davyken(at)comcast.net Guest
Posted: Mon Jul 17, 2006 5:14 pm Post subject: Rotax Service Instruction SI-04-1997 |
How are other Rotax 912 owners complying with SI-04-1997? This is the Service Instruction that discusses venting of the lubrication system. As I understand it you need to plug the oil return line and apply 10 psi to the vent line and rotate the engine. What are you using for a plug? How are you connecting a source of regulated 10 psi air to the vent line?
<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
Ken Davy N1701S
Classic IV – Rotax 912
jimmieblackwell(at)sbcglo Guest
Posted: Mon Jul 17, 2006 5:34 pm Post subject: Rotax Service Instruction SI-04-1997 |
I have a detailed instruction for this procedure. As I recall it appeared in a magazine.
Can send you a copy if you like.
I use a piece of oil line about 4" long plugged on one end with a wooden dowel, then apply 10 psi of regulated air to the oil tank inlet with an attachment on my compressor used to blow up ballons and air mattresses.
Hope this helps.
Jimmie
davyken <davyken(at)comcast.net> wrote:
| Quote: | How are other Rotax 912 owners complying with SI-04-1997? This is the Service Instruction that discusses venting of the lubrication system. As I understand it you need to plug the oil return line and apply 10 psi to the vent line and rotate the engine. What are you using for a plug? How are you connecting a source of regulated 10 psi air to the vent line?
Ken Davy N1701S
Posted: Mon Jul 17, 2006 5:45 pm Post subject: Rotax Service Instruction SI-04-1997 |
Pardon me I said that wrong. Air is applied to the vent hose connection at the tank.
Jimmie Blackwell <jimmieblackwell(at)sbcglobal.net> wrote: | Quote: | I have a detailed instruction for this procedure. As I recall it appeared in a magazine.
Hope this helps.
Jimmie
Ken Davy N1701S
