Malcolmbru(at)aol.com Guest
Posted: Sun Jul 16, 2006 6:02 pm Post subject: NEWS FLASH (SLSA) (ELSA) MALCOLM |
--- sportaviation(at)kc.rr.com <sportaviation(at)kc.rr.com>
wrote:
| Quote: | NEWS FLASH!
FAA RELEASES ORDER 8130.2F CHANGE 2
During the second week in July, FAA released Change
2 to FAA Order 8130.2F,
| Quote: | which specifies the requirements and procedures for
DARs and FAA inspectors
| Quote: | to use when certificating aircraft, including
experimental light-sport
| Quote: | (ELSA) and special light-sport (SLSA). This
revision made some very
| Quote: | beneficial changes for ELSA operating limitations
and other significant
| Quote: | changes for SLSA.
With the new revision, which is now effective, ELSAs
will have additional
| Quote: | flight privileges previously available only to
experimental amateur-built
| Quote: | (EAB) aircraft, including flight over densely
populated areas, in congested
| Quote: | areas, and over open-air assemblies of persons.
Additionally, night and IFR
| Quote: | flight will be allowed if the aircraft is properly
equipped.
If you own an ELSA certificated before last week,
you would be well advised
| Quote: | to request a revision to your operating limitations
and airworthiness
| Quote: | certificate. Just contact the FAA inspector or DAR
who certificated your
| Quote: | aircraft; in all likelihood, he/she will be able to
issue the revisions
| Quote: | without having to make another inspection visit.
The biggest change for SLSA is that DARs are now
allowed to issue the
| Quote: | production flight test permit by telegraphic means
or FAX. Thus, the DAR
| Quote: | will have to make only one visit to the
manufacturer's, agent's, or dealer's
| Quote: | facility instead of two that were often required
with the previous revision.
For a summary of all the changes contained in the
new Order, please visit
| Quote: | this page of our website. If you have any
questions, we also welcome phone
