cffd66(at)yahoo.com Guest
Posted: Tue Nov 18, 2014 9:46 am Post subject: CH 701 tires |
Normal 0 false false false EN-US X-NONE X-NONE MicrosoftInternetExplorer4 <![endif]-->
<![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} <![endif]-->
When I got my CH 701 kit in 2000, they supplied Titan Turf Glide tires and tubes. Titan quit making these. I found that Carlisle (Summit Racing supplier) makes a Turf Glide tire with tread exactly like the Titan’s. Titans weighed about 6 pounds while the Carlisle weigh 8 pound 11 oz. The Carlisle side walls are much stiffer. I recently changed out my main gear tires. After a sitting couple of days, the new tires get a flat spot on the bottom and take a lot of taxiing to get them round enough to takeoff. I increased the pressure to 20 psi but no luck. Has anyone else had this problem?
Chuck D. N701TX
lgold(at)quantum-associat Guest
Posted: Wed Nov 19, 2014 2:03 pm Post subject: CH 701 tires |
Deiterich,
The Carlisle turf glides I used (before switching to better tires) tended to be out of round or badly balanced and prone to thorns (they are only 2-ply rated). When I purchased them I would visit the supplier and roll them to find those that were not too bad.
From: owner-zenith701801-list-server(at)matronics.com [mailto:owner-zenith701801-list-server(at)matronics.com] On Behalf Of Charles Deiterich
Sent: Tuesday, November 18, 2014 9:46 AM
Subject: CH 701 tires
Chuck D. N701TX
01234567890123456789
rvsimons
Posted: Wed Nov 19, 2014 2:24 pm Post subject: CH 701 tires |
Yes I had the exact same issue with the Carlisle turf glides. It got to the point that I would suspend my mains by putting blocks under the axles. That was the only way I could keep the flat spots out of the tires. That was on a taildragger ultralight. I ran out like that until I sold the airplane. I never did try to remedy the issue with another tire.
Vance On Nov 19, 2014 2:05 PM, "Les Goldner" <lgold(at)quantum-associates.com (lgold(at)quantum-associates.com)> wrote:[quote]
Deiterich,
From: owner-zenith701801-list-server(at)matronics.com (owner-zenith701801-list-server(at)matronics.com) [mailto:owner-zenith701801-list-server(at)matronics.com (owner-zenith701801-list-server(at)matronics.com)] On Behalf Of Charles Deiterich
To: zenith701801-list(at)matronics.com (zenith701801-list(at)matronics.com)
Chuck D. N701TX
_________________ Vance Simons
Post Falls, Idaho
Zenith 701 |
Dan Wilde
Posted: Wed Nov 19, 2014 8:33 pm Post subject: CH 701 tires |
On 11/19/2014 10:01 AM, Les Goldner wrote:
| Quote: | v\:* {behavior:url(#default#VML);} o\:* {behavior:url(#default#VML);} w\:* {behavior:url(#default#VML);} .shape {behavior:url(#default#VML);} <![endif]--> <![endif]--> <![endif]-->
Deiterich,
Chuck D. N701TX
| I have the Carlisle tires from Summit Racing and the only problem I had was with them sealing to the rim. I put a tube in the one tire that would not seal correctly and have had no further problems. The tubes are as expensive as the tires tho. I was raised in northern Minnesota and in the really cold weather I remember the car tires would have a flat spot until you drove a ways.
Dan
john.marzulli(at)gmail.co Guest
Posted: Thu Nov 20, 2014 11:11 am Post subject: CH 701 tires |
My experience is that the Carlise tires need a tube, which sucks when you pinch a tube in the middle of North Dakota.
The Airstreaks hold their air and provide a better landing experience, but cost about 3-4MPH in cruise speed.
On Wed, Nov 19, 2014 at 8:35 PM Dan Wilde <stolpilot.wilde(at)gmail.com (stolpilot.wilde(at)gmail.com)> wrote:
[quote] On 11/19/2014 10:01 AM, Les Goldner wrote:
Deiterich,
Chuck D. N701TX
Dan
_blank">www.aeroelectric.com
="_blank">www.mypilotstore.com
ank">www.mrrace.com
ist" target="_blank">http://www.matronics.com/Navigator?Zenith701801-List
tp://forums.matronics.com
