kearney
Posted: Mon Aug 11, 2014 5:14 pm Post subject: Lean of Peak and other heresies |
Hi
At KOSH I received some very conflicted info on lean of peak ops with an IO540.
Continental (admittedly not a Lyc IO540), had a wonderful simulation / presentation about how to safely run LOP. Their position was to stay under 65% power to avoid the "red Box".
Lycoming seemed to think that LOP was was a high risk venture that most mere mortals should avoid like the plague. They even has a 2000 monograph that had a few veiled references to Gami.
Mike Busch was very much in support of LOP ops in either brand C or L engines. His view was physics doesnt't change with the brand of engine.
So, given that we have now resolved how to properly prime lithium batteries, I would be interested in hearing about first hand LOP experiences. Has anyone experienced problems with LOP. Lycoming seems to think that LOP requires more attention to detail than the average pilot can muster when things busy. They also suggest that ROP at power settings that match LOP power yields similar albeit somewhat higher fuel flows. Does actual experience bear this out?
Any comments?
Cheers
Les
Inquiring minds need to know!
rv10flyer(at)live.com Guest
Posted: Mon Aug 11, 2014 5:48 pm Post subject: Lean of Peak and other heresies |
Plainly put the lycoming rep was uneducated on the Lycoming stance:
http://www.avweb.com/news/maint/182849-1.html?redirected=1
Lie #7:
Aggressive leaning results in burned valves and detonation.
Fear of the red knob is one of the most pernicious areas of misinformation among general aviation pilots. Most pilots operate way too rich most of the time, and do so because of the mistaken belief that leaning will harm their engine. The result is usually trouble: fouled spark plugs, accelerated exhaust valve guide wear, and stuck exhaust valves.
Lycoming engine Lycoming has long authorized leaning to peak EGT at any cruise setting up to 75% power. TCM authorizes leaning to peak EGT up to 65%, and its latest recommendations even endorse lean-of-peak operation for many big-bore engines, provided the engines will run smoothly when operated that lean.
Contrary to popular belief, aggressive leaning doesn't cause burned valves. Most burned valves are the result of excessive valve guide wear or valve stem contamination.
Aggressive leaning doesn't cause detonation, either. Most of our engines are incapable of detonation at cruise power settings, provided that we don't exceed CHT red-line or try to burn contaminated fuel. Furthermore, recent tests on Lycoming engines by ASTM revealed this fascinating result: detonation is most likely to occur at a mixture setting 11% richer than stoichiometric (i.e., substantially richer than peak EGT).
Lean as aggressively as the book allows. For Lycomings, that means peak EGT at all cruise power settings to 75%. For Continentals, lean to peak EGT up to 65%, 50°F rich of peak at 75%. For turbocharged engines, also limit TIT to 1600°F.
Lean during all ground operations except for engine start. It is particularly important to lean for taxi and runup. Since EGT is usually off-scale at idle power, the best method is to lean for peak RPM at idle.
Read through Lycoming’s Key Operations- found on the lycoming site. Plenty about leaning at 75% and lower and even a chart that says they do not recommend LOP, but on the same page has:
pg38
6. Leaning to best economy mixture.
a. Set manifold pressure and RPM for the desired cruise power setting per the aircraft POH/AFM.
b. Lean slowly in small steps, while monitoring instrumentation, to peak TIT or maximum allowable TIT, whichever occurs first
[img]cid:3B93739FEA40497897A78D3550E4E0BE(at)pascalPC[/img]
than on pg 39:
Once cruise power has been set, leaning to best economy should be standard procedure as damage to the engine will not occur from leaning at cruise power settings.
141.62 KB |
15961 Time(s) |
![image[3].png](files/image_3__108.png)
gengrumpy
Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
Posted: Mon Aug 11, 2014 5:50 pm Post subject: Lean of Peak and other heresies |
Les,
I've been using Mike Busch's techniques with my Lyc IO540 and they work just great. My CHTs typically run 300 - 340 max or so at 65% and LOP, and are lower when I run less than 65% power.
I make the "big pull" to lean it out thus not spending any time in the "Red Box".
Fuel flows for me are typically 11 - 11.5gph at 65% power and that gives me (at)150KTAS in the 5 - 9k range.
Mike knows his stuff, and I just recently changed to a paid subscription on his website after hearing him talk about his new analysis capability for detecting early exhaust valve failures.
His website for uploading your data is an outstanding diagnostic tool, and beats the propriety program I have been using for years.
grumpy
On Aug 11, 2014, at 8:09 PM, LES KEARNEY <kearney(at)shaw.ca> wrote:
Hi
Any comments?
