Posted: Sat Sep 13, 2014 10:14 am Post subject: Engine removal for SB 14-08-29 |
Has anyone been successful mounting the engine to the engine mount with
the prop installed?
During initial construction, I had the opportunity demount and remount
the engine. During this the second mounting I attempted to keep the
prop installed on the engine but found it difficult/impossible to get
the assembly on the engine mount.
I then removed the prop and found the process to once again be quite easy.
Any insight or experience here welcome.
Bill "executing delay maneuvers before tackling engine removal" Watson
Posted: Sat Sep 13, 2014 10:39 am Post subject: Engine removal for SB 14-08-29 |
I've done it both ways .... and both ways are a PITA. Can't say which
way was easier. Instead of using both lift rings (no prop) I used the
aft ring and a strap around the prop blades at the hub (with prop). I
find it easier to put the engine on the mount using smaller dia. bolts
and then replacing them, one at a time, with the correct bolts.
Linn
On 9/13/2014 2:04 PM, Bill Watson wrote:
with the prop installed?
easy.
Checked by AVG - www.avg.com
rene(at)felker.com Guest
Posted: Sat Sep 13, 2014 11:12 am Post subject: Engine removal for SB 14-08-29 |
During my initial build I found a crack in my nose wheel strut. Vans sent
me a new one. To replace it. I left the engine mounted to the engine mount
and removed the engine mount from the firewall. Replaced the strut and then
remounted the assembly to the firewall. I did not have all the wiring done
at that time......
Just FYI, not sure it is an option since you have to remove more than the
strut to affect the repair.
Rene'
N423CF
801-721-6080
Kelly McMullen
Posted: Sat Sep 13, 2014 1:06 pm Post subject: Engine removal for SB 14-08-29 |
One very helpful item is to have a load leveling bar on the hoist, which lets you tilt the engine quite a bit forward or aft as needed. IIRC they are not terribly expensive at Harbor freight, or you may be able to borrow one.
On Sat, Sep 13, 2014 at 12:01 PM, Rene <rene(at)felker.com (rene(at)felker.com)> wrote:
[quote]--> RV10-List message posted by: "Rene" <rene(at)felker.com (rene(at)felker.com)>
at that time......
Rene'
N423CF
[url=tel:801-721-6080]801-721-6080[/url]
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Sat Sep 13, 2014 1:47 pm Post subject: Engine removal for SB 14-08-29 |
Yep, I have one. The one with those immortal words, "Not to be used for aircraft purposes".
On 9/13/2014 4:51 PM, Kelly McMullen wrote:
[quote] One very helpful item is to have a load leveling bar on the hoist, which lets you tilt the engine quite a bit forward or aft as needed. IIRC they are not terribly expensive at Harbor freight, or you may be able to borrow one.
at that time......
Rene'
N423CF
157.32 KB |
4472 Time(s) |
Posted: Wed Sep 17, 2014 12:07 pm Post subject: Engine removal for SB 14-08-29 |
So I have removed my engine and will remove the mount this evening.
Questions for the list:
- I'm planning on replacing the engine mount elastomers. At 500 hours,
why not except for $$$. Thoughts?
- I don't know about replacing the nose wheel elastomers. Afterall,
they are already compressed and 'set'. Thoughts?
Bill
Posted: Wed Sep 17, 2014 12:17 pm Post subject: Engine removal for SB 14-08-29 |
I would think this comes under the heading of 'if it ain't broke ....
don't fix it'.
They will continue to compress, but the rate slows down over time. They
should last for 10 years or more. I'd keep adding spacers until you see
cracks in the elastomer.
Linn
On 9/17/2014 4:06 PM, Bill Watson wrote:
hours, why not except for $$$. Thoughts?
Bill
