Warpdrive Torque settings
hurstkr(at)growzone.com.a
PostPosted: Mon Jul 10, 2006 4:03 am    Post subject: Warpdrive Torque settings Reply with quote
Hi , i can't seem to find the torque settings for the bolts on the warp
drive propellor & prop flange anywhere in the manual ,does anyone have any
figures?, thanks, #573 steve vestuti.
Steve,
The torque settings for the Warp Drive propeller are specified in the
instructions accompanying the propeller. Since the instructions for
assembling the propeller are quite detailed, I think you would be wise to
get Warp Drive to send you a copy if you don't have them. There are two
lots of torque settings dependent on which bolts are being used, 1/4" or
5/16" Also beware, the two hub halves have mating marks. To reiterate, I
think you would be wise to get yourself a copy of the instructions if you
can't find them.
Kingsley in Oz
