brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Tue Jul 04, 2006 7:00 am Post subject: Alternator failure thoughts |
There has been a lot of heat of late in the great alternator debate
(GAB). I thought I would throw in some thoughts and experience I have
had.
I have seen a number of alternator failures on cars, boats, and
airplanes. Some were pretty simple, no-brainer failures and some were
"HOLY S--T" failures. I thought I would toss in here the ways I can
see alternators failing (and have failed) and then address the failures.
Here are the failure modes I have see so far (feel free to add to
this list):
1. Straight electrical failures:
a. regulator failed -- no output
b. brushes failed -- no output
c. output diode failure -- whine and reduced output
d. diode trio failure -- no output
e. regulator failed -- runaway output (destroys battery and anything
else attached to the bus)
2. Mechanical failures:
a. bearing failure -- armature chews up stator -- no output
b. broken mounting brackets -- no output
c. broken wires, usually field -- no output
3. Miscellaneous failures:
a. burned up stator -- overload -- no output
First thing to think about is what to do when the alternator fails.
If you are on this list it probably means you are building your
electrical system with an eye toward safely completing the flight
with the lights still burning in the panel. I have come to the
conclusion that alternator failure is something that demands a
landing ASAP. Why? Because I have experienced too many failed-bearing
failures. The alternator stops producing output so you tend to think
in terms of electrical failure and just keep on going. I wonder what
would happen if the bearing were to fail so completely that the
armature would jam against the stator or one of the bell housings.
Instant stoppage. Nothing good is going to come from that much mass
stopping suddenly. I can certainly imagine mounting ears and mounting
brackets snapping and bits of alternator taking the grand tour of
your cowling.
So, I hold that an alternator failure should require a "let's land
and check it out now" response unless you can tell for sure it is an
electrical-only failure. And I don't know of a good way to tell if it
is an electrical-only failure.
Now as to causes, some have come up with vibration as a potential
source of failure. I agree. Lycoming engines are not particularly
smooth (but can be made a lot smoother by balancing, matching
mixtures in all the cylinders, and doing a dynamic prop balance). I
see extra-beefy mounting hardware as a plus here. The other form of
imbalance is the armature rotating balance. If the armature is
balanced the instantaneous vibrational loads on the bearings will be
a LOT less. I would expect this to result in reduced incidence of
mechanical failure of alternator bearings.
Heat is another killer. Insufficient cooling can result in burned
stator windings and/or failure of the lubricant in the bearings
leading to bearing failure. It seems to me that ensuring excellent
cooling is very important too. Many alternators have external or
internal fans but since most alternators are mounted on the hot side
of the baffling the fan just circulates hot air through the
alternator. The alternator really needs its own source of cool air
from before it passes through the cylinders. I would probably try to
find a source of cooling air that won't be as likely to contain water
if you run through the rain. I can't imagine that circulating water
through the alternator is likely to improve its longevity.
Hopefully this will spark some discussion about installation
practices that may improve alternator longevity over and above
anything we can do electrically.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
paulm(at)olypen.com Guest
Posted: Tue Jul 04, 2006 8:17 am Post subject: Alternator failure thoughts |
Good post.
I would add I have had an alternator on a Excavator suddenly lock up due to
a bearing seize and it was on the opposite end from the belt. It was a
sealed ball bearing and the result was a burned up belt 2300 hours on the
unit. A different failure than the too tight belt bearing damage often seen.
I also agree immediate landing is called for.
Paul
chaztuna(at)adelphia.net Guest
Posted: Tue Jul 04, 2006 9:32 am Post subject: Alternator failure thoughts |
| Quote: | snipped
this list):
else attached to the bus) | snipped
Brian,
I'd like to expand on item C of the list above
Output diodes comprise the rectifier. (converts AC current to DC) For the purposes of the alternators we use, the rectifier is comprised of 6 diodes. These diodes can fail in two modes, open or short. Failing open (diode blows apart) is the more common failure mode. In this mode, each diode that fails will reduce the alternator's output by 1/6th.
