PHCarter(at)aol.com Guest
Posted: Thu Jul 06, 2006 7:28 pm Post subject: Yak 52 Intercomm |
The volume of the radio and intercom in the rear cockpit has gotten too low to hear in flight. The volume of the front cockpit for both radio and intercom is just fine and adjusts well in both volume and squelch. I don't think it is the rear headset, but still doing test to make sure. Are there any adjustments or classic problems with the intercom that anyone can tell me about?
Preston, N6209F
dsavarese(at)elmore.rr.co Guest
Posted: Fri Jul 07, 2006 3:35 am Post subject: Yak 52 Intercomm |
Be sure that both toggle switches in both cockpits are in the down position. Then adjust the volume controls for both the intercom and VHF fully clockwise. If you are using an active noise canceling headset in the rear cockpit, remove it and try using two passive headsets in the front and rear of the same type if possible, and see if that makes a difference.
Dennis
fwblack7(at)yahoo.com Guest
Posted: Fri Jul 07, 2006 4:41 am Post subject: Yak 52 Intercomm |
Do you have the original radio? I have the same problem you've described, but have been told by several different radio people that there is an impedence issue between the Russian equip. and American. I'm using a Garmin GPS Com. in the front.
PHCarter(at)aol.com wrote: | Quote: | The volume of the radio and intercom in the rear cockpit has gotten too low to hear in flight. The volume of the front cockpit for both radio and intercom is just fine and adjusts well in both volume and squelch. I don't think it is the rear headset, but still doing test to make sure. Are there any adjustments or classic problems with the intercom that anyone can tell me about?
Preston, N6209F
Check 6!
Talk is cheap. Use Yahoo! Messenger to make PC-to-Phone calls. Great rates starting at 1˘/min.
duncan1574(at)execpc.com Guest
Posted: Fri Jul 07, 2006 10:56 am Post subject: Yak 52 Intercomm |
Having been in the backseat of a 52 for many hours there is a set of volume controls for just the backseat, also there are two channels for the intercom (toggle switches) that should both in the same position in the front and back. DeBear, Did I miss anything? Russ Russ
Posted: Fri Jul 07, 2006 2:41 pm Post subject: Yak 52 Intercomm |
Yes, that is correct. There IS an impedance issue that affects audio levels as does some of the active noise canceling headsets.
Dennis
