mounting strobe power supply in RV-6/6A
sarg314(at)comcast.net
PostPosted: Sun Jul 02, 2006 6:33 am    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
I have the Whelen strobe power supply to run 3 strobes ( HDACF). It's
got a mounting plate that is about 6" square. It weighs 2 Lbs. I want
to mount it just behind the baggage bulkhead some where. First idea, to
simply mount it to the belly skin was rejected. The skin's not braced
enough.
Putting a shelf of some sort from the central rib to the side skin
seems like too large a run and gets in the way of accessing the elevator
bell crank unless youplace it rather far aft. I'd like to keep it as
far forward as possible.
I could make a mounting "shelf" attached vertically to the aft side of
the skin that screws to the baggage bulkhead, down low the lower
corner. Problem there is you'd have to remove or diconnect the thing
everytime you removed the skin. It's an easy installation, though,
since you can work on the bench instead of int he plane.
Another idea is to mount it oriented vertically on the side of the
fuse, up high. One bracket attached to the bulkhead itself, the other
to the skin. The skin's flat there. A piece of 1/16 angle 7" long
rivetted vertically between the 2 J strips would be plenty solid and I
think the skin is strong enough there.
The baggage floor is rivetted down so that closes off some possibilities.
If any one has some ideas or photos on a web site, I would be very
appreciative.
Tom Sargent, RV-6A
kboatright1(at)comcast.ne
PostPosted: Sun Jul 02, 2006 6:55 am    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
Obviously not a direct answer to your question, but why not mount it between
the battery box and the fuel selector? Make a little shelf between two of
the floor stringers and put it on the shelf. This is also a good location
for your ELT, oxygen bottle, or fire extinguisher.
KB
bobbyhester(at)charter.ne
PostPosted: Sun Jul 02, 2006 7:16 am    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
Here's what I did, I had it on my web site at one time but have since removed some of the older stuff:
[img]cid:part1.06070105.05090509(at)charter.net[/img]
I ran conduits under my baggage floors to run wires.
My new email address: bobbyhester(at)charter.net (bobbyhester(at)charter.net)
Surfing the Web from Hopkinsville, KY
Visit my web site at: http://www.geocities.com/hester-hoptown/RVSite/
RV7A N857BH SB wings-QB Fuse-XPO360 engine Smile
sarg314 wrote:
--> RV-List message posted by: sarg314 <sarg314(at)comcast.net> (sarg314(at)comcast.net)
I have the Whelen strobe power supply to run 3 strobes ( HDACF).  It's got a mounting plate that is about 6" square. It weighs 2 Lbs.  I want to mount it just behind the baggage bulkhead some where.  First idea, to simply mount it to the belly skin was rejected.  The skin's not braced enough.
Putting a shelf of some sort  from the central rib to the side skin seems like too large a run and gets in the way of accessing the elevator bell crank unless youplace it rather far aft.  I'd like to keep it as far forward as possible.
I could make a mounting "shelf" attached vertically to the aft side of the skin that screws to the baggage bulkhead, down low the lower corner.  Problem there is you'd have to remove or diconnect the thing everytime you removed the skin.  It's an easy installation, though, since you can work on the bench instead of int he plane.
Another  idea is to mount it oriented vertically on the side of the fuse,  up high.  One bracket attached to the bulkhead itself, the other to the skin.  The skin's flat there.  A piece of 1/16 angle 7" long rivetted vertically between the 2 J strips would be plenty solid and I think the skin is strong enough there.
If any one has some ideas or photos on a web site, I would be very appreciative.
Tom Sargent, RV-6A
http://wiki.matronics.com
 Filesize:  37.51 KB
 Viewed:  655 Time(s)
rvsixer(at)juno.com
PostPosted: Sun Jul 02, 2006 7:29 am    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
Tom,
I used screws instead of rivets to fasten down my right side baggage
floor. I added two stiffeners to the floor panel between the ribs and
mounted the power supply upside below the baggage floor. Whelen said it can
be mounted any direction and cooling was not a factor. Also, I have no
strobe noise in the headsets, even with the comm antenna on the belly under
the seats.
