |
I maintain the tool kit for a formation group I fly with. Our kit is pretty
comprehensive (and heavy), but here are the items I've used most often this
year, roughly in order.
1. safety wire
2. #2 phillips screwdriver (a good multi-bit driver would be fine)
3. wrench sizes common for our airplanes (Navions) -- 3/8, 7/16, 1/2, & 9/6
4. needle-nose pliers; I also use safety wire pliers a lot (see item 1)
5. telescoping magnet (for retrieving dropped parts)
6. inspection mirror
7. right-angle ratcheting screwdriver (MAC tools -- incredibly useful)
8. bits for item 7 (can be combined with item 2)
9. multi-meter and cables
Tedd McHenry
Surrey, BC, Canada