Cheers
Les
kearney
Posted: Mon Aug 11, 2014 6:19 pm Post subject: Lean of Peak and other heresies |
Hi Pascal
Here is a link to the monograph I hot from Lycoming at KOSH.
http://www.shamrockairservices.com/images/LEANING%20TECHNIQUES.pdf
Cheers
Les
On Aug 11, 2014, at 7:43 PM, "Pascal" <rv10flyer(at)live.com (rv10flyer(at)live.com)> wrote:
[quote] Plainly put the lycoming rep was uneducated on the Lycoming stance:
Lie #7:
pg38
<image[3].png>
than on pg 39:
Bob Turner
Posted: Mon Aug 11, 2014 6:31 pm Post subject: Re: Lean of Peak and other heresies |
In no particular order:
1. I do not attempt to operate LOP at high power settings. I think my injectors aren't tuned well enough to get all the cylinders out of the red box at high powers.
2. I did have to tune the injectors. Stock setup was not great in that regard.
3. Typical cruise for me is at 11,000'; all cylinders 10 to 30 F LOP; wide open throttle; 2200-2300 RPM; 9.5 gal/hr fuel flow; 160 KTAS. CHT's are 325 F plus or minus 10F or so (I removed the front air dams). This is two people plus bags. Full gross and I lose a couple of knots.
_________________ Bob Turner
RV-10 QB |
Posted: Mon Aug 11, 2014 6:49 pm Post subject: Lean of Peak and other heresies |
Funny thy tell folks to avoid when they have this to support just the opposite.
To answer you questions, I always fly LOP, I tuned the injectors and can get the plane to fly smoothly at around the 9.8-10.2gph range. Every annual has shown a very clean and good looking cylinder. The A&P that does the scope says it’s the cleanest cylinder he sees all year. He cant believe its because I fly LOP, but knows the certs he sees are flying ROP because of carbs or POH instructions to be 50-100F ROP, and is starting to believe that the 75F LOP I usually see is the reason for the cleaner inspections.
I have about 300hrs on the narrow deck / eci cylinders and LOP works very well for my CHT temps. I do not fly ROP ever (except TO and initial climb), pretty much from 1K up I have the aircraft leaned.
Pascal
Sent: Monday, August 11, 2014 7:18 PM
Subject: Re: Lean of Peak and other heresies
Hi Pascal
Cheers
Les
Lie #7:
pg38
<image[3].png>
than on pg 39:
Kelly McMullen
Posted: Mon Aug 11, 2014 6:54 pm Post subject: Lean of Peak and other heresies |
Pascal has it right. Lycoming says you are too inattentive, too dumb and basically incapable of operating lean of peak because a. their engineers have never tried it
b. their engineers are too stupid to understand it
c. their lawyers perceive a little itty bitty risk that must be avoided
d. they wouldn't want to change from what they recommended 50 yrs ago.
I've operated my 200 hp Lycoming IO-360-A1A LOP for the past 12 yrs or 700 hours without a problem. Prior to that it had some valve sticking that probably caused overload on the cam lobes that resulted in spalled cam lobes and lifters. It is stock 8.7:1 compression requiring 100 octane minimum...closer to detonation margin than an stock IO-540 260 hp at 8.5:1 compression.
The main thing is to understand that you have one reference point for ROP (when the first cylinder peaks) and LOP (when the LAST cylinder peaks). I normally run full throttle and 10-20 LOP anywhere above 6000 ft (~24" MAP). Fuel consumption will be about 0.5 gph per cylinder less than same power ROP.
75% for IO-540=195hp = ~13gph LOP.
65%=169hp=~11.3 gph
for normally aspirated engines between 8.5 and 8.7 to 1 compression when LOP power=FF*15 (14.9 if you want that much precision)
On Mon, Aug 11, 2014 at 7:18 PM, Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote] Hi Pascal
Cheers
Les
Lie #7:
pg38
<image[3].png>
than on pg 39:
A&P/IA, EAA Tech Counselor
KCHD |
Kelly McMullen
Posted: Mon Aug 11, 2014 6:56 pm Post subject: Lean of Peak and other heresies |
I'm assuming it is fuel economy that motivates your operating at 55% power LOP? Absolutely nothing wrong with it, and excellent speed for that power.
