q
Russ Kinne
PostPosted: Mon Jul 03, 2006 4:27 pm    Post subject: q Reply with quote
Matt
Thank you SO MUCH! -- for taking "Max Stafford" off the list, but I
think he'll re-surface as someone else. I also think he's the same
guy as "jetpilot", Michael E. Bigelow" and "orcabonita". And now
he'll likely try to take me apart somehow. Hey, go ahead, I've
survived better people than him trying it.
And the FCC does have some most serious teeth, which he may yet feel --
Anyway, thanx for your efforts.
Russ Kinne
Max Stanford
PostPosted: Mon Jul 03, 2006 7:31 pm    Post subject: Re: q Reply with quote
Russ Kinne
You are very mistaken to say that I was taken off the list… This response here on the list proves you wrong. You are also very mistaken to think that I am here as someone else. I am here to stay, so get used to it.
I also remember Matt promising to ban anyone that started this stuff again on the list, I got banned and did my time out. Now you have started this again without so much as a word from myself. Matt, when you read this, I ask that you apply the rules fairly and ban Russ Kinne as you did me. I should be able to come to the list without having to read repeated personal attacks by Russ and a couple others.
Max
Site Admin
PostPosted: Mon Jul 03, 2006 7:47 pm    Post subject: q Reply with quote
Okay, guys. Let's just drop this right now. My ban last time came when I specifically said that I did not want to see anymore discussion regarding a particular topic thread. Max subsequently posted a very inappropriate follow up message and was banned for the requisite 5-day period.
Here's the warning. I suggest that everyone drop this thread now and get back to Kolb-specific discussions. Anymore mud flinging, and someone's going to end up in List jail again. I don't really care who.
End this now.
Matronics Email List Admin.
At 08:31 PM 7/3/2006 Monday, you wrote:
Russ Kinne
Max
http://forums.matronics.com/viewtopic.php?p=44664#44664
dhkey(at)msn.com
PostPosted: Tue Jul 04, 2006 5:36 am    Post subject: q Reply with quote
Hey Max, What kind of Kolb do you have? Can you post a photo for me? I'd
like to see your workmanship? Have you met anyone on the list yet? I'd like
to meet you, it sounds like you know a lot about the Kolbs and I could
probably pick up some building tips from you. I'm working on an Xtra and I
was wondering if I can put the transponder antenna next to the pitot tube or
if you think there's a better place to put it.
David
Reply-To: kolb-list(at)matronics.com
Subject: Re: q
Date: Mon, 3 Jul 2006 20:31:57 -0700
Russ Kinne
Max
Cat36Fly(at)AOL.COM
PostPosted: Tue Jul 04, 2006 6:36 am    Post subject: q Reply with quote
David,
Have you considered putting the antenna in the belly between the gear?
I put X-ponder and VHF there, one on each side and according to Dover AFB approach they both work fine (they see me and hear me).
Larry Tasker
MKlll x 582/warp
N615RT
dhkey(at)msn.com
PostPosted: Tue Jul 04, 2006 7:22 am    Post subject: q Reply with quote
I didn't want to go through the fabric because I've already painted it... I
didn't want to penetrate the fabric if I don't have to. Drilling the boom
tube is out of the question. So I thought drilling through the fiberglass
would be better but I was afraid that the pitot tube would mess up the
antenna reception or transmission. I checked the Acceptable Methods book
AC43.13B, in 12-20a it talks about transponders. It says that special
consideration must be given to pulse equipment such as DME and weather radar
but it doesn't mention anything about pitot tubes.
I had a book on the considerations of antenna mounting but I can't find it
now, figures...
Subject: Re: Re: q
Date: Tue, 4 Jul 2006 10:34:57 EDT
David,
Larry Tasker
MKlll x 582/warp
N615RT
Richard Pike
PostPosted: Tue Jul 04, 2006 9:04 am    Post subject: q Reply with quote
Back when I built my MKIII, I was still working at TRI ATCT, and had
opportunity to get one of the AF techs to look at the underside of the
airplane. The primary goal is to keep your antenna as far from other
metal parts that extend away from the surface as possible. So I cut a
sort of triangle shaped slab of thin aluminum for a ground plane, and
slid it around and under the left side of the main tube behind the cross
member that ties the main gear together. I had predrilled the hole for
the antenna, so once I knew it would fit, all I had to do was slather it
down with polytak and cram it against the inside of the fabric.
Here is a picture of where it is:
http://www.bcchapel.org/pages/0003/pg9.htm
Sort of evenly spaced between the gear and a bit behind them. Works good.
