kingjohne(at)adelphia.net Guest
Posted: Wed Jul 12, 2006 6:55 am Post subject: RG Battery |
Has anyone obtained an RG type battery that can fit inside the standard Kitfox battery box of the type provided by SkyStar? If so I would like to know the make and model . My current Series 6/912S battery has a 16 amp-hour and 240 cranking amps ratings.
| Quote: | --
John King
Warrenton, VA
n10pg(at)neo.rr.com Guest
Posted: Wed Jul 12, 2006 11:52 am Post subject: RG Battery |
Hello John:
Have you tried Bill Bainbridge at B& C Specialty Products in Newton KS (316) 283-8000 (http://www.bandcspecialty.com). Say hello for me.
Peter Graichen
[url=http:/home.neo.rr.com/n10pg/kitfox.htm]http:/home.neo.rr.com/n10pg/kitfox.htm[/url]
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com] On Behalf Of John King
Sent: Wednesday, 12 July, 2006 10:54
To: Kitfox List
Subject: RG Battery
| Quote: | --
John King
Warrenton, VA
jdmcbean(at)cableone.net Guest
Posted: Wed Jul 12, 2006 5:26 pm Post subject: RG Battery |
John,
We have a sealed battery that fits into an un-modified Kitfox battery box.. Been using it for the last 3 years…
<![if !supportEmptyParas]> <![endif]>
AUTOTEXTLIST \s "E-mail Signature" <![endif]-->Fly Safe !!
John & Debra McBean
208.337.5111
www.kitfoxaircraft.com
"The Sky is not the Limit... It's a Playground"
<![endif]--><![if !supportEmptyParas]> <![endif]>
-----Original Message-----
From: owner-kitfox-list-server(at)matronics.com [mailto:owner-kitfox-list-server(at)matronics.com]On Behalf Of John King
Sent: Wednesday, July 12, 2006 8:54 AM
To: Kitfox List
Subject: RG Battery
Has anyone obtained an RG type battery that can fit inside the standard Kitfox battery box of the type provided by SkyStar? If so I would like to know the make and model . My current Series 6/912S battery has a 16 amp-hour and 240 cranking amps ratings. <![if !supportLineBreakNewLine]> <![endif]> | Quote: | | -- John King Warrenton, VA |
Posted: Wed Jul 12, 2006 6:38 pm Post subject: RG Battery |
John,
Is it a Recombinant Gas (RG) battery? I prefer that to a jell cell type or a sealed lead acid battery. If so what is the Amp Hour and Cold Cranking Amps ratings.?
| Quote: | --
John King
Warrenton, VA |
jdmcbean wrote: | Quote: | <![endif]--> 0 DocumentEmail <![endif]--> <![endif]--> <![endif]-->
John,
John & Debra McBean
208.337.5111
<![endif]-->
From: owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com) [mailto:owner-kitfox-list-server(at)matronics.com (owner-kitfox-list-server(at)matronics.com)]On Behalf Of John King
To: Kitfox List
Subject: Kitfox-List: RG Battery
Has anyone obtained an RG type battery that can fit inside the standard Kitfox battery box of the type provided by SkyStar? If so I would like to know the make and model . My current Series 6/912S battery has a 16 amp-hour and 240 cranking amps ratings. | Quote: | | -- John King Warrenton, VA |
Mark.Napier(at)sciatl.com Guest
Posted: Thu Jul 13, 2006 7:15 am Post subject: RG Battery |
I didn't like the mounting of the battery box in my KF III so I axed it
and built up one from aluminum angle. Took a little while but it is
very light and goes in the same place. The Odyssey PC-625 now occupies
that place on the firewall and it is very reliable.
After walking off for lunch and somehow leaving my master switch and
Wheeling strobes on for 2 hours (duhh!) there was still enough juice
left to crank the engine. Incredible!
- - - - - Appended by Scientific Atlanta, a Cisco company - - - - - This e-mail and any attachments may contain information which is confidential, proprietary, privileged or otherwise protected by law. The information is solely intended for the named addressee (or a person responsible for delivering it to the addressee). If you are not the intended recipient of this message, you are not authorized to read, print, retain, copy or disseminate this message or any part of it. If you have received this e-mail in error, please notify the sender immediately by return e-mail and delete it from your computer.
