chasb(at)satx.rr.com Guest
Posted: Thu Jul 06, 2006 1:06 am Post subject: Alternator Belt |
A recent post regarding alternator abuse mentioned using an
automotive belt on the alternator rather than an aircraft belt.
That's the first I ever heard regarding an "aircraft alternator
belt." I always thought a V- belt is a V-belt.
The belt furnished with my B&C 60 Amp alternator was too short. I
replaced it with a belt from an auto parts store. Seems to work okay.
Am I asking for trouble?
Charlie Brame
RV-6A N11CB
San Antonio
Ed Anderson
Posted: Thu Jul 06, 2006 3:03 am Post subject: Alternator Belt |
Charlie, I've found that good quality auto V belts like made by GATES give
no problem. However, I have had some poor experience with lesser quality
brands. I only use GATES belts myself.
Ed
Ed Anderson
Rv-6A N494BW Rotary Powered
Matthews, NC
eanderson(at)carolina.rr.com
http://members.cox.net/rogersda/rotary/configs.htm#N494BW
_________________ Ed Anderson
Matthews, NC
eanderson@carolina.rr.com |
lhelming(at)sigecom.net Guest
Posted: Thu Jul 06, 2006 3:37 am Post subject: Alternator Belt |
No problem. Just be sure you got a good one. Vans aircraft recommends using
a Yates belt. I would not use a no name special, Stick with a strong
brand name and premium grade. Larry in Indiana
nuckollsr(at)cox.net Guest
Posted: Thu Jul 06, 2006 5:15 am Post subject: Alternator Belt |
At 03:59 AM 7/6/2006 -0500, you wrote:
There's no such thing as an "aircraft alternator belt". There
are thousands of belts by hundreds of manufacturers and they
range in SERVICE LIFE from mediocre to the best-we-know how
to do.
There may be folks who are on a par with GATES for the
manufacture of belts but I'm not personally familiar with
who they might be. Perhaps folks on the list who work in
that venue can offer some insight as to alternative brands.
| Quote: | Am I asking for trouble?
Not if you've crafted your architecture and pilot's mind-set
for failure tolerant operation. Broken belts are but one of
many reasons an alternator might decided to quit. If you're
prepared to deal with an alternator failure on your own terms,
then no, you're not asking for trouble. But you may decided to
'upgrade' a belt because you're tired of replacing it. See
chapter 17 in the 'Connection.
I've seen airplanes at fly-ins where the owner has installed
a 'spare' belt over the prop shaft and secured it. This would
allow a failed belt to be replaced in the field without
pulling the prop. Given the extra-ordinary stress that a
belt gets when driving a small-pulley alternator such as
the B&C, it's probably money well spent to get the best.
Give B&C a call and ask about their experience with Gates
belts (that's the brand that probably came with your alternator).
< What is so wonderful about scientific truth...is that >
< the authority which determines whether there can be >
< debate or not does not reside in some fraternity of >
< scientists; nor is it divine. The authority rests >
< with experiment. >
< --Lawrence M. Krauss >
chaztuna(at)adelphia.net Guest
Posted: Thu Jul 06, 2006 5:42 am Post subject: Alternator Belt |
| Quote: | snipped
to do.
snipped
Bob . . . |
Listers,
I will second the recommendation of Gates belts. On a par with Gates is the OEM belt supplier for most Japanese cars. The manufacturer is Bando. In the past year, I've found Bando belts easily available from the after-market. I have only found one "off brand" belt which compares to these two. The brand name is Force One. It comes in a black and white cardboard sheath. My local parts supplier carries this brand and I'm impressed with the quality. On the other hand, I would not use a Dayco brand belt on a go kart!
Charlie Kuss
FLYaDIVE(at)aol.com Guest
Posted: Thu Jul 06, 2006 6:56 am Post subject: Alternator Belt |
In a message dated 7/6/06 9:17:59 AM Eastern Daylight Time, nuckollsr(at)cox.net
writes:
| Quote: | There's no such thing as an "aircraft alternator belt". There
to do.
Don't tell that to the FAA!
Here are the part numbers:
ALT BELT: 37A19773-37 <--- FAA Approved and with an FAA - PMA stamp. This
is the Gates Automotive equivalent: (gates belt 3V375).
Now, as I have stated before, there are quality differences. I have noted
that when it comes to Original Timing Belts and Serpentine Belts. The FACTORY
ORIGINAL is of much better quality than OEM or Auto Store items. See my long
post with explanation ... It should be in the archives.
Barry
"Chop'd Liver"
rv9jim(at)juno.com Guest
Posted: Thu Jul 06, 2006 9:27 am Post subject: Alternator Belt |
Charlie,
I sell V-Belts for a living and other assorted sundry for
industrial items like bearings. There is two styles of "V" belts. one
configuration is "industrial" and the other is "automotive". The
difference is in the angle that makes the v-belt. The automotive is a
narrow "V" and the industrial "V" is a wider angle "V".. Industrial
belts are designated by their size. The first letter or number usually
designates the top width. Such as A-35 belt. This is a 1/2" wide belt
that is 35" in circumference on the inside. A 4L370 is physically the
same just a light duty "A" series. (don't ask !!) Think of the "L"
meaning light duty. There is a series called "3V or 3VX that is almost
the exact match to the belts used on aircraft engines. I will bring
home a 3vx belt and check it out on my engine. That should put the
confusion and sources to rest.
Jim Nelson
Posted: Thu Jul 06, 2006 10:31 am Post subject: Alternator Belt |
James,
I am aware of the industrial Gates belts. I've also seen Gates heavy duty belts referred to as Green Stripe. Are the Green Stripe Gates brand belts the same as the industrial quality units? I often see these used in heavy machinery or in medium and heavy duty trucks. Your recommendation to use the industrial quality belts is well founded.
However, for the pilot who is AOG due to a broken belt, he may not be able to find an industrial supplier close by the airport or open (weekends ya' know). That means he has to resort to an auto or farm supply store. He still has a chance of getting a good quality belt, if he knows what to ask for.
Thanks for adding to this discussion.
Charlie Kuss
---- James H Nelson <rv9jim(at)juno.com> wrote:
Charlie,
Jim Nelson
willslau(at)alumni.rice.e Guest
Posted: Thu Jul 06, 2006 2:18 pm Post subject: Alternator Belt |
The Green Stripe belt was/is a "premium" automotive version. I have no specs
on how premium it is, but back in the day it was the preferred belt for
racing Corvairs, where the belt had to go over two idler pulleys, making the
trip from the horizontal crankshaft pulley, then turning 90 degrees to drive
the cooling fan mounted on a vertical axis, then back down another 90 degree
turn to rejoin the crankshft pulley. As you can imagine, this setup on a
6000+ rpm motor was quite a workout for the belt. Generic belts wouldn't
last a day, but the Green Stripe belts gave good service.
William Slaughter
Kellym
Posted: Thu Jul 06, 2006 9:34 pm Post subject: Alternator Belt |
I know some Piper owners have received belt from Piper dealer in a Gates
sleeve, with the Gates number on the belt, and the Piper number hand
written in silver pen on the belt. I don't know for sure that it was an
automotive number, but believe that is correct. 9335XL Green Stripe or
9335HD. Piper number 73965-015 formerly #452-541
James H Nelson wrote:
Charlie,
Jim Nelson
KCHD |
Posted: Thu Jul 06, 2006 10:54 pm Post subject: Alternator Belt |
writes:
to do.
Barry
"Chop'd Liver"
