Aircraft Fuel Flow Indicator
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List
Pable Mackenzie
PostPosted: Mon Dec 01, 2014 2:16 am    Post subject: Aircraft Fuel Flow Indicator Reply with quote
Hi,Dear Friend,
I like to share my knowlege with you and want to gain more if you are have same interest related Aircraft's Spare Parts
Modern passenger jets not only have sophisticated edm 700 engine monitor systems, they go a step further and transmit accumulated data (via satellite feed ) at regular intervals to ground stations that have been setup and monitored by the engine manufacturers.
This helps engine manufacturers make appropriate notations and pay special attention to under-performing engine parts during the next maintenance overhaul or, they may even recommend an early overhaul.
The Aircraft fuel flow indicator in a modern jet also sends critical performance related information to the aircraft flight recorder (black box). In the unfortunate event of a crash, such information plays a big hand in helping determine the cause of the crash.
If you knew more about this or want to know about other related parts, please feel free to write me.
For More information Visit:https://www.jpinstruments.com/product-category/fuel-flow-instruments/
Best Regards
Pable Mackenzie
- The Matronics Engines-List Email Forum -
http://www.matronics.com/Navigator?Engines-List
 Filesize:  14.37 KB
 Viewed:  4988 Time(s)
 Filesize:  47.66 KB
 Filesize:  17.2 KB
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Engines-List All times are GMT - 8 Hours
