Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List
Craymondw(at)aol.com
PostPosted: Tue Sep 16, 2014 6:21 pm    Post subject: 140831_0001.JPG Reply with quote
This is what a Glasair2S exhaust should look like.
- The Matronics Glasair-List Email Forum -
http://www.matronics.com/Navigator?Glasair-List
 Filesize:  93.12 KB
 Viewed:  4781 Time(s)
robin02(at)mindspring.com
PostPosted: Wed Sep 17, 2014 7:49 am    Post subject: 140831_0001.JPG Reply with quote
Ray, what is the function of the bulbs near the exhaust ports? RObin
From: owner-glasair-list-server(at)matronics.com [mailto:owner-glasair-list-server(at)matronics.com] On Behalf Of Craymondw(at)aol.com
Sent: Tuesday, September 16, 2014 10:18 PM
To: glasair-list(at)matronics.com
Subject: 140831_0001.JPG
PostPosted: Wed Sep 17, 2014 10:31 am    Post subject: 140831_0001.JPG Reply with quote
They are swivel joints that prevent cracking. The exhaust supplied by Glasair for the 180's and 200's h.p. not only cracked all the time, the design robbed the engine of 180 & 200 h.p. Lycoming engines of power. The flanges supplied by Glasair are so thin they warped causing exhaust leaks. The powder coating reduces heat up to 15 degrees. We have a man flying his GL3 up to have his exhaust redesigned. The exhaust shown will cost you less than $1,800 and nearly the cost of the one supplied by Glasair and will add extra ponies to your engine and the three inch tail pipe sounds like a 1960's muscle car. If you are interested contact jeffrj2007(at)yahoo.com (jeffrj2007(at)yahoo.com)
In a message dated 9/17/2014 11:49:21 A.M. Eastern Daylight Time, robin02(at)mindspring.com writes:
Subject: Glasair-List: 140831_0001.JPG
href="http://www.matronics.com/Navigator?Glasair-List">http://www.matronics.com/Navigator?Glasair-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Glasair-List All times are GMT - 8 Hours
