dreel(at)cox.net Guest
Posted: Sat Jul 15, 2006 12:53 pm Post subject: Tire marking material |
Has anyone found a material that will make a permanent mark on a tire
sidewall?
I've sprayed white auto body paint on mine a month ago and it has pretty
completely disappeared by now. My purpose is to easily move the airplane to
a point where the tire can be inflated without removing the wheel pants.
Dave Reel - RV8A
ronlee(at)pcisys.net Guest
Posted: Sat Jul 15, 2006 1:55 pm Post subject: Tire marking material |
At 02:53 PM 7/15/2006, you wrote:
sidewall?
Yellow or white tire marking crayons are good enough.
Ron Lee
T.gummo(at)verizon.net Guest
Posted: Sat Jul 15, 2006 4:27 pm Post subject: Tire marking material |
I found a touch up pen at a auto parts store. It has yellow paint in it.
It seems to stay on my tires with no problems.
Tom Gummo
Apple Valley, CA
Harmon Rocket-II
http://mysite.verizon.net/t.gummo/index.html
jhstarn(at)verizon.net Guest
Posted: Sat Jul 15, 2006 7:37 pm Post subject: Tire marking material |
The pen Tom refers to is the one that Pick A Part, Pick Ur Part ETC. use to
identify items. Ours came from the local NAPA auto parts store, not plain
touch up but more on the line of "Marks a Lot" 'cause it only wears off if
ya'll git on your fingers. It has a ball bearing in it to help with mixing.
Make sure to depress the wick end when you think it's out of paint. I think
the brand name is "Paint Stik". 8*) KABONG Do Not Archive
chaztuna(at)adelphia.net Guest
Posted: Sun Jul 16, 2006 5:45 am Post subject: Tire marking material |
Listers,
The item mentioned below is commonly called a metal marking pen. I purchased mine from my local MSC store. They sell them in white, yellow, blue and red. I've found that the yellow is the most useful. See
http://www1.mscdirect.com/CGI/NNPDFF?PMPAGE=2618&PMITEM=07519317&PMCTLG=00
Charlie Kuss
[quote]--> RV-List message posted by: "JOHN STARN" <jhstarn(at)verizon.net>
The pen Tom refers to is the one that Pick A Part, Pick Ur Part ETC. use to identify items. Ours came from the local NAPA auto parts store, not plain touch up but more on the line of "Marks a Lot" 'cause it only wears off if ya'll git on your fingers. It has a ball bearing in it to help with mixing. Make sure to depress the wick end when you think it's out of paint. I think the brand name is "Paint Stik". 8*) KABONG Do Not Archive
Vanremog(at)aol.com Guest
Posted: Sun Jul 16, 2006 7:48 am Post subject: Tire marking material |
In a message dated 7/15/2006 1:54:27 P.M. Pacific Daylight Time, dreel(at)cox.net writes:
| Quote: | Has anyone found a material that will make a permanent mark on a tire
sidewall? |
I used the white-out correction fluid for making ink corrections to documents. It worked well enough and was free from work.
GV (RV-6A N1GV O-360-A1A, C/S, Flying 801hrs, Silicon Valley, CA)
czechsix(at)juno.com Guest
Posted: Sun Jul 16, 2006 8:45 pm Post subject: Tire marking material |
Dave,
Before putting my wheel pants on I marked each tire with a dot using
yellow torque seal. I just smeared it around a bit to work it into the
rubber....if you were to put a three-dimensional glob of it on the tire
sidewall (the way you normally use the stuff for its intended
application) I'm sure it would break right off, but so far after 67 hours
the marks still show clearly. Easy to do and doesn't require a seperate
purchase if you've already got some laying around the hangar....
--Mark Navratil
Cedar Rapids, Iowa
RV-8A N2D flying and grinning like an idiot....
sidewall?
to
Dave Reel - RV8A
Posted: Sun Jul 16, 2006 9:50 pm Post subject: Tire marking material |
The liquid paper & torque seal I would think would dry, become brittle &
flake off. 280hrs on the Paint Stik & we only need to re-do then we rotate
tires or add new ones. Yes, you can still see the marks on the inside of the
tires after rotating them but they may no longer line up as near as we can
tell, never wasted the time to check. Low tire, sidewall flexing, heat, cold
"strong" landings nor time seem to adversely affect the Paint Stik's
performance. Do Not Archive, think the price was about 3-4 dollars 6 years
ago, still using that original one. If you close to APV come by the hanger &
I'll mark your tires for FREE. KABONG
seiders(at)bellsouth.net Guest
Posted: Mon Jul 17, 2006 4:45 am Post subject: Tire marking material |
Are my tires the only ones that move on the rims rendering the paint marks
useless?
At 09:44 AM 7/16/2006, you wrote:
[quote]Listers,
Charlie Kuss
Posted: Mon Jul 17, 2006 5:43 am Post subject: Tire marking material |
Richard Seiders wrote:
marks useless?
I your tires are truly rotating on the rims, I'd be more worried about
sheared valve stems than marking the tires. The problem is usually the
opposite: The SOBs act like they're glued to the rims when you go to
change them out. Even though I liberally apply talc to the rims during
assembly, the tires/rims never come apart easily.
Linn
