		ed(at)solairecanada.com Guest
				 Posted: Wed Oct 29, 2014 9:05 am    Post subject: RV6-List Digest: 0 Msgs - 10/27/14 |
				I have just completed the FAB on my RV-6 and instructions say to put the
 seal on the front of the inlet on the FAB side.
 With the way the cowling goes on  (from the bottom) would it not make more
 sense to attach the bottom of the seal to the inlet on the cowling and the
 top of the seal on the FAB?
 Any reason this could not be done or am I overlooking something?
 Ed Hollestelle.
  |  | - The Matronics RV6-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  http://www.matronics.com/Navigator?RV6-List |
		n146wb(at)cfu.net Guest
				 Posted: Wed Oct 29, 2014 10:52 am    Post subject: RV6-List Digest: 0 Msgs - 10/27/14 |
				Ed,
 I put my seals on per the plans (RV-6) and it works ok as long as there is
 enough gap between the end of the inlet on the cowl and the front edge of
 the FAB.  I always have to push the bottom part down around the lip of the
 inlet when I install the lower cowl.  I think your suggestion might work
 pretty well and, from my experience, it probably would make the lower cowl
 easier to install.  You just need to ensure that you get a pretty good seal
 all the way around the lip on the cowling.
 Warren
				 Posted: Thu Oct 30, 2014 1:25 pm    Post subject: RV6-List Digest: 0 Msgs - 10/27/14 |
				Warren,
 Thanks for your input.
 I understand the need for a good seal (and fit) so that is what made me
 think thatif I put the bottom seal on the cowling side, it will fit without
 pushing it over the edge.
 If I use a small strip of alluminum (as with the front of the bottom baffle
 inlet) to attach the fabric seal and have that about 1" over the top on both
 sides it should work.
 The horizontal top seal will then fit tightly in between.
 I am just thinking that it will be easier to install the cowling that way.
 What do you think?
 Thanks again-Ed.
				 Posted: Thu Oct 30, 2014 2:14 pm    Post subject: RV6-List Digest: 0 Msgs - 10/27/14 |
				I'm sure it would be easier to install the cowling.  I dread having to pull off and install the lower cowling.  If you are successful with your idea, I would like to see some pictures as I might modify mine.
 Warren
 [quote] On Oct 30, 2014, at 4:24 PM, Ed Hollestelle <ed(at)solairecanada.com> wrote:
  Warren,
  What do you think?
  Thanks again-Ed.
