HELP! Mag info needed--M-14P
netmaster15(at)juno.com
PostPosted: Fri Jun 30, 2006 9:15 am    Post subject: HELP! Mag info needed--M-14P Reply with quote
Dennis, or any other,
Recently I discovered the presence of oil residue in the right mag of my M-14P.  More than a light trace, less than heavy fluid in quantity. I have removed the mag from the engine and want to replace the seal inside at the bottom of the mag.  I need, and would appreciate ,  a parts blowup or any type of diagram showing disassembly  procedure. Screws at bottom of mag are shallow  slot head screws which seem to have been put in place by an 800 lb gorilla and I don't want to tear anything up trying to remove them. Can anyone fax me a diagram and procedural
summary applicable to this task?  I will furnish fax number upon request  Thanks All
   Cliff
   YAK 50
On Fri, 30 Jun 2006 06:19:08 -0500 "A. Dennis Savarese" <dsavarese(at)elmore.rr.com (dsavarese(at)elmore.rr.com)> writes:
[quote] Tim,
I agree with Gary.  You may have an intake leak.  Check all your intake tube gland nuts and intake collars.  If you have an intake drain kit, be sure all the fittings are tight as well.
Dennis
PostPosted: Sat Jul 01, 2006 4:35 pm    Post subject: HELP! Mag info needed--M-14P Reply with quote
Cliff,
You may want to contact Steve Culp of Culps Specialties.  He has new/overhauled M9-F mags for $680.  They are on Ebay.
http://cgi.ebay.com/ebaymotors/M-14P-Mag-Russian-Radial-Aircraft-Engine_W0QQitemZ4615461747QQihZ002QQcategoryZ26437QQssPageNameZWD1VQQrdZ1QQcmdZViewItem
The attached diagram is the only IPB that I could come up with.
Dennis
M9-F_Mag_Drive_Assembly.doc
 Filename:  M9-F_Mag_Drive_Assembly.doc
 Filesize:  113 KB
 Downloaded:  449 Time(s)