On Mon, Aug 11, 2014 at 7:31 PM, Bob Turner <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)> wrote:
[quote] --> RV10-List message posted by: "Bob Turner" <bobturner(at)alum.rpi.edu (bobturner(at)alum.rpi.edu)>
Bob Turner
RV-10 QB
http://forums.matronics.com/viewtopic.php?p=428328#428328
le, List Admin.
KCHD |
kearney
Posted: Mon Aug 11, 2014 7:22 pm Post subject: Lean of Peak and other heresies |
Hmmm
Has anyone run LOP with 9:1 compression cylinders?
For the IO540, is there a power setting analogous to the Brand C 65% power setting that eliminates the red box risk?
Cheers
Les
On Aug 11, 2014, at 8:53 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]Pascal has it right. Lycoming says you are too inattentive, too dumb and basically incapable of operating lean of peak because a. their engineers have never tried it
65%=169hp=~11.3 gph
[quote] Hi Pascal
Cheers
Les
Lie #7:
pg38
<image[3].png>
than on pg 39:
Kelly McMullen
Posted: Mon Aug 11, 2014 7:48 pm Post subject: Lean of Peak and other heresies |
Les,
Just curious why you would want 9:1 compression when the availability of
true 100 octane fuel into the future is questionable?
The gain in horsepower might help a little on really short or high
elevation airports, but it isn't going to do much for cruise speed.
I don't know anyone that thinks the acceleration and climb of the stock 260
is inadequate for most any normal operation.
The physics is the same. 8.7:1 has almost zero red box and 8.5 to 1 even
less. Higher compression just means the red box is bigger and needs more
attention, just like a turbo would.
On Mon, Aug 11, 2014 at 8:21 PM, Les Kearney <kearney(at)shaw.ca> wrote:
[quote] Hmmm
Cheers
Les
have never tried it
compression.
ROP.
65%=169hp=~11.3 gph
On Mon, Aug 11, 2014 at 7:18 PM, Les Kearney <kearney(at)shaw.ca> wrote:
> Hi Pascal
> Cheers
> Les
> Sent from my iPhone
> Lie #7:
> that lean.
> TIT to 1600°F.
KCHD |
This is right on based on my experience as well. Our -10 has over 1,300 hrs on ECI narrow deck cylinders running LOP exactly as Pascal describes. Tuned injectors help. Some engines can't even get LOP smoothly without them. Some do, but it helps in all cases. That is why I started stocking the AFP restrictors. I recommend it to everybody I can. It's nice to be able to avoid the Gami prices with our experimentals.
Jesse Saint
Saint Aviation, Inc.
352-427-0285
On Aug 11, 2014, at 10:53 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
65%=169hp=~11.3 gph
[quote] Hi Pascal
Cheers
Les
Lie #7:
pg38
<image[3].png>
than on pg 39:
partner14
Joined: 12 Jan 2008 Posts: 540 Location: Granbury Texas
Posted: Mon Aug 11, 2014 7:57 pm Post subject: Lean of Peak and other heresies |
How about 9:5 compression? That's what I have, and I fly LOP everywhere. Lot's of hp, 3 blade prop... cruise at 1/2 throttle (at 10,500', instead of WOT providing 21.3 inches, I'm around 18.5") and between 2,000 and 2,100 rpm. I'm sure Kelley will tell us what % power that setting is. Before some of you say "he can't get 21.3" at 10,500, I only get 20.3".... you can if you have a 4" forward facing servo with cold air induction and an F1 Rocket scoop.
With these settings we cruise fast enough (156kts), have a low fuel burn, and the engine temps and my wallet are very happy.
Don Mc
To: "rv10-list(at)matronics.com" <rv10-list(at)matronics.com>
Sent: Monday, August 11, 2014 10:21 PM
Hmmm
Cheers
Les
65%=169hp=~11.3 gph
[quote] Hi Pascal
Cheers
Les
Lie #7:
pg38
<image[3].png>
than on pg 39:
_________________ Don A. McDonald
40636 |
kearney
Posted: Mon Aug 11, 2014 8:06 pm Post subject: Lean of Peak and other heresies |
Hi Kelly
I am not too fussed about 100ll. As well, I plan to fly over the rocks to the west.
Cheers
Les
On Aug 11, 2014, at 9:47 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]Les,
Just curious why you would want 9:1 compression when the availability of true 100 octane fuel into the future is questionable?
The gain in horsepower might help a little on really short or high elevation airports, but it isn't going to do much for cruise speed.
I don't know anyone that thinks the acceleration and climb of the stock 260 is inadequate for most any normal operation.
The physics is the same. 8.7:1 has almost zero red box and 8.5 to 1 even less. Higher compression just means the red box is bigger and needs more attention, just like a turbo would.
