Rear Wing Channels (Scratch Builder Question)
sky_ranger161
PostPosted: Fri Jun 30, 2006 2:57 am    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
Hi guys,
I'm to the point of fabricating the rear wing channels and on my XL. These things are 12' long, and my plan is to bevel the edge of my work table for proper springback, use the router to radius the edge and basically make a 12' form block out of the edge of my table. Seems logical enough to me, but I was wondering if  (a.) this has already been tried and (b.) was it successful?
If not, how did you guys make this 12' bend? I saw on Scott Laughlin's site that he had cut his, but never shows the bending process. I've seen some pretty ingenious press brakes out there too, but am looking at this from a cost vs. return standpoint as well. As always, any help is greatly appreciated.
Debo Cox
XL/Corvair
Working on wings
Sneak preview the [url=http://us.rd.yahoo.com/evt=40762/*http://www.yahoo.com/preview] all-new Yahoo.com[/url]. It's not radically different. Just radically better.
mgraves(at)usmo.com
PostPosted: Fri Jun 30, 2006 3:49 am    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
Debo,
I have never tried 12ft this way, I have bent aprox 7 ft this way. It is
not as good as finding a brake that will bend it. But I think acceptable.
If you do end up bending your channels this way. I would suggest using a
piece of plywood aprox 2 ft long to start the bend. Strike the plywood
with the mallet and move it along. It makes a nicer piece than just
striking the alum directly with the mallet in these long pieces.
Its also makes a better piece to use most of a full sheet of alum width
wise.... bend the first lip, move it out, bend the middle, move it out
bend the last lip, and snip it off of the larger sheet. This way you get
a much better clamping surface.
Monty
At 03:52 AM 6/30/2006 -0700, you wrote:
Hi guys,
successful?
appreciated.
Debo Cox
XL/Corvair
Working on wings
Sneak preview the
<http://us.rd.yahoo.com/evt=40762/*http://www.yahoo.com/preview>all-new
Yahoo.com. It's not radically different. Just radically better.
nfivesl(at)yahoo.com
PostPosted: Fri Jun 30, 2006 5:12 am    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
Debo:
I bent the two pieces with the 8' brake I built from
Larry McFarland's plans. If you can find an 8' sheet
brake you can build the rear channel and splice it. I
think the spliced rear channel is stronger than the
full piece because you have to drill that large hole
for the aileron control. The splice happens to fall
right where you drill the hole so you have much
thicker material there where the rear channel is the
weakest.
Using the table or any other form block will give you
a twisted channel - especially over a 12' length. I
know this because I tried it. The splice really is a
good solution. I got a hand drawing from Chris Heintz
for the splice. I think it may be posted on
ch601.org.
Have a good day,
Scott Laughlin
www.cooknwithgas.com
In the home stretch.
--- Debo Cox <sky_ranger161(at)yahoo.com> wrote:
Hi guys,
sky_ranger161
PostPosted: Fri Jun 30, 2006 3:12 pm    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
Thanks for the replies guys. Once again the list comes through. I appreciate the help.
Debo Cox
XL/Corvair
Ron Lendon
PostPosted: Fri Jun 30, 2006 7:46 pm    Post subject: Re: Rear Wing Channels (Scratch Builder Question) Reply with quote
Hey Debo,
I am getting ready to tackle the wings also and in doing some research I came up with this link in the archives:
http://www.matronics.com/photoshare/HeatonHE(at)aol.com.05.07.2006/index.html
The pictures show how Herb Heaton made a 12' long press brake and made his parts. I am thinking of going along these same lines.
I am currently sidetracked tearing down what looks like a 110 corvair motor.
Ron Lendon
CH 601 XLB
N601LT - Flying
Corvair Engine Prints:
dclaytx2(at)HOTMAIL.COM
PostPosted: Mon Jul 03, 2006 10:29 am    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
I just made my rear wing channels today. Bent them with my trusty $75
bending brake. They turned out great. I'm going the 6 foot spliced route. If
the good folks at Can Zac think it's OK, and Zen-Master Scott Laughlin
thinks it's OK, and most importantly, if Chris Heintz thinks it's OK...then
its OK with me.
If anyone is interested I can email you step by step instructions (with
photos) showing how I did this task.
Dave
Scratch building wings
 Filesize:  91.57 KB
 Viewed:  431 Time(s)
randy(at)shadycreekoutlaw
PostPosted: Mon Jul 03, 2006 11:17 am    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
If you'd like me to post the step by step on my site, send them to me and
I'll put em' up...
Randy
ch601xl(at)gmail.com
PostPosted: Mon Jul 03, 2006 12:16 pm    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
You know I will as well Dave...Please send.
On 7/3/06, Dave and Jan Clay <dclaytx2(at)hotmail.com (dclaytx2(at)hotmail.com)> wrote:
its OK with me.
Dave
Christopher W. E. Smith
fly1m1
http://ch-601xl.com
PostPosted: Mon Jul 03, 2006 12:45 pm    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
Wow Dave! That picture looks like you came to my
garage and cleaned it up and took that picture! Mine
used to be that clean but somehow it got messy and I
can't bring myself to stop and re-organize it before I
finish my airplane.
Your rear channel bend looks great. I think the
spliced channel is stronger than the 12' version since
you reinforce the channel right where you drill the
big hole for the aileron control rod. Chris H. is
good with it and I have a sketch from him to prove it.
Just to be clear, the splice is a mini-channel that
fits inside the flanges of the channel, not just a
plate. It's a tricky bend to get just right so get
some scrap pieces ready for trial and error.
Great work,
Scott Laughlin
Wishing my garage was as clean as Dave's.
DO NOT ARCHIVE
with my trusty $75
waj(at)quik.com
PostPosted: Mon Jul 03, 2006 2:03 pm    Post subject: Rear Wing Channels (Scratch Builder Question) Reply with quote
Great looking work Dave ,your brake design must be working well .Building
the brake is my next task .Please e-mail me the rear wing channel photos
.Thanks Wade