Diodes that fail shorted are more insidious. Often, the pilot will not notice a decrease in performance. However, he/she will generally notice an increase in noise (generally on the radios) This is because 1/6th of the alternator's output is now bleeding through as AC current. The ship's electrical system is designed for DC current. The one item which really can not tolerate AC current is the battery. Any time an alternator fails, it is best to do a postmortem, to determine the cause.
Shorted rectifier diodes which are not repaired promptly, will soon destroy the battery's storage capacity. This damage to the battery may not be noticed, without conducting a battery output test. This is important if you subscribe to Bob N's ideas regarding battery only emergency operations.
Charlie Kuss
Dale Ensing
Posted: Tue Jul 04, 2006 10:05 am Post subject: Alternator failure thoughts |
Charlie,
Does the reduce output show as lower voltage and/or reduced maximum amps?
Dale Ensing
_________________ Dale Ensing
RV-6A
Aero Plantation
Weddington NC |
Posted: Tue Jul 04, 2006 11:20 am Post subject: Alternator failure thoughts |
At 02:02 PM 7/4/2006, you wrote:
| Quote: | Output diodes comprise the rectifier. (converts AC current to DC) For the purposes of the alternators we use, the rectifier is comprised of 6 diodes. These diodes can fail in two modes, open or short. Failing open (diode blows apart) is the more common failure mode. In this mode, each diode that fails will reduce the alternator's output by 1/6th.
Charlie,Does the reduce output show as lower voltage and/or reduced maximum amps?
Dale Ensing |
Dale,
The reduced output can show itself as both a reduction in voltage and amperage. If the load on the electrical system is below the crippled alternator's ability to produce power, you may not notice any difference. Generally though, reduced charging voltage will be noticed first. This is why Bob N says that a good voltmeter is more important to have than an ammeter.
An analogy could be made to an aircraft's ability to climb. An aircraft can only climb as long as the engine can produce power in excess of what is needed to maintain level flight at a given altitude.
An alternator's ability to increase the system voltage (assuming we had no voltage regulator to stop a voltage climb) is limited by it's ability to produce current (amps) in excess of the load on the system.
Charlie Kuss
klehman(at)albedo.net Guest
Posted: Tue Jul 04, 2006 12:55 pm Post subject: Alternator failure thoughts |
We've discussed rotation speed a number of times but I still used larger
pulleys to keep the speed more in line with what my alternators would
see in their oem application. Automotive demonstrated reliability means
nothing to me when we run a component faster, hotter, at higher load, or
in a tight cowl, compared to an automotive engine compartment. Bearings
generally run cooler and last longer at slower speeds and vibration
loads are lower. I also like short dedicated belts that don't flop
around as much as long belts driving several accessories that have to be
fairly tight. I don't trust any alternator bracket that is less than
about 3/16" steel or 1/8" if truly 3 way triangulated. I hadn't really
considered it necessary to land soon following a alternator failure as
while I've discovered poor bearings during the electrical repair
(usually not on the pulley end), I've never had a bearing as the direct
cause of the failure -- yet Maybe time to rethink a bit!
Ken
Brian Lloyd wrote:
<brian-yak(at)lloyd.com>
had.
this list):
anything else attached to the bus)
your cowling.
brian
Posted: Tue Jul 04, 2006 1:06 pm Post subject: Alternator failure thoughts |
On Jul 4, 2006, at 1:07 PM, Charlie Kuss wrote:
| Quote: | > c. output diode failure -- whine and reduced output
Brian,
Actually, I am pretty sure it is still 1/3 of the output. (Warning:
technical BS follows.) Each diode is part of a full-wave bridge for
two of the three phases. Therefore when one diode opens you lose a
half-wave of output from two of the three phases. Since there are six
half-wave outputs, two from each of the three phases, you still lose
1/3 of your potential output.
