pj.ladd(at)btinternet.com Guest
Posted: Tue Jul 04, 2006 7:28 am Post subject: derigging. |
Hi All,
after a week of good weather during which I have kept the Xtra pegged down on my field the forecast has turned to heavy rain and thunder storms.
Consequently i have had to fold up the Xtra and stow her away in the barn because I have not sold my Challenger yet and my hangar is occupied..
Does anyone have an bright ideas for inserting the pins in the tubes which support the wings when folded. The first one is reasonably easy but with both wings folded it is alsmost impossible to reach the second fitting.
Obviously I can fix a rod of some sort to the pin so that I can reach past the rudder but has anyone any other ideas?
Cheers
Pat
Dave Pelletier
Joined: 10 Jan 2006 Posts: 100 Location: Prescott, Arizona
Posted: Tue Jul 04, 2006 10:19 am Post subject: derigging. |
_________________ AzDave |
Posted: Tue Jul 04, 2006 10:58 am Post subject: derigging. |
painted just a bit of white around it >>
Great idea. Thanks
Cheers
Pat
e.bayliss(at)blueyonder.c Guest
Posted: Tue Jul 04, 2006 11:43 am Post subject: derigging. |
Pat
On my mk111 one of the wing pins is a small diameter bolt (to fit easily) welded to form a T shape on the end of a length of light tube this can then be put into place from the rear after the wing has been slipped onto its mounting I then tie the free end up to the frame I have that keeps the tail feathers up together to take any strain away from the wing mount in the boom
Eddie Bayliss
Liverpool
UK
David.Lehman
Joined: 10 Jan 2006 Posts: 265 Location: "Lovely" Fresno CA
Posted: Tue Jul 04, 2006 11:59 am Post subject: derigging. |
Speaking of wing pins... I was having a heck of a time lining up the wing supports into the fuselage tube every time I folded the wings... I went to the hardware store and bought a couple of the plastic screws used to hold the toilet seats to the toilet (quit laughing), they fit the ID of the wing supports perfectly, I then pliabonded (contact cement) the screws into the supports... Now the curved head of the plastic screw slides into the fuselage tube with ease...
DVD
ô¿ô "Attitude is everything ~ pick a good one"...
_________________ ô¿ô
"Both optimists and pessimists contribute to the society. The optimist invents the aeroplane, the pessimist the parachute."
--- George Bernard Shaw |
Possum
Posted: Wed Jul 05, 2006 9:15 pm Post subject: derigging. |
I have a depth perception problem (only one eye)
AzDave |
And they let you fly a plane??
91.82 KB |
335 Time(s) |
Dave Pelletier
Possum
Posted: Thu Jul 06, 2006 12:02 pm Post subject: derigging. |
At 02:50 PM 7/6/2006, you wrote:
| Quote: | | Quote: | | I have a depth perception problem (only one eye) | And they let you fly a plane?? [img]cid:7.0.0.16.0.20060706155946.01cb69b8(at)mindspring.com.0[/img]
Of course, and drive a car too. The airlines don't advertise it, but there are some airline pilots with just one eye.
AzDave
Me too.
Russ Kinne
Posted: Thu Jul 06, 2006 2:37 pm Post subject: derigging. |
ATP's with one eye? No problem. I'v e seen some with two heads!do not archive
On Jul 6, 2006, at 2:50 PM, Dave & Eve Pelletier wrote:
| Quote: | | Quote: | | I have a depth perception problem (only one eye) AzDave | And they let you fly a plane??
AzDave
a58r(at)verizon.net Guest
Posted: Thu Jul 06, 2006 3:13 pm Post subject: derigging. |
And Wiley Post, famous pilot, round-the-world flyer, had only one
eye. John Hauck, two eyes, flew right up to the very spot where Post
and his famed passenger, humorist Will Rogers, fatally crashed at Pt
Barrow Alaska, 1935. That makes this Kolb-attuned.
regards,
Bob N.
