RnJCurtis(at)charter.net Guest
Posted: Thu Aug 14, 2014 3:18 pm Post subject: ELT: 406 vs 121.5 |
I know that there have been some discussions on 121.5 Mhz vs 406 Mhz ELT's.
My question is, what is the general consensus of opinion as to
recommendations on a new experimental aircraft? I don't presently have an
ELT, but will be purchasing one in the near future. Also interested in
initial cost and cost of maintenance ie. batteries.
What are the expectations that the 406 will be mandated, and when? Does the
406 have a large advantage? I know that it can pinpoint location much more
accurately.
Should I spring for the extra bucks for a 406? What great advantage do you
receive when you pay $1800+ as apposed to $600?
That should be enough questions for now!
Roger Curtis
Posted: Thu Aug 14, 2014 4:54 pm Post subject: ELT: 406 vs 121.5 |
At 06:16 PM 8/14/2014, you wrote:
| Quote: | --> AeroElectric-List message posted by: "R&J. Curtis" <RnJCurtis(at)charter.net>
I know that there have been some discussions on 121.5 Mhz vs 406 Mhz ELT's. My question is, what is the general consensus of opinion as to recommendations on a new experimental aircraft? I don't presently have an ELT, but will be purchasing one in the near future. Also interested in initial cost and cost of maintenance ie. batteries.
What are the expectations that the 406 will be mandated, and when? Does the 406 have a large advantage? I know that it can pinpoint location much more accurately.
Should I spring for the extra bucks for a 406? What great advantage do you receive when you pay $1800+ as apposed to $600? |
Are you seeing new 121.5/243Mhz ELTs for sale?
I think part 91 prohibits them as new installations
after 6-21-95 . . .
[img]cid:.0[/img]
Then there is the matter of just how useful the
older ELT will be in finding your wreck. See:
http://tinyurl.com/kz93ymy
I'm seeing ACK 406 ELTs with GPS data
ports for 500-700 dollars.
91.71 KB |
6268 Time(s) |
edpav8r(at)yahoo.com Guest
Posted: Thu Aug 14, 2014 4:59 pm Post subject: ELT: 406 vs 121.5 |
$1,800? The ACK E-04 406MHz ELT new installation kit is $589 at Aircraft Spruce:
http://bit.ly/1lZI2q7
Eric
| Quote: | On Aug 14, 2014, at 4:16 PM, "R&J. Curtis" <RnJCurtis(at)charter.net> wrote:
Roger Curtis
dlj04(at)josephson.com Guest
Posted: Fri Aug 15, 2014 1:10 am Post subject: ELT: 406 vs 121.5 |
First, keep in mind that 406 MHz ELTs are *also* 121.5 MHz ELTs, so
existing monitoring on 121.5 is not going to go away any time soon. FCC
announced around five years ago that they were planning to ban
manufacture and use of 121.5/243 ELTs, but gave up when AOPA and FAA
asked them not to do that. FCC will not approve any new 121.5/243 MHz
ELT transmitter designs but existing models can still be made, sold and
installed.
There are three TSOs that apply to ELTs. The early ones like the
original Narco ELT-10 meet TSO C91 and have a mechanical G switch that
was never too reliable, and went off by itself some times. You can
continue to use one if installed in your plane but you may not make a
new installation of a C91 ELT. In 1985 the spec was revised to TSO C91a
which requires a much better G switch. You can still buy and install
these. The new 406 MHz ELTs meet TSO C126 as well as C91a, and besides
transmitting to the satellites for a near instant fix on where you are,
have a still better G switch. Most have the ability for the user to test
them easily.
If you don't care whether people find your wreck, a used C91a unit is
probably fine. If I were buying a new one, under $600 for a 406 MHz unit
is cheap enough, I think.
fvalarm(at)rapidnet.net Guest
Posted: Fri Aug 15, 2014 11:56 am Post subject: ELT: 406 vs 121.5 |
121.5 is no longer monitored via "satelites". Cross country pilots should
still listen on 121.5 if able, and report. Airborne searches and ground
crews can still home in on the 121.5. But if you want to be "saved", and
not just "recovered eventually", you must have 406 with GPS connected. If
"recovery" is good enough for you but your plane has a passenger seat, your
choice affects them too.