And then there is the whole root mean square (RMS) thing. Without
doing the math I am going to guess that the loss of one diode (open)
is going to reduce the available power (amps probably) by 1/3. Ripple
will also be up substantially.
| Quote: | Diodes that fail shorted are more insidious. Often, the pilot will
Well, actually it is not. With one diode shorted it will show up as a
dead short on two of the phases for half a wave. The current from the
affected phases will go through the good diode but return to the
winding through the shorted diode so two of the phases will see a
short through one diode drop. So for half a wave two of the phases
will be producing maximum current and dissipating it in the
resistance of those two stator windings. To the outside world it will
look like and ope diode (I think -- I am guessing here) but I suspect
that the affected phases of the stator will very quickly burn
themselves up unless the alternator has superb cooling.
| Quote: | The ship's electrical system is designed for DC current. The one
I understand your logic Charlie but, as I indicated above, I don't
think it will work the way you have outlined.
But this was just an off-the-top-of-my-head analysis and very will
could be wrong.
brian
Posted: Tue Jul 04, 2006 1:30 pm Post subject: Alternator failure thoughts |
> Charlie,
> maximum amps?
> Dale Ensing
Dale,
and amperage.
The peak voltage available will remain the same as each winding of
the stator is capable of that peak voltage. But the ripple will be up
and the available current will be down. With one diode gone (open) I
would bet that a 60A alternator becomes a 40A alternator. If one
diode shorts the alternator becomes a 40A alternator and then shortly
thereafter a 20A alternator as two of the windings in the stator burn
out.
| Quote: | If the load on the electrical system is below the crippled
difference.
I agree with that but you will start to hear one heck of an
alternator whine.
| Quote: | Generally though, reduced charging voltage will be noticed first.
But the VR is going to increase the field current to keep the voltage
where it is supposed to be. As long as you are drawing less than 1/3
of the alternator's rated output you won't notice anything but the
whine. What will be reduced is the charging current.
| Quote: | An analogy could be made to an aircraft's ability to climb. An
system.
True.
Posted: Tue Jul 04, 2006 2:56 pm Post subject: Alternator failure thoughts |
| Quote: | | Quote: | | Quote: | snippedDoes the reduce output show as lower voltage and/or reduced
maximum amps?
Dale Ensing |
Dale,
and amperage. |
out.
difference. |
alternator whine.
have than an ammeter. |
system. |
True.
Brian Lloyd 361 Catterline Way |
Brian,
We both agree that voltage drop is caused by the alternator's inability to produce enough current (amps) to meet system demands. What I was trying to express, is that it would be more likely for the pilot (Dale) to notice a drop in voltage first. This is why Bob N recommends a low voltage warning system. When alternator output drops below what is being consumed by the ship's systems, voltage will always sag.
Charlie
| Quote: | On Jul 4, 2006, at 1:07 PM, Charlie Kuss wrote:
| Quote: | | Quote: | c. output diode failure -- whine and reduced output
Brian,
alternator's output by 1/6th. |
1/3 of your potential output. |
Brian,
Your suggestion of a 33% loss of output is closer to real world losses. I have tested charging systems which showed a 20 to 35% loss of output. Tear down of the alternator later for repair showed that one diode had failed in the rectifier.
| Quote: | And then there is the whole root mean square (RMS) thing. Without
themselves up unless the alternator has superb cooling. |
I've tested alternators which would meet the output spec (for a limited time) Then one (or more) of the rectifier diodes would overheat and short. My point here is that not all failures are "hard" failures. When diagnosing a charging system you can't always rely on what "theory" says should happen.
| Quote: | | Quote: | The ship's electrical system is designed for DC current. The one
battery only emergency operations. |
could be wrong.
My experience here is anecdotal, as it simply relates to what I've seen in my experiences.