On Mon, Aug 11, 2014 at 8:21 PM, Les Kearney <kearney(at)shaw.ca (kearney(at)shaw.ca)> wrote:
[quote] Hmmm
Cheers
Les
65%=169hp=~11.3 gph
[quote] Hi Pascal
Cheers
Les
Lie #7:
pg38
<image[3].png>
than on pg 39:
Kellym
Posted: Mon Aug 11, 2014 8:07 pm Post subject: Lean of Peak and other heresies |
The only way to determine power LOP is by the fuel flow calculation I provided earlier. While higher compression does provide somewhat better efficiency, it is offset by lower detonation margins. I don't know whether WOT with stock compression would be less or equally efficient than partial throttle with higher compression. I do know that partial throttle does disrupt the airflow into the manifold. Whether that offsets some of the efficiency gain would probably have to be determined on a dyno or other instrumented setup.
I just prefer the keep it simple way of doing things, so that if something fails, I can get replacement stock parts, and I don't have to worry if I find myself somewhere that only 91 octane mogas is available.
All choices that we get to make as amateur builders. Only those that make sense for our individual needs are the right ones.
Kelly
On 8/11/2014 8:56 PM, Don McDonald wrote:
[quote] How about 9:5 compression? That's what I have, and I fly LOP everywhere. Lot's of hp, 3 blade prop... cruise at 1/2 throttle (at 10,500', instead of WOT providing 21.3 inches, I'm around 18.5") and between 2,000 and 2,100 rpm. I'm sure Kelley will tell us what % power that setting is. Before some of you say "he can't get 21.3" at 10,500, I only get 20.3".... you can if you have a 4" forward facing servo with cold air induction and an F1 Rocket scoop.
Don Mc
From: Les Kearney <kearney(at)shaw.ca> (kearney(at)shaw.ca)
To: "rv10-list(at)matronics.com" (rv10-list(at)matronics.com) <rv10-list(at)matronics.com> (rv10-list(at)matronics.com)
Hmmm
Cheers
Les
[quote] Pascal has it right. Lycoming says you are too inattentive, too dumb and basically incapable of operating lean of peak because a. their engineers have never tried it
65%=169hp=~11.3 gph
[quote] Hi Pascal
Cheers
Les
Lie #7:
pg38
<image[3].png>
than on pg 39:
KCHD |
Kellym
Posted: Mon Aug 11, 2014 8:18 pm Post subject: Lean of Peak and other heresies |
Hi Les,
Like I said, individual choices, individual opinions. Compression needs
are probably related to which primer you used......................
IIRC the -10 will climb over any rock in North America with a stock
engine. I know the service ceiling is higher than my 200 hp Mooney that
will do 18,800 for service ceiling. IIRC there aren't too many rocks in
Canada besides Mt. Logan that are in the upper teens.
Of course most of us ignore the advice that mods take time, money, more
time and more money.
On 8/11/2014 9:06 PM, Les Kearney wrote:
| Quote: | Hi Kelly
to the west.
Cheers
Les
KCHD |
Jim Berry
Posted: Mon Aug 11, 2014 9:03 pm Post subject: Re: Lean of Peak and other heresies |
| kearney wrote: | Hmmm
Cheers
Les
Since I primed everything, I figured I needed 9:1 pistons to get off the ground. My Barrett IO-540 also has roller cam, Bendix 1200 mags, and AFP injection with restrictors matched to 0.1 gal thanks to Don Rivera. My home field elevation is 5800 ft. I routinely run WOT, 23-2400 rpm and LOP (at) 10-10.5 gph. I do the big pull in less than 5 seconds, so don't worry much about the red box. After 4 years and approx. 400 hours, boroscope, plugs, oil analysis and compression all remain great.
Jim Berry
Mike Whisky
Posted: Tue Aug 12, 2014 4:31 am Post subject: Re: Lean of Peak and other heresies |
I run my TMX-IO-540 always LOP. Usually at 8-9.5k WOT it generates 160 TAS using 38-40l/h which is about 10-10.5 USGAL .
You should take the advanced pilot seminar online course this will make you understand the physics behind engine management. I after break in I spent all my flights on injector balancing and I am now at a 2l difference which works for now. Clearly electronic engine monitoring and balanced fuel flow injection is a prerequisite for LOP ops. Given that I pay about 11.7$ per USgal LOP makes a lot of sense from an economical view as well.
Mike
_________________ RV-10 builder (flying)
#511 |
