		| Author | Message |
		| moe-rosspistons(at)hotmai Guest
		| Back to top |  |
		| lloydsss11(at)MSN.COM Guest
				|  Posted: Sun Aug 31, 2014 7:49 am    Post subject: From: Moe Mills |   |
				| <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Mo, how much weight did you lose? Every 6 lbs you lose extends your range  by 5 miles in a 500b.
[quote]   -----    Original Message -----
 From:    Moe    Mills (moe-rosspistons(at)hotmail.com)
 To:    commander-list(at)matronics.com (commander-list(at)matronics.com)
 Sent:    Sunday, August 31, 2014 8:30 AM
 Subject:    From: Moe Mills
 Hi
 http://venturetechnologies.net/living.php?eckayhnx3046fxxrky
 moe-rosspistons(at)hotmail.com (moe-rosspistons(at)hotmail.com)
 [b] 	  | Quote: |  	  |
 title="http://www.matronics.com/Navigator?Commander-List" href="http://www.matronics.com/Navigator?Commander-List">http://www.matronics.com/Navigator?Commander-List
 | |  |  | - The Matronics Commander-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Commander-List
		| Back to top |  |
				|  Posted: Sun Aug 31, 2014 10:32 am    Post subject: From: Moe Mills |   |
				| Lloyd,
 It appears that I have been hacked.  About 30 years ago I lost about 80 lbs. and my weight has not varied over 5 or 6 pounds since then.
 It would be most interesting to look at the data that compares the gross weight with the fuel burn.  My 680F(p) burns about 55 gallons per hour, and the  maxim gross weight is 8,000 lbs.  Usually the take off weight is around 7,600 lbs, as I most often fly either alone or with one lite passanger.
 Moe Mills
 N680RR
 680F(p)
 Subject: Re: From: Moe Mills
 Date: Sun, 31 Aug 2014 11:51:12 -0400
 Hi
  	  | Quote: |  	  |
 st" target="_blank">http://www.matronics.com/Navigator?Commander-List
 http://forums.matronics.com
		| Back to top |  |
				|  Posted: Sun Aug 31, 2014 5:37 pm    Post subject: From: Moe Mills |   |
				| <?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]-->  Sorry about hacker. I rounded out fuel burn on the 500B to about 30 gals /  hr at 12000FT , about 200mph. That’s about 1.1 mile per Lb of fuel. hope   that provides incentive for maintaining a lean frame. I'm about 198 down from  250 when I bought the commander 24 yrs ago. rgds
 To:    commander    list (commander-list(at)matronics.com)
 Sent:    Sunday, August 31, 2014 2:31 PM
 Subject:    RE: From: Moe Mills
 Lloyd,
 Moe    Mills
 N680RR
 680F(p)
 [b] 	  | Quote: |  	  | -----      Original Message ----- From:      Moe      Mills (moe-rosspistons(at)hotmail.com)
 Hi
  	  | Quote: |  	  |
		| Back to top |  |
