n1cxo320(at)salidaco.com Guest
Posted: Sun Jul 16, 2006 12:11 pm Post subject: Lightspeed Electronic Igntion Probelm - SOLVED |
Thanks for all your suggestions - most of them were about on the mark. After replacing all plugs and re-timing (2nd time) I began ohm meter work and something "funny" was found at one transformer....after unwrapping some electrical tape I found the inside insulating material on the coaxial cable from the electronics box to the input side of one transformer has shrunk back far enough that the inside conductor was shorted to the braid. (probably from engine heat) So, naturally, the input to the transformer was 'gone.' A temporary repair confired all is well. I will just replace the entire coax cable upon my return from OSH (am driving to test out my new "Cubby" teardrop camper this year.)
Again, thanks folks for your help. You don't relaize how close to the actural problem many of you were. Thanks again.
John at Salida, CO
