jmjones2000(at)mindspring Guest
Posted: Sun Nov 09, 2014 4:53 am Post subject: John Deer PM Alternator |
Has anyone used the John deer PM alternator? With some research, I have found that it is 20A and requires an external regulator. It weighs 3.5 lbs and the cost is around $110 usd.
Part numbers:
SE501843
2500A
2500B
APM0005
AM877557
10939
and many more
Seems it may be a good lightweight alternator for primary or backup use.
Justin
raymondj(at)frontiernet.n Guest
Posted: Sun Nov 09, 2014 5:25 am Post subject: John Deer PM Alternator |
When I was following the Corvair aircraft engine building lists they
were using the JD item on the builds. You may find some info there also.
Raymond Julian
Kettle River, MN
The things we admire in men, kindness and generosity, openness, honesty,
understanding and feeling are the concomitants of failure in our system.
And those traits we detest, sharpness, greed, acquisitiveness, meanness,
egotism and self-interest are the traits of success. And while men
admire the quality of the first they love the produce of the second.
-John Steinbeck, novelist, Nobel laureate (1902-1968)
On 11/09/2014 06:52 AM, Justin Jones wrote:
Part numbers:
SE501843
2500A
2500B
APM0005
AM877557
10939
and many more
Justin
yellowduckduo(at)gmail.co Guest
Posted: Sun Nov 09, 2014 5:49 am Post subject: John Deer PM Alternator |
I've got 600 hours on one of those running one side of a Z-14 setup with
the matching J-Deere regulator. I did convert it to a multi-v belt
pulley which was a bit of a challenge. It Turns 8 to 10,000 rpm on my
setup. I replaced one of the ball bearings that seemed dry when I
happened to have the unit off at around 500 hours. I believe they are
popular with the Corvair and VW converters as well.
Ken
On 09/11/2014 8:22 AM, rayj wrote:
Raymond Julian
Kettle River, MN
honesty, understanding and feeling are the concomitants of failure in
our system. And those traits we detest, sharpness, greed,
acquisitiveness, meanness, egotism and self-interest are the traits of
success. And while men admire the quality of the first they love the
produce of the second. -John Steinbeck, novelist, Nobel laureate
(1902-1968)
> <jmjones2000(at)mindspring.com>
> Part numbers:
> SE501843
> 2500A
> 2500B
> APM0005
> AM877557
> 10939
> and many more
> Justin
Posted: Sun Nov 09, 2014 6:57 am Post subject: John Deer PM Alternator |
Ken,
Are you running it on the front of a lycoming? I would like to find a way to drive it from the rear vacuum pad. The b&c alternators are pricey in comparison.
| Quote: | On Nov 9, 2014, at 16:47, Cherie&Ken <yellowduckduo(at)gmail.com> wrote:
I've got 600 hours on one of those running one side of a Z-14 setup with the matching J-Deere regulator. I did convert it to a multi-v belt pulley which was a bit of a challenge. It Turns 8 to 10,000 rpm on my setup. I replaced one of the ball bearings that seemed dry when I happened to have the unit off at around 500 hours. I believe they are popular with the Corvair and VW converters as well.
Ken
> When I was following the Corvair aircraft engine building lists they were using the JD item on the builds. You may find some info there also.
> Raymond Julian
> Kettle River, MN
> The things we admire in men, kindness and generosity, openness, honesty, understanding and feeling are the concomitants of failure in our system. And those traits we detest, sharpness, greed, acquisitiveness, meanness, egotism and self-interest are the traits of success. And while men admire the quality of the first they love the produce of the second. -John Steinbeck, novelist, Nobel laureate (1902-1968)
>> Part numbers:
>> SE501843
>> 2500A
>> 2500B
>> APM0005
>> AM877557
>> 10939
>> and many more
>> Justin
Posted: Sun Nov 09, 2014 8:31 am Post subject: John Deer PM Alternator |
At 07:47 2014-11-09, you wrote:
Depending on the regulator technology, running a PM alternator
at very high speeds elevates risk to the electronics. Unlike
the wound-field machines where actual output votlage is limited
by the regulator, a PM alternator's output is proportional to
driving RPM. So running a PM alternator as much greater speeds
than they operate in their other-life on garden tractors
MIGHT prove challenging to the PM regulator.
Posted: Sun Nov 09, 2014 8:40 am Post subject: John Deer PM Alternator |
At 06:52 2014-11-09, you wrote:
I think they have some 3-phase models that run
upwards of 30A.
Posted: Sun Nov 09, 2014 5:27 pm Post subject: John Deer PM Alternator |
Well no I'm running it with a dedicated 3-V belt on a Subaru slowed to
what I consider acceptable. The original single V "pulley" arrangement
is quite small. It is not feasible to drive this thing from a vacuum pad
IMO. It would entail a lot of machining and very likely put the engine
accessory drive at risk from torsional resonances.
Ken
On 09/11/2014 9:54 AM, Justin Jones wrote:
Ken,
> Ken
>> Raymond Julian
>> Kettle River, MN
>>> Part numbers:
>>> SE501843
>>> 2500A
>>> 2500B
>>> APM0005
>>> AM877557
>>> 10939
>>> and many more
>>> Justin
