Pable Mackenzie Guest
Posted: Wed Nov 26, 2014 4:16 am Post subject: Aircraft flight instruments |
Hi,Dear Friend,
I like to share my knowlege with you and want to gain more if you are have same interest related Aircraft's Spare Parts
Modern passenger jets not only have sophisticated Aircraft flight instruments systems, they go a step further and transmit accumulated data (via satellite feed ) at regular intervals to ground stations that have been setup and monitored by the engine manufacturers. This helps engine manufacturers make appropriate notations and pay special attention to under-performing engine parts during the next maintenance overhaul or, they may even recommend an early overhaul.
The Aircraft sensor systems in a modern jet also sends critical performance related information to the aircraft flight recorder (black box). In the unfortunate event of a crash, such information plays a big hand in helping determine the cause of the crash.
BestRegards
Pable Mackenzie
18.05 KB |
2109 Time(s) |
18.05 KB |
2109 Time(s) |
9.68 KB |
2109 Time(s) |
8.29 KB |
2109 Time(s) |
