Michael Valentine
Posted: Sun Jan 15, 2006 2:29 pm Post subject: XL PLans / Assembly Guide Question Elevator Trim Tab Install |
On 1/15/06, Larry Whitlow <ldwhitlow(at)comcast.net> wrote:
Quote: | The assembly guide explains how to position the servo and drill the holes to
rivet the servo to the underside of the top skin but something seems amiss
Larry -
I recently experienced the same thing. I called the factory
(afterwards) to ask if I had done something wrong and they said it was
fine. He said that the real goal of the cutout is not to work on the
servo or even inspect the connection, but just to get it inside.
Although that seems a bit silly to me - why not just shift the hole a
bit so that you can do both - I was reassured that I had done it
correctly.
Obviously if you change your mind and decide to move the inspection
plate, I would get it signed off by the factory. Otherwise, you are
seeing it correctly and that is just the way it is!
Good luck,
Michael Valentine
601XL - tail/ailerons/flaps complete - working on wing.
