CrownLJ(at)verizon.net Guest
Posted: Sat Jul 15, 2006 4:49 am Post subject: Fly without turtle deck |
"maybe it will fly nice with the turtle deck back on the ground. "
I would definitely NOT recommend this. I had a small panel maybe 12"x12" blow out of turtle deck and the resulting drag/ lost of lift was very noticeable. I think that if you removed the deck completely, if would cause a huge loss of lift, and / or be a huge "bucket" catching wind off the top of the cockpit. In any case, when my small panel departed, I need much more power and still lost airspeed. It happened during a steep sideslip with one door open and the other closed. The air pressure from that slip was enough to "pop" the Velcro loose and the panel departed. (Not a problem with both doors open.) The airplane was still flyable, but it eliminated my thoughts of flying without the deck on.
Larry
