Undercarriage
rj_todd(at)yahoo.co.uk
PostPosted: Fri Aug 29, 2014 2:47 am    Post subject: Undercarriage Reply with quote
Hi Folks,
If you haven't seen this on Vansairforce.net I strongly suggest you read http://www.vansairforce.com/community/showthread.php?t=116171
What Dave Brown has reported is greatly worrying.
Best wishes to all,
Rodger
rv10flyer
PostPosted: Fri Aug 29, 2014 4:57 am    Post subject: Re: Undercarriage Reply with quote
I guess flying at the aft CG limit with the family 90% of the time and being #486 in the air has some other benefits. We fly off of grass once or twice per year, but will definitely keep an eye on it.
Wayne G.
n223rv(at)wolflakeairport
PostPosted: Fri Aug 29, 2014 11:29 am    Post subject: Undercarriage Reply with quote
This should be interesting and very appropriately timed for me.... I am starting my condition inspection this weekend and I fly exclusively off of grass.... But so far I only have ~180 hours...
-Mike Kraus
On Aug 29, 2014, at 8:57 AM, "rv10flyer" <wayne.gillispie(at)gmail.com> wrote:
Wayne G.
http://forums.matronics.com/viewtopic.php?p=429574#429574
rv10free2fly(at)yahoo.com
PostPosted: Sat Aug 30, 2014 7:27 pm    Post subject: Undercarriage Reply with quote
Oh bugger!
Warm regards
Patrick
On 29 Aug 2014, at 20:16, Rodger Todd <rj_todd(at)yahoo.co.uk (rj_todd(at)yahoo.co.uk)> wrote:
[quote]Hi Folks,
Best wishes to all,
Rodger
Kellym
PostPosted: Sat Aug 30, 2014 7:40 pm    Post subject: Undercarriage Reply with quote
Inspected mine today, more as an exercise in determining how much effort
it will take to install the doubler. Did see there was a little
interference between top shock disk and the rear tubes, so that will get
eliminated before I reassemble. I just used engine hoist to lift nose
after I had compressed disks by jacking under tail tiedown, removed
retaining bolt, then removed jack to allow tail to go down.
Not a lot of work, could have waited to first condition inspection, but
I decided I wanted to get the doubler before any problem shows up, as I
sure wouldn't want to have to remove the engine mount to have it weld
repaired.
On 8/30/2014 8:26 PM, Patrick Pulis wrote:
Oh bugger!
Warm regards
Patrick
<mailto:rj_todd(at)yahoo.co.uk>> wrote:
> Hi Folks,
> <http://Vansairforce.net> I strongly suggest you read
> Best wishes to all,
> Rodger
Kelly McMullen
KCHD
