rvdave
Posted: Tue Oct 14, 2014 4:23 pm Post subject: Advice on red cube install |
Trying to decide how to install the red cube to the AFP fuel system I have. Engine came with fuel lines made up and looking to possibly cut existing line to make red cube fit. Attached photos show cube strapped to where I'm thinking of placing it. Questions I have:
1). Is this the best location considering the system and lines that I have?
2). Is it enough to support red cube by adel clamps above and below cube and let those clamps be sole support?
3). Where can I send this fuel line to get new fittings attached?
https://www.dropbox.com/sc/ugtbx1d3mvj0n4y/AABmGFpc4V3IZbsI98cvO1IOa
_________________ Dave Ford
Cadillac, MI |
Posted: Tue Oct 14, 2014 4:44 pm Post subject: Advice on red cube install |
I'll reply inline.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
jesse(at)saintaviation.com
Sent from my iPad
Quote: | On Oct 14, 2014, at 8:23 PM, "rvdave" <rv610dave(at)gmail.com> wrote:
That's not a bad location and it should work fine.
I'm not a big fan of that. I would recommend a bracket bolted where you are proposing putting the Adel clamp.
You can't. Those lines are made and then the fire sleeve is molded on, I'm pretty sure. Aircraft Spruce has a custom hose order form where you can specify length, ends, sizes, etc. I would replace the single line with 2 new lines for that location.
rleffler
Posted: Tue Oct 14, 2014 6:24 pm Post subject: Advice on red cube install |
I would call Tom at TSFlightlines a call to see what options you may have regarding modifying your fuel lines, If not possible, he's a great source to get new lines constructed.
Sent from my iPad
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=431881#431881
_________________ Bob Leffler
N410BL - Phase I
Kellym
Posted: Tue Oct 14, 2014 7:04 pm Post subject: Advice on red cube install |
Bonaco is another good source.
On 10/14/2014 7:23 PM, Bob Leffler wrote:
Sent from my iPad
> Dave Ford
> RV6 flying
> RV10 building
> Cadillac, MI
KCHD |
Posted: Wed Oct 15, 2014 8:10 am Post subject: Advice on red cube install |
Even though I don't have the AFP fuel system, I had the folks at AFP do
the hoses.
I went to their weekend fuel injection class just to get gain some
knowledge about fuel injection systems in general. Great people there.
I came away convinced to move my GRT (red cube equivalent) fuel meter
from the tunnel to where you are putting yours. It did make my fuel
consumption numbers it dead nuts accurate.
Months after the class I gave them measurements and such and they
provided 2 custom teflon hoses, with firesleeve, a needed AN fitting and
1 foot of firesleeve to wrap the (red cube) with. It cost $191.46 plus
shipping.
They will provide any consultation desired. As I recall there is a AN
fitting 'clocking' consideration with their fuel controllers so if you
need to change the direction of the fitting coming out of their unit,
you may want to chat with them.
Bill "wondering why only 1 mag is firing after engine re-install" Watson
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
Checked by AVG - www.avg.com
rvdave
Posted: Wed Oct 15, 2014 8:36 am Post subject: Re: Advice on red cube install |
Thanks guys, called Tom at TS Flightlines and he will add fittings to existing hose, just sent it to him. One other thing--do I need to get a short section of 2" fire sleeve for the cube?
Cadillac, MI |
Posted: Wed Oct 15, 2014 11:25 am Post subject: Advice on red cube install |
I don't think it's critical depending on how you have the unit mounted.
I was just mimicking an install that I had seen pictured.
I managed to use only one Adel clamp on the upstream hose. That
combined with the hose and padded (red cube) gave me a secure mount and
some vibration/heat protection. My unit is actually mounted on the
front of the engine block. But I have an entirely different set of
components than you are using. Same idea though.
On 10/15/2014 12:36 PM, rvdave wrote:
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p=431905#431905
woxofswa
Posted: Wed Oct 15, 2014 12:17 pm Post subject: Re: Advice on red cube install |
When I was at that stage I called the red cube's company.
