europa(at)triton.net Guest
Posted: Wed Jul 05, 2006 6:41 pm Post subject: Charging System |
I’m having difficulty trouble shooting a charging system problem. The install is a Rotax 914 in an Europa XS. Besides the Rotax alternator, I have a B&C L60 alternator driven off the crankshaft and a B&C LR3C regulator. The electrical system is basically AeroElectric Z-13. I have recently completed the 50 hour inspection of the airframe and engine. There were no problems found with the charging system and the battery (Panasonic LC-X1220P 20 aH) is only 18 mos old with 50 hours of use. It passed a capacity test with the same result as when new.
The aircraft is equipped with 3 ammeters - one on the battery positive and one on each alternator output. What I observed during flight and subsequent testing today is that the battery ammeter shows -3 amps (a 3 amp discharge) all the time, regardless of load - ie turning on pitot heat doesn’t change the value - it’s still a 3 amp discharge. Data from flights prior to the maintenance showed 0 amps at this spot as expected. The problem is present with either alternator on line and both of them operate correctly, proven by loading heavily (pitot heat) and noting the amp output.
Any suggestions on where to look? Might there be a problem with this battery where it can’t accept a charge properly? The bus voltage runs 14.1 - 14.2 volts which is what B&C recommends.
Jim Butcher
Europa XS N241BW
brian
Joined: 02 Jan 2006 Posts: 643 Location: Sacramento, California, USA
Posted: Thu Jul 06, 2006 5:53 am Post subject: Charging System |
On Jul 5, 2006, at 10:40 PM, Jim Butcher wrote:
Quote: | The aircraft is equipped with 3 ammeters - one on the battery
If the bus voltage is 14.1 then the battery is charging. There is no
question about that. I would suspect the metering circuit.
Do you really have three ammeters or three shunts switched to one
ammeter? It sounds to me like you might have inadvertently switched
two of the leads to your shunt switch. (Presuming one ammeter).
Another possibility is that if you have hall-effect sensors the zero
setting on the one for the battery has become misadjusted.
Brian Lloyd 361 Catterline Way
brian-yak AT lloyd DOT com Folsom, CA 95630
— Antoine de Saint-Exupéry
_________________ Brian Lloyd
brian-yak at lloyd dot com
- Antoine de Saint-Exupery |
