Tundra10
  Joined: 14 Jun 2010 Posts: 102 Location: Scarborough, Ontario
				 Posted: Mon Nov 17, 2014 10:02 am    Post subject: Charging system problem - please help |
				Digging through the schematics and parts listing, the over voltage
 sensor was added at serial number 17259904 which was the second
 production year of the 172L (1972).
 I have a 1970 K model which has circuit breakers and the new double
 rocker master switch.
 Unfortunately, it looks like to add the over voltage module, I also
 need to change the regulator, which has the additional connection for
 the low voltage light, so it becomes an expensive proposition.  I also
 don't know what Transport Canada would require to consider the change
 legal.  So I won't bother.
 Jeff Page
 Dream Aircraft Tundra #10
  	  | Quote: | 	 		   Time: 05:58:40 AM PST US
  From: "Robert L. Nuckolls, III" <nuckolls.bob(at)aeroelectric.com>
  Subject: Re: Re: Charging system problem - please
  help troubleshoot
  At 07:13 2014-11-16, you wrote:
 > I can tell you for sure that 1968 & 1969 Cessna 172's were equipped
 > with alternators and a push-pull master switch AND no over-voltage
 > protection.  Don't forget that the alternator ground is part of the
 > charging circuit.
      Good data point. Thanks!  I'm going to the
      Textron Electronics Lab Thanksgiving lunch
      next week. I'll get into the archives and
      see what the evolutionary steps were that
      lead up to the full changeover to alternators,
      rocker switches and ov protection.
      Did those aircraft still have fuses?