Charlie
Posted: Tue Jul 04, 2006 3:14 pm Post subject: Alternator failure thoughts |
At 05:08 PM 7/4/2006, you wrote:
| Quote: | --> AeroElectric-List message posted by: Brian Lloyd <brian-yak(at)lloyd.com>
maximum amps?
Dale Ensing |
Dale,
snippedIf the load on the electrical system is below the crippled
difference. |
alternator whine. |
In most situations you are correct. Unfortunately, the absence of whine doesn't mean that everything is rosy. Like they say, one test is worth a thousand expert opinions. Another is: Test, don't guess.
snipped
Charlie
brian
Posted: Tue Jul 04, 2006 6:24 pm Post subject: Alternator failure thoughts |
On Jul 4, 2006, at 6:55 PM, Charlie Kuss wrote:
Brian,
will always sag.
Very true. But until you reach the point where the alternator can't
carry the load, system voltage will appear normal.
You know, Bob used to sell a loadmeter/voltmeter that had the ability
to measure field voltage (voltage across the field windings which is
proportional to field current). What would be apparent is a sudden
increase in field voltage for the same RPM and load. Another
advantage of externally regulated alternators.
brian
On Jul 4, 2006, at 6:47 PM, Charlie Kuss wrote:
Ah, you are telling me that the difference between theory and
practice in practice is greater than the difference between theory
and practice in theory? OK, I agree with that.
| Quote: | > I understand your logic Charlie but, as I indicated above, I don't
> could be wrong.
Ah, real-life trumps theory. Yeah, I can go with that too.
FLYaDIVE(at)aol.com Guest
Posted: Wed Jul 05, 2006 3:09 am Post subject: Alternator failure thoughts |
In a message dated 7/4/2006 9:25:44 PM Eastern Standard Time, chaztuna(at)adelphia.net writes:
| Quote: | For the purposes of the alternators we use, the rectifier is
Charlie, |
Charlie:
Why 6 diodes? Half wave rectification only requires 2 diodes. And Full wave reverification only requires 4 diodes. So why 6 and how are they hooked up?
Barry
"Chop'd Liver"
Posted: Wed Jul 05, 2006 3:22 am Post subject: Alternator failure thoughts |
| Quote: | Why 6 diodes? Half wave rectification only requires 2 diodes. And
they hooked up?
Barry
"Chop'd Liver"
Hi Barry,
Those alternators are 3 phase.
Gilles Thesee
Grenoble, France
http://contrails.free.fr
brian
Posted: Wed Jul 05, 2006 4:37 am Post subject: Alternator failure thoughts |
On Jul 5, 2006, at 6:57 AM, FLYaDIVE(at)aol.com wrote:
| Quote: | In a message dated 7/4/2006 9:25:44 PM Eastern Standard Time,
Charlie,
Charlie:
For a single winding, half-wave rectification only needs one diode.
| Quote: | And Full wave reverification only requires 4 diodes. So why 6 and
It would be possible to write a whole dissertation on this subject.
The alternator is three phase. There are three windings in the stator
of the alternator. Each one by itself produces a full AC wave but
each one has its phase starting 120 degrees after the phase of the
previous winding. Imagine a sine wave starting at zero, rising to a
positive peak at 90 degrees, crossing zero again at 180 degrees,
rising (falling?) to a negative peak at 270 degrees, and then coming
back to zero at 360 degrees to start the whole cycle over again. Now
imagine that the next winding starts its wave at zero just as the
waveform from the first winding is on its downward slope between 90
and 180 degrees. Do this again for the third winding. (This stuff is
hard to describe in words without pictures.)
If you think of how a full-wave bridge rectifier is connected to a
single winding (as in a transformer) You see that each leg of the
transformer has two diodes connected to it -- one going from ground
to the winding and another going from the winding to output. So each
leg of the transformer requires two diodes, one to conduct the
positive half of the cycle to the positive output and the other to
connect the negative half of the cycle to ground.
