ftyoder(at)yoderbuilt.com Guest
Posted: Sun Aug 03, 2014 7:20 pm Post subject: docs |
For those who have a Cont. IO-240 B1B in there TR-1 and haven't changed there rubber mount bushings recently, here are the part numbers and what they cost me from my source. Note that the four center bushings #638255 are not the same as used in the O-200. I had to remove my oil filter and adaptor in order the remove the bottom right mount bolt. The gasket was the replacement for the oil filter adaptor. If you have a different model IO-240 you may not need the gasket.
It is a bit of a chore but well worth the effort.
Thanks to OC Baker for his help no getting me the information I needed to complete this job.
Tim
From[img]cid:CF25E085-02DD-495E-A812-387A693ADAC3(at)ph.cox.net[/img]: Tim Yoder [mailto:timyoder(at)mac.com]
Sent: Sunday, August 03, 2014 7:47 PM
To: Dad
Subject: docs
[img]cid:C7DDB9F0-3963-44EF-B761-B10BD6A74316(at)ph.cox.net[/img]
This email is free from viruses and malware because avast! Antivirus protection is active.
| | - The Matronics KIS-List Email Forum - | | | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
1.94 MB |
2320 Time(s) |
1.35 MB |
2320 Time(s) |
hans.erstad(at)gmail.com Guest
Posted: Sun Aug 03, 2014 10:09 pm Post subject: docs |
Thanks for sharing this information Tim. I have IO-240 and have not changed the bushings yet. Now I know how..
Hans Christian
2014-08-04 5:19 GMT+02:00 Tim Yoder <ftyoder(at)yoderbuilt.com (ftyoder(at)yoderbuilt.com)>:
| Quote: | For those who have a Cont. IO-240 B1B in there TR-1 and haven't changed there rubber mount bushings recently, here are the part numbers and what they cost me from my source. Note that the four center bushings #638255 are not the same as used in the O-200. I had to remove my oil filter and adaptor in order the remove the bottom right mount bolt. The gasket was the replacement for the oil filter adaptor. If you have a different model IO-240 you may not need the gasket.
Tim
From[img]cid:CF25E085-02DD-495E-A812-387A693ADAC3(at)ph.cox.net[/img]: Tim Yoder [mailto:timyoder(at)mac.com (timyoder(at)mac.com)]
To: Dad
Subject: docs
1.94 MB |
2317 Time(s) |
1.35 MB |
2317 Time(s) |