Bevan
tim2542(at)sbcglobal.net Guest
Posted: Fri Aug 15, 2014 3:25 pm Post subject: ELT: 406 vs 121.5 |
Evidently 406 even without GPS is pretty good, local A&P got a call from a customer. He had been called by the Feds to notify him his ELT was triggered. They were able to tell him where it was parked on the ramp, GPS not connected yet.
Tim
[quote] On Aug 15, 2014, at 12:55 PM, "B Tomm" <fvalarm(at)rapidnet.net> wrote:
Bevan
Kellym
Posted: Fri Aug 15, 2014 8:35 pm Post subject: ELT: 406 vs 121.5 |
Excellent description of the differences. There are some other
considerations. ELTs were first required in 1973. Satellite monitoring
did not start until perhaps the mid 1980s, so the loss of sat monitoring
of 121.5 just means less false alarms pursued. The TSO91a units are far
and away the least expensive for new legal install, including
maintenance as most allow usage of standard D cells.
A 406 ELT is 2-3 times more expensive to buy, requires at least double
the install time IF connecting to a GPS, and requires at least 2 and
some 3 lithium batteries. The least expensive ACK requires 3 batteries.
It will come with the main battery, which costs well north of $100 to
replace, and you will have to buy the other 2 photo type batteries that
are 10-20 each, which operate the remote panel and the alarm buzzer. All
3 are good for at least 5 years if not triggered. However, a false alarm
trip that goes for more than 1 hour will not only get you a phone call,
but you will get to replace that main battery, at a minimum. Also, not
entirely clear what recurrent tests will have to be done, as the current
reg is written to testing 121.5 units. Some have a self test built in,
but that may not be sufficient.
Also, there is one more expensive 406 unit with its own built-in GPS,
that incorporates GPS antenna with the transmit antenna, but is
certified without 121.5. As far as I know only a few CAP aircraft have
the capability to home in on a 406 only signal, while all can home on 121.5.
On 8/15/2014 2:08 AM, D L Josephson wrote:
<dlj04(at)josephson.com>
FCC announced around five years ago that they were planning to ban
and installed.
C91a which requires a much better G switch. You can still buy and
install these. The new 406 MHz ELTs meet TSO C126 as well as C91a, and
besides transmitting to the satellites for a near instant fix on where
you are, have a still better G switch. Most have the ability for the
user to test them easily.
unit is cheap enough, I think.
KCHD |
stuart(at)stuarthutchison Guest
Posted: Sat Aug 16, 2014 1:02 am Post subject: ELT: 406 vs 121.5 |
Worldwide satellite monitoring of 121.5/243.0MHz was disabled in Feb 2009.
The frequency stability spec for 406MHz is much tighter, facilitating more
accurate Doppler analysis for LEO (moving) satellites, but if you have GPS
fix from your ELT, then GPS position is appended to the digital signal and
your location is known to GEO (fixed overhead) satellites in near-real-time.
The HEXID also positively identifies you against the registry database, so
the 95% of false alarms generated by 121.5MHz systems can be resolved and/or
the search area narrowed down very promptly. It may be legal to install an
analogue, indistinguishable 121.5MHz ELT, but it may take up to 9 hours for
the RCC to determine your position via multiple LEO passes. $600 over seven
years (until battery replacement time) seems like cheap insurance to be
confident of a chance the USAF/CAP could rescue me before I/we bled to death
or succumbed to exposure. As they say in the SAR world, the first 24hrs is
often the only 24hrs to find survivors. It's especially unfortunate when
people survive a crash, only to die in the days that followed before they
were found.
