		Bill Reining
  Joined: 13 Aug 2007 Posts: 13 Location: Oakland, California
				 Posted: Thu Aug 07, 2014 11:48 am    Post subject: NavWorx ADS-B |
				Kelly and All
 After reading your comments posted Saturday, I went back to the NavWorx booth and was fortunate to get some quality time with Bill Moffitt.  I told him I was concerned that I didn't have a clear picture of his product and it's status, nor did others in the RV-10 community.  He was kind enough to bring me up-to-date.  Note - I am in no way affiliated with NavWorx - I'm just an interested 182 owner and RV-10 builder.
 The NavWorx products are a Universal Access Transceiver (UAT).  They send out, and receive in, ADS-B information.  It is the "out" requirement that will be mandatory in all aircraft as of January first, 2020.  There is another way to meet the "out" requirement - a transponder with extended squitter (ES).  NavWorx does not offer such a transponder.  Aircraft that fly above 18,000 feet within the US, or that fly internationally, will have to have an ES transponder.  This may be a deciding factor for the RV-10, considering it's performance.  (It is not so for my lower performance Cessna 182 in California, unless the Canadians and Mexicans really get on the bandwagon.)  Bear in mind that if you only install an ES transponder to meet the requirement, it does not receive the free ADS-B "in" traffic and weather information.
 NavWorx has two basic models, both of which are TSO'd and have an STC/AML for installation in all aircraft, whether certified, experimental, or LSA.  These models are the ADS600-B ($2399) and the ADS600-BG ($3499, drops to $2899 on 4/1/2016).  They are identical except for their internal GPS.  The -B has a non-compliant GPS internal to it, and can be used today through 1/1/2020.  After 1/1/2020, and to meet the mandate, the -BG will be required.  The -B can be upgraded to the -BG after April 1, 2016 for $500, though that cost is likely to fall by the time 2020 arrives.  Both models are available now.
 The fact that the NavWorx products have their own GPS makes installation pretty simple.  The transceiver is remotely mounted.  There is no control panel.  Two new antennas are required: one for the internal GPS, the other for the ADS-B signal.  (The antennas are an additional cost: for certified aircraft they cost $499, for experimental and LSA $89.99.)
 A clever "TransMon" (looks kinda like a dongle) is strapped to the current mode C transponder's coax cable that runs between the transponder and it's antenna.  The TransMon picks up the current code being squawked, the altitude being reported, and whether an IDENT signal is being sent.
 The transceiver must be connected to electrical power (9 to 33 volts DC at 0.5A for 14 volts, or .33A for 28 volts.)
 The only other connection is to the device to be used to display the incoming ADS-B information (traffic and weather).  NavWorx has reverse engineered many of the current, and legacy displays (such as the MX-20 in my 182).  NavWorx will display the weather and traffic on the Garmin handhelds, beginning with the GPSMAP-396 and up, including the AERA.  It is compatible with Aspen displays.  The information will be presented on any of these displays per the original device's design, without any extra hardware.  There are some systems which will not work with the NavWorx "in" information (traffic and weather), due to their proprietary design.  These include Dynon products and the Garmin 650, 750 and G3X.)
 NavWorx also offers, as an accessory, a WiFi module, for $120.  The WiFi module will allow the ADS-B "in" information to be displayed on a tablet, such as the iPad (if the app accepts it - ForeFlight may be a problem.)  NavWorx will do 2 displays at once (e.g. something on the panel and a tablet.)
 For those who may consider both a UAT and an "extended squitter" transponder, the NavWorx can supply the necessary GPS data to the ES transponder.
 Bill estimates a shop that has sufficient experience installing ADS-B equipment can install the NavWorx equipment in about 15 man hours.  Of course the experimental community can do so themselves.
 I realize this message is pretty long-winded, but I hope the information is useful.
 Bill Reining
 RV-10 40514 (QB wings)
  |  | - The Matronics RV10-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
  _________________ Bill (and Jon) Reining
40514 |
				 Posted: Thu Aug 07, 2014 12:59 pm    Post subject: NavWorx ADS-B |
				Thanks for the summary.
 I've had the "B" model unit installed and flying for over a year.
 Displaying the ADSB-in weather and traffic on my GRTs and seemingly
 doing the ADSB-out.  I talked to Bill briefly and was relieved to hear
 that my box would be upgradeable  when needed.
 Wifi support for FF would make life complete.
