JohnT(at)comp-sol.com Guest
Posted: Fri Jul 14, 2006 7:16 am Post subject: Mic audio ground - PMA8000B |
Say - on the PMA7000, 8000 or GMA340 audio panels...none of them have a
dedicated return (ground) for the Mic Gnd (used on SL30/40 & GNS480). I
would assume the 'dedicated' returns are all connected together
internally - and are there for ease of install - i.e. to pin 10,11.....
Anyone have some advice as to what to hook up the Mic Gnd to on a
PMA8000 series audio panel?
Say - I noticed that the PMA7000 vs the PMA8000 and GMA340 have opposite
convention on the tip and middle tip of the audio plugs - for L/R use.
Obviously the input tip/middle tips are changed as well - so pass thru
is just fine.
Is there actually a convention used? - just curious....
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Fri Jul 14, 2006 10:28 am Post subject: Mic audio ground - PMA8000B |
On Jul 14, 2006, at 11:11 AM, John Tvedte wrote:
Insulate the mic jack from the airframe. Return the shell to the
ground at the audio panel. All your mic inputs will return to this
same common ground at the audio panel.
Do not return your mic grounds to the single-point power ground at
the firewall.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