They said.
1. The closer to the spider the better.
2. Straight connectors in and out.
3. Preferred no hard direct connection to the engine for vibration.
4. Preferred slight tip up of the exit to the entrance.
They also said that they were quite against the Van's tunnel recommendation.
I mounted mine at the front of the case on a piece of bent steel with a bit of spring to it and have had zero issues with it.
_________________ Myron Nelson
Mesa, AZ
Flew May 10 2014 |
n223rv(at)wolflakeairport Guest
Posted: Wed Oct 15, 2014 2:23 pm Post subject: Advice on red cube install |
I made all my own lines, they are actually quite easy.... Aircraft spruce sells all the components.
Just a thought...
Quote: | On Oct 14, 2014, at 11:03 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
> Sent from my iPad
>> Dave Ford
>> RV6 flying
>> RV10 building
>> Cadillac, MI
Posted: Thu Oct 16, 2014 4:13 am Post subject: Advice on red cube install |
On 10/15/2014 5:09 PM, Linn Walters wrote:
Quote: | On 10/15/2014 9:00 AM, Bill Watson wrote:
Quote: | Bill "wondering why only 1 mag is firing after engine re-install" Watson
There is only one thing that will prevent a mag from firing .... a grounded P-lead. Check the P-lead to make sure you didn't get it caught between things like the firewall/engine mount when you re-installed the engine.
Linn |
Well, actually I lied. After completing the SB and rehanging the engine, the first time I tried a start I got nothing. It just cranked. It wasn't immediately obvious but neither mag was firing!
This is embarrassing because I consider myself a careful and reasonably meticulous amateur mechanic but I'll share it for reflective purposes.
Using a mirror and flashlight I examined the LH Mag which had not been touched except to disconnect and reconnect the P-lead and the shower of sparks line. It turned out that I had a lock washer jammed between the P-lead terminal and the case of the Mag that was grounding the circuit. After removing the washer and putting a fresh washer under the terminal nut, the engine started.
But a mag check indicated that the RH Mag wasn't firing! Unlike the LH Mag, this Mag had been removed to facilitate removal/installation of the tach pickup that is screwed into the side of it. So before the first start, this Mag required pinning and timing which was all completed without an apparent problem.
Again using a mirror and a flashlight I examined the RH Mag and discovered that I had put the P-lead terminal underneath the insulating washer instead of on top. Well that seems like it might short the Mag. So with better lighting I rewire the upside down P-lead terminal and try again. The RH Mag is still 'dead'.
I should add that every step in this troubleshooting process is followed by much reflection, usually overnight, and study of every reference document available. I have copies of magazine articles, Light Plane Maintenance Newsletters, John Schwaner's Mag book, and printouts of various posts. Tim's informative mark-up of Slick's timing instructions remains the go-to reference guide for Mag timing. Thanks Tim!
I decide to just remove the P-lead from the Mag and let it run naked and hot, then work forward from there. Well, that didn't work either. I still had a 'dead' Mag. I should add the the engine started and ran just fine with only the LH Mag working. Only a Mag check indicated that I had a dead Mag.
I'm thinking, "Oh no, I may have over torqued the P-lead and ruined the condenser or something else that is going to require parts or a rebuild". But I decide to remove the Mag, take it to the bench, blanket it with brain waves and then very carefully go back through the installation procedure. I pin it, remove a set of plugs, position the prop, install it with fresh gaskets and time it. This time I leave the P-lead disconnected and run it naked and hot again. SUCCESS!
The good news is that it is now running perfectly and I got some experience with running a hot mag through the checks. The bad news is that I have absolutely no idea what I had done wrong initially.
Test flight scheduled for later today.
Linn, you are a gentleman for being so discreet in pointing out the obvious but evidently I'm immune to the obvious. Thanks for giving me a chance to reflect on my stumbles publicly.
Bill "finally released from SB jail" Watson