Since we have a three-phase device we have three windings, not just
one. It turns out that you can save diodes by hooking the three
windings together so you end up with only three leads total. They are
hooked up in either delta configuration or wye ('Y') configuration.
Here, let me try to draw a picture. The letter 'W' will denote a
winding and 'T' will denote a connection terminal:
Delta:
T
W W
T---W---T
Wye:
T
W
t
W W
T T
(The center-tap terminal in the wye configuration is often not used
so I made it a small 't'.)
Most alternators are wired in wye configuration. Each of the three
main terminals gets two diodes, one each for the positive and
negative half-cycle of the waveform available at that terminal.
BTW, if your alternator has a 'stator' terminal (the Delco
alternators do) it is usually the center-tap terminal. On boats the
AC at this terminal is used to drive the tachometer. The frequency is
proportional to engine speed. Having your tach drop to zero while the
engine is running is a good indication you have lost your alternator.
(This is how I usually find out I have burned up another stator.)
BTW, if you are wondering about how you can 'short' all the windings
together in the delta configuration without hurting anything you will
find that the voltage at the free ends of any two windings connected
together (vector sum) will be equal and opposite in phase to the
voltage on the other winding so no current will flow.
Barry
"Chop'd Liver"
pwmac(at)sisna.com Guest
Posted: Wed Jul 05, 2006 6:29 am Post subject: Alternator failure thoughts |
Its interesting about the number of diodes used
in alternators. The Ford alternator used in
recent vehicles has 8 diodes and a regulator
bolted to the back of the case. I have not been
able to determine if the field wire is externally
accessible. Anyhow, the 95130/160/200amp versions
of the 3G alternator are physically pretty big
for a plane. A schematic and other details can be
found at:
http://fullsizebronco.com/forum/showthread.php?t=55169&highlight=alternator
I would appreciate an explanation of for all the diodes.
The guy who sells the upgraded alternators also
sells various pulleys if anybody has interest.
His link is buried in the above site.
Regards, Paul
At 06:35 AM 7/5/2006, you wrote:
>Charlie,
>Charlie:
Delta:
T
W W
T---W---T
Wye:
T
W
t
W W
T T
>Barry
>"Chop'd Liver"
Jim Baker
Posted: Wed Jul 05, 2006 7:13 am Post subject: Alternator failure thoughts |
| Quote: | Its interesting about the number of diodes used
Recall seeing an article that said Mercedes or BMW (forget
which) uses 12......
Jim Baker
580.788.2779
Elmore City, OK
jonlaury(at)impulse.net Guest
Posted: Wed Jul 05, 2006 8:32 am Post subject: Alternator failure thoughts |
I'm not flying yet, but my 60 A ND ER alternator (of undetermined auto application) has been modified by removing the stamped steel vented rear cover and replacing it with a fiberglass closed cover with a stub to accept a blast tube to force air over the diode plate, as an attempt to compensate for a backward turning alt fan. Aside from buying a B&C or Plane Power unit, is there a better way? Is this likely to have a positive effect?
John
frank.hinde(at)hp.com Guest
Posted: Wed Jul 05, 2006 9:11 am Post subject: Alternator failure thoughts |
Not sure i understand this "backwards turning" deal. Frome what i can see the internal fan alternators appear to have simply radial fan blades that simply throw air out thru the sides of the alt. Therby presumably sucking air in from both front and back.
Adding a cool air supply to the regulator should therefore augment the existing fan. I am thinking of doing a similar thing by riveting something similar to the stamped rear cover of my Autozone Toyota Camry special.
Cetainly couldn't hurt
Frank
From: owner-aeroelectric-list-server(at)matronics.com [mailto:owner-aeroelectric-list-server(at)matronics.com] On Behalf Of John Burnaby
Sent: Wednesday, July 05, 2006 8:55 AM
Subject: Re: AeroElectric-List: Alternator failure thoughts
John
