dhkey(at)msn.com Guest
Posted: Mon Jul 17, 2006 10:10 am Post subject: Kolb Lexan Xtra Question |
There is one tube where two pieces of Lexan join(see attachment). Am I
supposed to put two rows of rivets on that tube or overlap the lexan. Was I
suppose to cut the windshield lexan with the front tabs in it and run it
down the sides in the front. If someone has a photo that would be great too.
63.07 KB |
519 Time(s) |
Craig.Nelson(at)heraeus.c Guest
Posted: Mon Jul 17, 2006 10:27 am Post subject: Kolb Lexan Xtra Question |
I riveted the windshield in place first. The side window I positioned
the top just under the edge of the windshield and the tube, riveting
only the front edge back edge and the bottom of the side window
Uncle craig
Jim Ballenger
Joined: 12 Jan 2006 Posts: 18 Location: Virginia Beach, Virginia
Posted: Mon Jul 17, 2006 12:00 pm Post subject: Re: Kolb Lexan Xtra Question |
I installed the side window temporary then overlapped the windshield and used one row of rivets to attach both to the tubing.
Jim
MK3X 582
Cat36Fly(at)aol.com Guest
Posted: Mon Jul 17, 2006 12:24 pm Post subject: Kolb Lexan Xtra Question |
I installed mine the same as Jim. One row of rivets.
Larry Tasker
Mklllx 582
Posted: Tue Jul 18, 2006 7:23 am Post subject: Kolb Lexan Xtra Question |
Thanks, I guess I'm going to go with overlapping the lexan. I'd like to see
photos of your xtras!!