 On 8/7/2014 3:48 PM, Bill Reining wrote:
  Kelly and All
  Bill Reining
  Checked by AVG - www.avg.com
		Kellym
				 Posted: Thu Aug 07, 2014 6:07 pm    Post subject: NavWorx ADS-B |
				Seems like FF is trying to limit compatibility to the Stratus units
 exclusively.
 On 8/7/2014 1:58 PM, Bill Watson wrote:
KCHD |
		gengrumpy
  Joined: 07 May 2013 Posts: 131 Location: Tullahoma, TN
				 Posted: Thu Aug 07, 2014 6:11 pm    Post subject: NavWorx ADS-B |
				Unless we all start banging on them to open up to others!!!!
 grumpy
 On Aug 7, 2014, at 9:05 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
  Seems like FF is trying to limit compatibility to the Stratus units exclusively.
		Tim Olson
				 Posted: Thu Aug 07, 2014 6:40 pm    Post subject: NavWorx ADS-B |
				Seems like?  Basically they've always been that way and show no signs of
 changing.  That's why I advocate openness and buy wingX for in flight.
 Admittedly, I buy Foreflight for preflight planning because it's awesome
 for that, but for in flight I won't pay Foreflight for pro when wingX
 offers a discount for 3 year subscription.  That's my biggest problem
 with garmin too.  If they were into open standards for protocols I'd
 have a much higher opinion of the company.
 Tim
  	  | Quote: | 	 		   On Aug 7, 2014, at 9:05 PM, Kelly McMullen <kellym(at)aviating.com> wrote:
		Kellym
				 Posted: Thu Aug 07, 2014 6:47 pm    Post subject: NavWorx ADS-B |
				What variety of primer do you use on FF?? Does it work on Garmin stuff
 as well?
 On 8/7/2014 7:40 PM, Tim Olson wrote:
  of changing.  That's why I advocate openness and buy wingX for in
  flight. Admittedly, I buy Foreflight for preflight planning because
  it's awesome for that, but for in flight I won't pay Foreflight for
  pro when wingX offers a discount for 3 year subscription.  That's my
  biggest problem with garmin too.  If they were into open standards for
  protocols I'd have a much higher opinion of the company.
  Tim
 > exclusively.
KCHD |
		Tim Olson
				 Posted: Thu Aug 07, 2014 6:58 pm    Post subject: NavWorx ADS-B |
				  I guess I always use green.....without giving foreflight, wingx,
 Jeppesen, and others lots of green, it's much harder to fly.
 Tim
 On 8/7/2014 9:46 PM, Kelly McMullen wrote:
  as well?
 > Tim
 >> exclusively.
		Rv10flyer(at)live.com Guest
				 Posted: Thu Aug 07, 2014 7:50 pm    Post subject: NavWorx ADS-B |
				I've managed to fly across the country two times and never spent a dime with the green tools.
 I have free FltPlan go and Iflightplanner for iPad , that offers everything I need for inflight, I used airnav FBO for airport fuel info and flyQ for airport info. Granted its three tools to do the job of 1 but for the way I fly it seems to offer far more than I ever had in the military over 20 years ago. I actually needed to think where I was back in those days
 Not putting very nice tools like FF and wing X down, just commenting that there are other options that work well for free.
 Pascal
  	  | Quote: | 	 		   On Aug 7, 2014, at 7:58 PM, Tim Olson <Tim(at)MyRV10.com> wrote:
  Tim
 > as well?
 >> Tim
 >>> exclusively.
		Bob Turner
				 Posted: Fri Aug 08, 2014 11:35 am    Post subject: Re: NavWorx ADS-B |
				Interesting marketing strategy: telling customers that if they wait the price will drop?
 I'm with Tim on trying to avoid companies that force you into one product line (with Foreflight, it's Stratus). Garmin has a very competitive mode S-ES transponder out now, but apparently it only works if you buy a G3X.
  _________________ Bob Turner
RV-10 QB |
		Tim Olson
				 Posted: Fri Aug 08, 2014 11:45 am    Post subject: NavWorx ADS-B |
				I think the reasoning for the price is, right now they're planning
 to do the GPS modules in a bulk order come next year, so, right
 now the production costs are much higher in small batch runs
 than if you wait a short time and get one after they do the
 large batch.
 I'm guessing prices will rise over time, otherwise, because
 there's been competition in the market now for a while, so
 unless someone drastically undercuts others, there's nothing
 that's going to bring much price pressure.
 Tim
 On 8/8/2014 2:35 PM, Bob Turner wrote:
  Bob Turner
  RV-10 QB