If you don't have the hoop skid under the nose, a good place would be
right at the back of the nose fairing, but if the hoop is still there,
then that would not be so good. Stick an aluminum plate in there
somewhere for a ground plane.
Richard Pike
MKIII N420P (420ldPoops)
it... I didn't want to penetrate the fabric if I don't have to.
Drilling the boom tube is out of the question. So I thought drilling
through the fiberglass would be better but I was afraid that the pitot
tube would mess up the antenna reception or transmission. I checked
the Acceptable Methods book AC43.13B, in 12-20a it talks about
transponders. It says that special consideration must be given to
pulse equipment such as DME and weather radar but it doesn't mention
find it now, figures...
> From: Cat36Fly(at)aol.com
> Subject: Re: Re: q
> David,
> AFB
> Larry Tasker
> MKlll x 582/warp
> N615RT
http://wiki.matronics.com
Richard Pike
Kolb MKIII N420P (420ldPoops)
Kingsport, TN 3TN0
dhkey(at)msn.com
PostPosted: Tue Jul 04, 2006 11:24 am    Post subject: q Reply with quote
I see your pitot there too. I did make a ground plane for it but didn't have
the forsight to make a hole in the fabric. I guess I will put it under the
nose near the pitot, if that dosen't work well I'll move the pitot to the
strut or something.
THANKS
Subject: Re: Re: q
Date: Tue, 04 Jul 2006 13:01:13 -0400
airplane. The primary goal is to keep your antenna as far from other metal
parts that extend away from the surface as possible. So I cut a sort of
triangle shaped slab of thin aluminum for a ground plane, and slid it
around and under the left side of the main tube behind the cross member
that ties the main gear together. I had predrilled the hole for the
antenna, so once I knew it would fit, all I had to do was slather it down
If you don't have the hoop skid under the nose, a good place would be right
at the back of the nose fairing, but if the hoop is still there, then that
would not be so good. Stick an aluminum plate in there somewhere for a
ground plane.
Richard Pike
>I didn't want to penetrate the fabric if I don't have to. Drilling the
>boom tube is out of the question. So I thought drilling through the
>fiberglass would be better but I was afraid that the pitot tube would mess
>up the antenna reception or transmission. I checked the Acceptable Methods
>book AC43.13B, in 12-20a it talks about transponders. It says that special
>radar but it doesn't mention anything about pitot tubes.
>now, figures...
>>Subject: Re: Re: q
>>David,
>>Larry Tasker
>>MKlll x 582/warp
>>N615RT
>http://www.matronics.com/Navigator?Kolb-List
Dave Pelletier
PostPosted: Wed Jul 05, 2006 7:38 am    Post subject: q Reply with quote
AzDave
dhkey(at)msn.com
PostPosted: Wed Jul 05, 2006 9:29 am    Post subject: q Reply with quote
it must of been all that time spent covering, brushing, sanding, painting
silver, wet sanding, painting more silver, wet sanding, painting white,
sanding, masking off, painting red, scuffing, masking off, painting blue and
uncovering. If I didn't touch fabric again for the next three lifetimes that
would be ok with me.
I did put many drain holes along the wings and tail with a soldering iron. I
could do that again.
Thanks for the tip.
[quote]From: "Dave & Eve Pelletier" <pelletier(at)cableone.net>
To: <kolb-list(at)matronics.com>
Subject: Re: Re: q
Date: Wed, 5 Jul 2006 08:34:00 -0700
slyck(at)frontiernet.net
PostPosted: Wed Jul 05, 2006 10:10 am    Post subject: q Reply with quote
For small holes the soldering iron works well.
-if you want a larger hole, glue (GOOP is a good sub for polytack)
a washer of plastic or thin metal on the inside first, then cut the
hole.
Some fabric and sewing stores carry plastic washers.
You can seal the joined edge with a smear of GOOP or clear nail
polish.
-BB
JetPilot
PostPosted: Thu Jul 06, 2006 9:55 am    Post subject: Re: q Reply with quote
Hi Russ,
We had our disagreements and pissing match on the list months ago, but shortly afterwards you took the time to email me and send me some really good advice about trim tabs on my MK-III. I figure anyone that can get over a disagreement on the list to help a fellow Kolber out has got to be a pretty descent guy. I am not going to get drawn into the current dispute with Max. And even though I am not thrilled about you linking my name with Max, I am not going to “ take you apart “. I appreciate the good advice you sent, it helped me make an important building decision and that’s what this list is really all about.
Michael A. Bigelow
Kolb MK-III Xtra, 912-S