Mike Hilger
RV-6 N207AM 760 hrs
Kyle:
Yes, that's a good location, functionally, but likely to get
kicked. I'd want to make some sort of cover for it (there's 5000v in
one of those wires). Besides, I plan on putting the fire extinguisher
there. Also, the wires from the strobe supply have to end up on the aft
side of the wing spar, so it's convenient if they start out on the aft
side of the wing spar to begin with. That ay only the power & ground
wires cross the spar.
between the battery box and the fuel selector? Make a little shelf
between two of the floor stringers and put it on the shelf. This is
also a good location for your ELT, oxygen bottle, or fire extinguisher.
KB
bill(at)vondane.com
PostPosted: Sun Jul 02, 2006 7:33 am    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
I would caution you on putting your strobe power supply in a location near
to anything that may leak fuel... Strobe power supplies send very high
voltage to the strobe heads and it would make for a very bad day if for some
reason your fuel selector should happen to leak on the connections to the
strobe heads...
Just an FYI...
-Bill VonDane
RV-8A ~ N8WV
Colorado Springs, CO
www.rv8a.com
Rick Galati
PostPosted: Sun Jul 02, 2006 10:06 am    Post subject: Re: mounting strobe power supply in RV-6/6A Reply with quote
Tom,
My RV sports two Whelen power supplies, and I mounted a unit to each outboard wing rib. In your case, perhaps it is advantageous to mount your single unit to the right wing given that side is usually built a bit lighter than the left wing if your landing light and pitot installation is located on the left wing. The photo illustrates my installation technique on the right wing. As shown, the wing tip rests atop the wing showing the internally mounted VOR antenna bolted inside the tip.
http://img373.imageshack.us/img373/2518/img0004457xa.jpg
Rick Galati RV-6A "Darla" 145 hours
enough.
appreciative.
Tom Sargent, RV-6A
dbris200(at)sbcglobal.net
PostPosted: Sun Jul 02, 2006 2:31 pm    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
Tom,
I mounted mine to the bottom rear of the baggage bulkhead and it's never been a problem. Removing it is as simple as disconnecting a few plugs. It was the simplest and lightest way to mount it and I'd do it the same way again.
Dave
Tom Sargent, RV-6A
denis.walsh(at)comcast.ne
PostPosted: Sun Jul 02, 2006 3:58 pm    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
Mine went on the aft side of the baggage bulkhead, slightly left of
center and just below the seam between the two halves of the
bulkhead . It has worked well. Now that I have done many
inspections, mods and maintenance I would recommend putting it on the
top half bulkhead. Reason being that I have not had the need to
remove that one in the last several years. There fore I would not
have to unplug the power wires each time I take off the bulkhead for
inspections etc.
I also like Bobby Hester picture, since that belly skin is an oil
canner and those rails should stiffen them up a bit!
Denis Walsh
possibilities.
appreciative.
Tom Sargent, RV-6A
www.matronics.com/Navigator?RV-List
wiki.matronics.com
bicyclop(at)pacbell.net
PostPosted: Sun Jul 02, 2006 5:01 pm    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
Hmmm, I don't think that will help with oil canning. It looks as if the rails are suspended on each end at the bulkheads and not in contact with the skin. I bought another rib from Van's - the one that the elevator bellcrank is mounted to (sorry I don't have the part # at my fingertips) and fit it parallel to the existing one and made a sort of avionics deck.
Things wound up crowded and I mounted on the side of it. That black thing at the aft end is a remote compass sensor which I’ll probably end up not using.
Pax,
Ed Holyoke
Denis Walsh
 Filesize:  30.84 KB
 Viewed:  585 Time(s)
sheldonb(at)frontiernet.n
PostPosted: Mon Jul 03, 2006 4:02 am    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
Ed, Just some information for you... I have the AK-450 ELT as you do... The mount for the mounting strap broke (at around 300 hours)... Not sure why, but might be from unhooking it and re hooking at battery change times or from viberation... you might think of beefing this up... for if it came loose back there... not good...!
Sheldon RV6A 400 hrs
 Filesize:  30.84 KB
 Viewed:  533 Time(s)
PostPosted: Mon Jul 03, 2006 8:18 am    Post subject: mounting strobe power supply in RV-6/6A Reply with quote
Sheldon,
Thanks for the heads up. This airplane isn’t flying yet, but I’ll make sure to put a line in my inspection checklist to give it special attention when it does.
Pax,
Ed Holyoke
