szakreski(at)shaw.ca Guest
Posted: Mon Jul 17, 2006 7:44 am Post subject: broken push rod suberu ea81 - a little more |
Thinking more about it and looking at the photos of the broken rod. Mine look a lot different from that in the photo, much thicker diameter. I recall Lance asking me to send him photos of my pushrods at one time, and him telling me I had the “new” version of NSI pushrod. The older version, probably the one Mike Harter had break on him, was the same diameter as mine but had a different machined transition at the end where it swages onto to factory end piece. There used to be photos on some website showing the difference.
SteveZ
Calgary
Sent: Monday, July 17, 2006 8:20 AM
To: 'kitfox-list(at)matronics.com'
Cc: Steve Zakreski
Subject: RE: broken push rod suberu ea81
Lance once told me they use the stock pushrod ends however they replace the actual rod with an aluminum rod.
SteveZ
Calgary
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of wingsdown
Sent: Friday, July 14, 2006 6:52 PM
I will be out to the airport on the 17th and would be most happy to do that.
Rick