Cheers, Stu
F1 Rocket VH-FLY www.mykitlog.com/rockfly
dalamphere(at)comcast.net Guest
Posted: Sat Aug 16, 2014 2:36 am Post subject: ELT: 406 vs 121.5 |
I think that the GPS personal locator beacons are a more cost
effective idea.
They are small, easy to register and easy to use. If you survive the
crash then you turn it on.
If not, it doesn't matter.
Why do the feds want us to go the expensive route?
Dave
2009.
facilitating more
have GPS
signal and
real-time.
database, so
resolved and/or
install an
hours for
over seven
be
to death
24hrs is
when
they
were found.
Cheers, Stu
JOHN TIPTON
Joined: 17 Sep 2006 Posts: 239 Location: Torquay - England
Posted: Sat Aug 16, 2014 3:12 am Post subject: ELT: 406 vs 121.5 |
Yes: we have the McMurdo 'fast find'
http://www.aircraftspruce.com/catalog/avpages/fastfind-220a.php?clickkey=1218506
http://www.transair.co.uk/sp+McMurdo-Fast-find-220-PLB-with-GPS+3181?utm_campaign=Googlebase&utm_medium=organic&utm_source=Googlebase&gclid=Cj0KEQjwgryfBRDn7cvY-pOit4cBEiQAB3nTbokOhCSCFQLHeqmrA3c9yfvcDIW_yZHQlxi7yiZATNoaAm-N8P8HAQ
John (G-BBKZ)
----x--O--x----
[quote] On 16 Aug 2014, at 11:34 am, David & Elaine Lamphere <dalamphere(at)comcast.net> wrote:
I think that the GPS personal locator beacons are a more cost effective idea.
They are small, easy to register and easy to use. If you survive the crash then you turn it on.
Dave
> were found.
> Cheers, Stu
Posted: Sat Aug 16, 2014 5:48 am Post subject: ELT: 406 vs 121.5 |
Principally, I suspect, because the SAR effort often puts numerous searchers' lives and platforms at significant risk in adverse weather and/or high terrain, and is astronomically expensive to conduct (which your taxes pay for).
As you say, you may already be dead, but the searchers don't know that until you are found, which may otherwise take days or even weeks. Do you want to put your family through that grief? It's like looking for a needle in a haystack where finding the haystack is a welcome start.
I have a Kannad 406 hardwired and an MT406G handheld. If I ditch, I would certainly want a 406mHz PLB attached to me. Having spent 18hrs overnight in a liferaft 5nm to sea, I can say with confidence that you would too! If a PLB is all you have, then be sure to write it into your emergency procedures to activate the PLB before you reach the ground/water.
Kind regards, Stu
| Quote: | On 16 Aug 2014, at 20:34, David & Elaine Lamphere <dalamphere(at)comcast.net> wrote:
Dave
trigo(at)mail.telepac.pt Guest
Posted: Sat Aug 16, 2014 8:05 am Post subject: ELT: 406 vs 121.5 |
Dave
Don't forget that you can survive the crash but not in condition to turn anything on!
In that case you will need the Feds to find your ELT.
Carlos
Enviado do meu iPhone
No dia 16/08/2014, às 11:34, David & Elaine Lamphere <dalamphere(at)comcast.net> escreveu:
Dave
> were found.
> Cheers, Stu
Posted: Sat Aug 16, 2014 9:00 am Post subject: ELT: 406 vs 121.5 |
kenryan
Posted: Sat Aug 16, 2014 10:31 am Post subject: ELT: 406 vs 121.5 |
Also, people are killed conducting searches. If you want to be found, and it you want to minimize risk to search and rescue personnel, get a 406.
On Sat, Aug 16, 2014 at 8:58 AM, B Tomm <fvalarm(at)rapidnet.net (fvalarm(at)rapidnet.net)> wrote:
[quote] --> AeroElectric-List message posted by: "B Tomm" <fvalarm(at)rapidnet.net (fvalarm(at)rapidnet.net)>
