Wings missing mass balance recesses
gavanne(at)iconz.co.nz
PostPosted: Tue Sep 16, 2014 1:26 am    Post subject: Wings missing mass balance recesses Reply with quote
Hi Tony
I have what is referred to as a "hybrid".
I purchased the wing and tail kit in 1997 and they were of foam core construction, by the time I was ready for the fuselage the XS was in production so I ended up with classic "foam core" wings and tail and an XS fuselage.
If this is what you have rest assured the combination works just fine
Based in Auckland, welcome to come across and inspect if you wish
Gavin Lee
ZK - EPA
 Filesize:  106.44 KB
 Viewed:  3229 Time(s)
 Filesize:  108.95 KB
tonyvaccarella
PostPosted: Sun Feb 22, 2015 4:41 pm    Post subject: Re: Wings missing mass balance recesses Reply with quote
Hi Gavin,
I only just saw your reply - from many months ago.
What you described is exactly the same as what happened to me. I got an XS Fuselage and Classic wings. I could not work out what happened until I saw the Classic build manual and then it all came together.
Thanks for your reply and invitation to inspect your aircraft. The pictures look great. Do you have fun flying the Europa around NZ?
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
PostPosted: Mon Feb 23, 2015 11:18 pm    Post subject: Wings missing mass balance recesses Reply with quote
Hi Tony
Yes they are a great machine, a lot of fun
Gavin
On 23/02/2015, at 1:41 pm, tonyvaccarella <tony(at)weimagine.com.au> wrote:
Hi Gavin,
Tony
Tony Vaccarella
Mascot NSW 2020
Sydney Australia
http://forums.matronics.com/viewtopic.php?p=438595#438595
